A5 Leather Journal Cover
352
8
It seems all that there is a lot of Journal Covers for the Pocket Size (3.5" x 5.5") or A6 size. Although it is hard to come by a cover for an A5 Journal or Sketch Book. So I decided to make my own.
If you like this project, please vote for it in the Leather Challenge.
Materials
Veg-Tan Leather 3-4 oz.
Contact Cement
Leather Needles
Unwaxed Thread
Leather Die
Template
Tools
Utility Knife
4 mm Leather Stitching Chisel
Ruler
Hammer
Leather Grover
Scratch Awl or nail to make the leather
Supplies:
Step 1: Print Out Template
Print out the Template
Make sure you print it at 100%
Cut out the Shapes
Tape the two cover pieces together to make one piece.
Step 2: Trace and Cut the Shapes
Trace the shapes on the leather using the template
Then using a ruler and the utility knife cut out the shapes.
Step 3: Die the Leather
Die the leather. Where rubber gloves.
I recommend applying the die twice.
Once going the long way and once going the short way
Let it dry. Usually take a few minutes
Step 4: Glue Pockets
Glue one of the pocks to the curved pocket using the Contact Cement. Again I would wear rubber gloves so you don't get it on your fingers.
Then using the Leather Grover grove a link 3/16" around the edge of the piece. And to form the pockets as they are on the template.
Then use the Stitching Chisel to punch holes for stitching using the grove as the guide to make the pockets. You will be using the Stitching Chisel to punch holes around the edge of the whole project in an upcoming step.
Using the Needle and Thread sew the pockets and tie off the Thread behind the piece so the knot does not show. You will need 4x's the amount of thread that the length of the stitch. So if the stitch is to be 3" long your will need 12" of thread.
I used a Saddle Stitch for this. This is a very easy to use stitch and there are a number of videos on the web on how to do a Saddle Stitch. I would recommend that you search this stitch and you will be an expert in just a few seconds.
Step 5: Finishing It All Up
Using the Contact Cement glue the rest of the pieces together.
Using the leather groover, go around the entire piece on both sides. About 3/16 of an inch in
Using the Stitching Chisel, punch holes all the way around the piece.
Then cut a piece of thread 4 times in length the distance is around the entire piece.
Sew the piece together and ENJOY.
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    2 Discussions
