25 Cent Fork Ring
23,130
479
29
About: My name is Troy. I'm a Mechatronics graduate studying Mechanical Engineering. I like to make things and spend time outdoors (especially SCUBA diving). I am a Community Manager for Instructables.
As stated in a previous instructable, my now fiancée loves rings! After her help with a yet-to-be published instructable, I felt that I owed her. I've always seen rings made from fork or spoon handles at city fairs, but we were recently out and about when we saw one made from the tines of a small fork. When I saw that I couldn't help but think "I could make that". After a quick trip to the local thrift store, the 25 Cent Fork Ring was born.
Step 1: Parts and Tools
Parts
  • Small forks from your local thrift store
Tools
  • Jewelers Mandrel
  • Hammer
  • 1/2" pipe (I used a pipe from my pipe clamps)
  • Vice grips
  • Hacksaw or Dremel cut off wheel
  • Calipers or ruler
  • Duct Tape
  • Sandpaper
  • Polish
Step 2: Flatten Fork
Flatten the fork by placing it between two boards and hammering together. This will keep from making unnecessary tool marks on the fork.
Step 3: Measure and Cut Fork
The size of the ring will determine the length of the fork. I wanted to make a size 8 ring. I decided that I wanted a little bit of space between the tines and the handle. I cut the fork about 5.5 mm shorter than the final circumference. This ended up making it a little bit too short. With future rings, I will cut the fork only 2 or 3 mm short and not the 5 as I have done with this ring.
I used a cut off wheel on my Dremel to make a clean cut.
Step 4: Initial Bend
Using a 1/2" pipe and vice grips, clamp the handle end of the fork to the pipe. Using a hammer, slowly bend and form the ring around the pipe. Apply several layers of duct tape on the vice grips wherever they will make contact with the fork. The less tooling marks you make in the fork means the less you will need to sand out later.
Step 5: Final Sizing
Using your jewelers mandrel and duct tape covered vice grips, slowly form the ring moving up the mandrel till the desired size is made.
Step 6: Sand and Polish
Once the ring is the correct size, sand out any tooling marks using increasingly fine sandpaper. I started out with 150, then 200, 350, 400, and 600. After that I used buffing compound to polish it up.
Step 7: Finished
Give your ring to someone that would appreciate the beauty found in common materials.
  • Fat Challenge
    Fat Challenge
  • Pie Contest
    Pie Contest
  • Jewelry Challenge
    Jewelry Challenge
29 Discussions
Watch me make
3 years ago
Why not forks are cheap at the thrift store
Watch me make
3 years ago
Want to try this but am at a FORK in the road on whether to do yours or seamsters
Mad laboratory
3 years ago
Wow, never knew you could do that 0-0
JulianAzz
3 years ago on Introduction
nice idea bro!, I love when people make use of forks and spoons
IamTheMomoCreathings
Reply 3 years ago
That's obviously his fiancé's hands. See her pretty engagement ring on the other hand? She has a nice French manicure, dude.
That's obviously a joke, even the Dutch have a keen sense of humor, he just forgot to add a smily or two. ☺
GerdeM1
love it, going to make one for myself, Thanx for the instructions
IamTheMomo
3 years ago
I like this project a lot! I am a foodie so stick a fork on my finger!
