Accurate 1Hz Generator
2,948
21
About: iam a B.E Electronics and Communication Engineer. I have great interest on electronics.I love my college life.Even though there are many sadness in my life.I find joy in making instructables.
Accurate 1Hz squarewave pulses are required in stopwatches and other digital circuits. Here is a low-cost, general-purpose 1Hz signal generator without using a crystal oscillator.
Step 1: Components Required
Diode
  • 1N4007--------2
Resistor
  • 10KΩ
  • 470Ω
Capacitor
  • 1000μF, 35V
IC
  • CD4017------2
LED
  • RED
TRANSFORMER
  • 9V-0-9V, 500mA
PCB
  • General Purpose PCB
Connectors
  • 2 pin screw terminal -------- 3
Step 2: Schematic Diagram
Explanation of Circuit
Diode
The two diodes D1 and D2 are used to form full wave rectifier.The output of full wave rectifier is pulsating dc.
Capacitor
The capacitor C1 reject the ac signal and allows only DC signal, because the capacitor C1 is connected in parallel.
Capacitor allows AC signal if it is connected in series and blocks DC.Capacitor allows DC and blocks AC if it is connected in parallel.We have connected the capacitor in parallel because the circuit needs to be powered with DC Voltage.
IC CD4017
IC1 which is wired as a divide-by-5 counter via resistor R1. IC1 now produces 10Hz output at its pin 12, which is further given to the clock pin of another IC CD4017 (IC2), wired as a divide-by-10 decade counter. The output of IC2 can be seen as a 1Hz clock pulse on the screen of the oscilloscope and also as one flash per second on LED1 connected in series with the output load (resistor R2).
LED
It is used to indicate the 1Hz Signal by flashing of LED.
Step 3: Assembling the Schematic
I had assembled the circuit in a general purpose PCB according to the schematic diagram.
Step 4: Application
  • It is used to create blinking effect of LED.
  • It is used in many digital circuits like counter,timer,stopwatch,etc.
Step 5: Video
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    2 Discussions
    rafununu
    2 years ago
    This won't work in US where mains frequency is 60Hz. Take care cos all 4017 don't react the same, some of them need a noticable transistion on the clock input (TI I think), I've got this issue to solve in 1983 !
    tytower
    2 years ago
    You should explain that the incoming a/c is at 50 hz divided by 5 gives
    10hz divided by 10 gives 1 cycle per second. the pulse is taken from
    one side only! Thats assuming the powerco keeps it at exactly 50 hz which it rarely does.
