Acrylic Boombox
67,451
238
38
This Boombox was created for my friend with mostly recycled parts. The story is that I owed my friend big time, so I took his old car speakers he wasn’t using and decided to make something useful.
Below is how I had initially thought how it should be constructed. Now with this design, I realized that creating such a shape would be difficult. I even tried with the tools that I had but it failed miserably. I found a local laser engraving shop that would cut my piece for a very minimal fee, so I decided to use them. All they needed was a marked sketch with dimensions, turnaround time was very fast as well. I will likely be using them for my future projects.
*You can view this project as well as many others on my personal blog at www.diy-create.com.
Step 1: Parts Needed
  • Acrylic Sheet (Received via Craigslist) (FREE)
  • (2) Speakers (Received from my friend) (FREE)
  • Amplifier Board (Sure Electronics 15w x 2 Class D Audio Amplifier) (~$15)
  • Used Headphone Cables (My Junk Stash) (FREE)
  • Some Sort of Stand (TV Stand) (FREE)
Step 2: Construction
The shape I had designed came out exactly like I had designed it. As you can see I’m just laying the acrylic sheet against the stand. Seems good to me!
I realized that the speakers, that came from a Honda Civic, has these tabs. These tabs were probably used to fit in the door card of the vehicle. It is not needed in this case.
All Done Here!
Now its time to install them!
In the previous photo you can see I’ve started created construction lines for the stand. On the next photo, I drilled three holes for the stand and now I’m starting to layout amplifier board.
With the amplifier board holes drilled, it is now to time to attach them to the speaker board.
I wanted to integrate an iPod Dock and I spent a great deal of time trying to integrate it to the system. However, it was after the integration to the system that I realized iPod docks disable volume control, therefore the volume needs to be controlled via an external volume knob/potentiometer. Unfortantely, I learned this AFTER  I had integrated the dock into the stand. It was looking really great, but since I had not taken this into my design consideration, I decided to ditch that idea. Here are some pictures of the dock before the idea was ditched. Luckily, I was able to cover the exposed holes on the stand with a Honda Symbol that I got from the junk yard.
Step 3: Finishing
Now its time to reassemble everything and uncover this boom box!! In the latter pictures, I took a Honda Decal and was able to center it so that it covered the exposed holes.
Step 4: Conclusion
The project is done and my friend was very happy with it. I enjoyed this project and really I was blown away by the finish, the laser really helps. If I had to do this again, I would definitely incorporate the iPod dock for sure. With that, I will definitely have to incorporate a volume knob as well. The amplifier is rock solid, it can definitely drive those speakers easily. Also, if there is a version 2, I would probably design something that would sit behind the speakers as a cover, so the speaker can resonate properly. Most speaker enclosure are enclosed, but in this project my objective was to use whatever I had and make it very interesting looking. All in all, I’m very satisfied, here are some great pictures I took.
This was my first project in which I used a third party to cut my pieces. I found that in my past I would waste so much time just cutting the pieces that I would quickly loose interest. A local shop, Custom Engraving and Signs, have two laser cutters that can cut practically anything you can imagine. I was blown away by the accuracy and sharp definition of all my cuts. If I can win the Hurricane Lasers Contest, I want to continue doing what I'm doing now but at a much faster pace. I have so many great ideas just waiting to be designed and implemented. Rather than waiting for the shop to cut my design (which can take 1-2 weeks), I can do it at my own pace. I do believe that winning one of the Hurricane Laser Cutter will help evolve my creativity into an even higher level. Thank you Hurricane Lasers for sponsoring this contest that has inspired me to create such a high quality and memorable gift for my friend.
Links
Sure Electronics 15w x 2 Class D Audio Amplifier – TA2024
Custom Engraving & Signs
DIY-Create --- Acrylic Boombox
And as always, you can view this project as well as many others on my personal blog at www.diy-create.com.
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
38 Discussions
MartijnD
6 years ago on Step 3
Without compression via a closed box you do not get sound < 500Hz, so no bass, and with 15Watt you should be able to get a nice full sound, for next time I would advice to have to layers of plexiglass and add 2 pieces of PVC tube round 5" or bigger 3-5" high, check for best sound, paint the tube, and glue or screw everything together
BrokenMMartijnD
Reply 2 years ago
Acoustic short circuit - That was my first thought...
adleyjoseph
5 years ago on Step 4
Great project but there should be at least a rgb led illuminating on the acrylic
That costs more than free. . . Although, it would be very cool. Might have a better effect if the acrylic was clear, but frost a 1cm ring around the end. Maybe frost it in sections, then have lost of LED's, have a sound-based sensor to have it change colors to the beat.
thisoldgeek
Love the look and the way you reused everything. Great job! Question-I'm doing something similar, but have heavy shielded speakers (4 inch). How thick is your acrylic? I'm afraid my speakers will crack the 1/8 inch acrylic I'm using. May need to go to 1/4 inch. What do you think?
SharadSciencethisoldgeek
Reply 5 years ago on Step 4
If the speakers are thick and heavy then yes you will need thicker acrylic I think mine were not 1/4" thick but close to 3/16". If you are doing something similar keep in mind that this design is more aesthetically appealing. May I suggest adding some sort of enclosure on the back for resonance and bass performance.
tdaly2
6 years ago on Introduction
im new too this but how did you power the board and you think you could explain the board electrics (connect what to what) please if you have time/ thank
Very Cool Idea! Thanks everyone for these comments, looks like I'll have to make a better version of this boombox.
maybe make one with nxt flatpanels speakers ive found several pair at local goodwill i use the Teac flat panels with my mp3 no amplification at night in bed its enough sound but amplification be way bad for mobile boom box application rock your back pack.
billgeo
Nice! I have used those 15W Sure Amps.
They sound great.
How did they perform with those Honda speakers (looks like fullrange units)?
eobermeyer
For Version 2, I'd highly recommend looking into the theory behind H-frame and other open baffle speaker enclosures. The project looks awesome. It'd be great to mate the aesthetics here with the science of acoustics to make a high performing final product!
