3D Print a Custom Bike Grips
1,233
19
4
What is up guys, In this instructable I will show you how to make a custom 3d printed bike grips for less than 1 buck.
Supplies:
Step 1: Measurements
- As you can see, my 8 years old bike is not in a very good shape and the thing that annoys me the most are the cold steering wheel pipes that definitelly need something to be put on, so I decided to print my own bike grips with 3d printer.
- So, I firstly measured a diameter of a pipe and started modeling it in a solidworks.
-I also link a solidworks file of my bike grips here: https://goo.gl/5UgBnF
Step 2: Solidworks Modeling
I started by extruding a few milimeters thick cylinder and applyed a decent chamfer on both sides.
Then I use a helix tool to make spiral accross the whole part and cut out a small rectangle throughout the previously created spiral.
After that I use a pattern tool to increase the number of spiral cuts and mirror all that again to achieve a knurl pattern. That was pretty easy right :P ?
So, If I render it on my bike, it will look something like that, which is not that bad if you ask me :P
Last thing to do, is to slice it with simplify 3d, save it on sd card and start printing.
Step 3: Putting Them Back On
- Prints should came out perfectly and the last thing to do is to hammer them on the bike and that is it.
- Luckly, The diameter was just right, so it was a really nice tight fit.
- If you plan to make them for yourself I would suggest printing them a bit bigger, so you could still use some sort of a glue to hold them in place if they will be too lose.
Thank you for reading that instructable. If you have any ideas or suggestions I would love to hear them through the comments below. Also check out a video tutorial if you don't understand anything written above.
Jake
Step 4: Watch a Video
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    4 Discussions
    lomo85
    1 year ago
    Great idea! I will make some for my bike.
    tomatoskins
    1 year ago
    This is great! What did you print your grips with? Is one plastic better than another for this?
    Jakes workshoptomatoskins
    Reply 1 year ago
    Thanks, I used a normal PLA but I guess a flexible filament would be even better :)
    Buso
    1 year ago
    Great job!
