Walnut Bathroom Cabinet
5,937
63
18
Published
Introduction: Walnut Bathroom Cabinet
About: Open to learn new things. every time try something new.
It is part one of bathroom project.
Minimalist walnut sink cabinet
Step 1: Sourcing the Wood
I got raw wood from the local saw. I took some more wood, because this is the first project for bathroom. The second one is still to come.
So for the cabinet i took two 4m long and 4 cm thick walnut plank.
Step 2: Prepairing Two Planks for Glueing
The planks ware rough straight from band saw and dried in drying house.
So the first step was to flatten one side and one edge.
This was done with hand plane.
Step 3: Time for a Glue
When one side and one edge was flat and the edge was fitting perfectly it was time to glue them together.
I tried to match the grain, to get uniform grain pattern as possible. That later i would get look like it is one peace wood.
For glue i spread the glue on both side, align the planks and press them together on a workbench.
Them left it 24 hours to cure.
Step 4: Rouhg Shaping and Flatenning Other Side
After a glue-up I cut the rough shape.
I did that, because there was still quite some twist in board. especially on edges. So when I cut of excess, a also cut of the most twisted part.
Than like the first side time for some more planning.
P.S. don't forget on "soft jaws" for your vise, if you don't have real woodworking vise. if you use your metalworking vise without soft jaws, it will leave markings on wood, and all the work will be ruined.
Step 5: Filling Epoxy to Knots
One part of plank was with knots.
And I want to have whole cabinet from one peace, the was no other chance to do as fill those not stable knots with epoxy resin.
So I clean the knot. everything, that was not stable went out, and filled with laminating epoxy resin.
Then left to cure 24 hours before it was sended down to lever of wood.
Step 6: Cuting to Sections and Prepairng for Gluing
After the ford was nice and flat, it was time for cutting it to sections.
I measured the sections, and cut them with circular saw at 45 degree. every joint needs to be cut two times, to become a miter joint later.
Because my circular saw couldn't cut trough all wood, u finished with handsaw.
Saw left quite rough finish. to be able to make as good as possible miter joint i had to plane it down to flatten it. And than try both pieces together. than i was sending then so long til i got the perfect fit.
After all was fit i glue them together. one at the time.
For clamping i did a clamp, that wag exactly 90 degree.
Step 7: Sending and Oiling
Now we are close to end.
After the glue was dry I sended everything with 220 grit sandpaper.
And than i oiled it with Osmo oil.
This was the moment when wood shined with all of his beauty.
Step 8: Setting Up
After all was dry it was time for setting it in bathroom.
For fitting an wall I used a long screw, that i glued in wall with constructional epoxy.
And after the epoxy was dry, I just slip it on.
    • Oil Contest
      Oil Contest
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    1 Questions
    18 Comments
    very nice post i have something more here
    Very Nice! Beautiful piece
    Everything looks more "arty", than "handy". And making one piece from 2 desk... unnecessary waste of resources, including hand flattering. My position is "simplify as much as you can", means MAKE something, but don't waste time on boring work - it can be automated.
    agree, if i would have a jointer and thicknesser. and transporting 4m long plank in normal car is not an option. so hand planing in my garage was the only option :)
    Love your sink/cabinet combo! Very well done.
    Now, for an unrelated question. Was the wall hung toilet a bugger to install?
    Thanks,
    Ji m
    yes and no. i had some problems with washer, but with 2-3 attempts it was OK.
    so not that much of a problem :)
    That's a lovely piece of work! Thanks for sharing it!
    I'm confused on how the screws from the wall attach into the walnut. Can you please explain?
    Actually it is threathed rod. but it could be just a smooth rod. thread is not important. and it is not screwed on.
    it is just slides on 4 rods, on every corner.
    and it is secured with small allen screws from bottom. (picture with arrow).
    That is really great! Can you also say where you sourced the sink? Thanks for sharing.
    Stunning work
    This turned out really nicely, and a great complement to the unique sink. Great looking results!
    That looks beautiful. I like the use of the corner clamps to keep them at 90 degrees. Well done.
