3 Axis CNC Router - 60"x60"x5" - JunkBot
509,298
874
42
This Instructable is the first in a series documenting the construction of a DIY 3 axis CNC router. This is also my entry for the Universal Laser Cutter Contest.
The goal of this Instructable is not to show a full step by step progression but rather to pass along my experiences with making my own CNC.
I'm a MFA candidate (art student) at Rutgers University - Mason Gross College of the Arts. I designed this machine for the sculpture department to primarily cut soft material (foam, wax, some plastic and wood). I tried to leave as much room as possible for modification to suit the departments changing needs i.e. repurposing into a CNC plasma-cutter.
The design of my machine is loosely based around the Solsylva.com - Large Dual Leadscrew Table plans. I choose these plans a jumping off point - extracting what I needed and adding to the design to fit my needs. Linear motion control, next to the drive train, is often the most expensive system on a CNC device and the Solsylva plans present a simple yet elegant solution to cutting the cost of linear movement buy using roller skate bearings, angle iron, and EMT conduit.
There were a few concepts behind the design of this machine. The first was the use of scrap or existing materials - in essence recycling as much material as possible. The second idea was that any materials I needed to purchase I would try to obtained locally (Local Hardware Stores, Home Depot/Lowes, etc.) - the Solsylva plans are also based around this concept.
College art departments tend to generate a lot of usable scrap/waste. After a student projects are finished, they usually end up back in the scrap bin, metal recycling, or the dumpster. My goal for this project was to use as much of this "waste" material as possible and design the machine around these materials. The dimensions for parts were often times dictated by the size of the scraps available. The finish of this machine was inevitably dictated buy the materials I chose to use. I personally appreciate the scrappy junk-bot aesthetic - but then again I did build it ;)
This is project is a labor of love and a work-in-progress so there are a few things still unfinished - please excuse some of the inconsistencies in the photos as they've been taken at different time throughout the project.
Enough with the college talk and on to the good stuff -
The Machine Specs:
Materials: Recycled Steel and Aluminum.
Total Travel (x,y,z): 60" x 60" x 5"
Motors: 425 oz.in. dual shaft stepper Nema23 mounting.
Router/Spindle: Porter Cable 690 router (1/2" - 1/8" collets) or 1/4" trim router.
Motor Drivers/Electronics: Xylotex XS-3525/8S-3
Software: Mach3 (controller), various CAD/CAM software for object creation, tool paths, and g-code.
The table is geared, crank driven with quad lift screws and 1000lb capacity - and it's movable too. It's way overkill, but makes Z hight adjustment a dream. In the future this could become the Z axis if more movement is needed.
Supplies:
Step 1: The Z Axis (up and Down).
This step shows the progression of the Z axis - this was the most complex and time consuming assembly to manufacture.
Step 2: X and Y Axis Come Together - the Frame Takes Shape.
This is where the machine really starts to take shape.
Step 3: The Y Axis Drivetrain.
I really like the dual lead screw design - it has given us a lot of flexibility to have a movable table underneath the machine. Single lead screws designs usually have the screw running down the middle of the machine with a fixed cutting surface above. This limits the depth of the Z axis to the fixed table height.
Step 4: The Driver Board and Box - Cooling Overkill.
This box has a few too many fans. At the time I was unsure of how hot this was going to run, so I decided to error on the side of overkill - I think 4 fans is enough.
With the execption of the xylotex driver board and power supply, everything in this assembly was fabricated or from a recycled source.
Step 5: The First Project Out of the Machine.
This was the first 2D project to come out of the machine - It sits as a trophy next to our controller computer.
You can see a video this being cut on here.
Also the first 3D cut can be viewed here.
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    42 Discussions
    coolbigrock
    Question 1 year ago on Step 5
    Good day how can i download the full pdf to build my own like the on shown
    CharlesH62
    1 year ago
    How do you download the PDF without a premium account?
    ashithcalicut.
    2 years ago
    Take a look at my build.. Z-axis not yet complete..https://youtu.be/YEhp0V-Ah9A
    shezy
    3 years ago
    reply this can u send me y and z axis motor fixing pics
    sbsusilo
    3 years ago
    good works.....could you send me the drawings Plan and sktech up plans also ? I want to build this one.....I couldnt afford to buy here....and also can you show me the cost for building one ? We have a teenage community and so much we can do with this machine to challenge our creativity. sbsusilo76@gmail.com
    knoakes
    3 years ago on Step 5
    Great project, well done, I hope you got great marks for it.
    Are the threads just standard pitch screw threads?
    hasannebso
    4 years ago on Introduction
    thanx nice job , i love to build this router please can you send me the plane and the sketchup drawings
    h.nibso@yahoo.com
    burnerjack01
    6 years ago on Introduction
    Nice instructable. Im hoping to make one of these (or similar, seems the Instructable galaxy is awash in CNC stars...) One question I have is:" Feed rate. Is it an arbitrary value (static) or based on the media? Or is it based on motor loading? If static, I could see either needlessly long cycle times or at the other end, burned media and/or broken tools (if you break a tool, how does one get "back on track"?)! Am I more concerned than need be?
    abuelito
    8 years ago on Introduction
    Hi friends, this project is interesting and can be used for work in low hardness materials, the control program must use shorts codes
    zerocoolzmax
    11 years ago on Introduction
    hi there Russ my name is Robin Anderson , I'm interested in building your cnc router design , but was hoping i could get more information from u about the parts you used if by any chance a parts list . the problem is insouth africa we tend not to get some of these parts and i'd really like to build your model as it seems very sturdy and it has a nice work area . if you could help i'd be very greatful.
    petelynzerocoolzmax
    Hi Robin.
    Have you started to build this table yet?
    I was thing to build something along these line but want to know if you had found all the parts in SA
    Cheers Peter
    jj.inc
    Do you know where to get cheaper ACME screws or did you just spend like 100 bucks each
    hondaman900
    DIY CNC hits mainstream in an O'Reilly Radar tech blog report today. See
    http://radar.oreilly.com/2010/12/diy-fabrication-hits-a-new-pri.html
    69fordf100eagleeyes1963
    Reply 8 years ago on Step 4
    i've seen a similar machine at http://bluumaxcnc.homestead.com/Gantry-Setup.html.
    I so want to build these. time to hit the lottery!!!! come on numbers!!!
    cryophile
    9 years ago on Introduction
    Do you think I could use an Arduino in this project?  $300+ is really rich for me.
    jpablo78
    Great design! I'm working on a small CNC project and I'm taking a couple of ideas from here. I'm making a simplified design for a matter of costs but your work is very inspiring. Here in Argentina the acme threaded rods are pretty expensive, that's a relevant issue when working on a project like this.
    jp
    jpabloATomnisciens.com
    http://www.omnisciens.com
