ATtiny85 Robot Insect
1,550
22
The intention is to build an as simple as possible yet beautiful robot insect, and then apply it to their own choice, as a swarm insect or equipped with an IR sensor or color sensor ........
I would like to see two Robot Insects could communicate with each other via IR or Mic and Piezo
Sorry for my bad Englisch
Supplies:
Step 1: 3D Printing
Step 2: Hardware
First I made two prints like the picture
You look from above through the board, if you understand me
The smallest PCB is for Robotic Insect, I do not think there needs explanation
The larger PCB is for programmed via an Arduino Uno, the ATtiny85 The structure I think is easy to understand
The LED that is re-signed, is red and indicates that something is wrong if this fire
For programming I do the following
1 I load in the Arduino Uno the "ArduinoISP" program, which is already in the Arduino Uno see foto1
2 Unplug the USB cable from the Arduino Uno
3 Place the PCB with the 3 LEDs on top of the Arduino Uno, see that there's is an ATtiny85 in the right direction in the PCB
4 Then connect the USB cable back to the Arduino Uno
5 Set my settings to program the ATtiny85 see foto2
6 Take the program "ATtiny85_Robot_Horse.ino"and load it ........
7 Removed the USB cable from the Arduino Uno
8 Take the ATtiny85 from board and place it in the small PCB Robot Insect
9 Turn on the switch of the Robot Insect and then if all is well the Insect start walking
Between ( ) I am not responsible for any misunderstandings or mistake
Sorry if things go wrong
Step 3: Software
Step 4: Assembly
Step 5: Modifications
1 First and foremost, run better and run faster
2 Left turn, right turn and walk back
3 Programming the IR sensor as obstacle avoider or follower
But I have some need help, so if someone feels called to help me is accepted with thanks
Step 6: Video
This is my first test with the robot insects
You can see that the IR sensor is not connected yet, because I still have not found a decent program The walk I find myself a little stiff, maybe with other legs or to change what times in the program would have been better than now ???????
These settings are like on my video
void loop() {
myServo1.write(60); // Move Waist 15 delay 100
delay(250);
myServo2.write(150); // Move Legs 40 delay 150
delay(350);
myServo1.write(120); // 140 delay 100
delay(250);
myServo2.write(30); // 130 delay 150
delay(350);
if (counter >= 10) { // 20
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • Classroom Science Contest
