Adding a Mounting Point to a Vehicle That Has Nowhere to Tie Down a Canoe or Kayak
46,413
194
22
About: I am a married father of 2 teenage girls, living in Saskatchewan, Canada. Improvising the things I need with free or cheap materials is my favourite way to make things. I love to scavenge parts and keep thi...
Our 2000 Explorer has mostly plastic parts on the front of it. This means there is nowhere to tie the bow of our canoe in place. We found some fairly expensive straps from several companies online but nothing local. It was cheap and easy to make them ourselves. They mount to the fender bolts under the hood and provide a good solid mounting point. In total it cost us about $2-$3 to make and 35 minutes to make and install.
Supplies:
Step 1: Matterials and Tools:
For us, step 1 was giving our very active puppy a big beef bone so he would leave us alone long enough to complete the project!
Materials:
- Nylon webbing. We found a bunch at a surplus store where the charge by weight. it was 67cents for 6 feet.
- Grommet kit. Make sure they are the right size to go under the bolts you want to use. The kit should come with the special tool you need to pound it in.
Tools;
- Hammer
- Sewing Machine and sewing stuff (pins, scissors, ruler, fabric pencil, etc.)
- propane torch or lighter
- wrench that fits the bolts under the hood
Step 2: Cutting and Melting the Webbing
Every vehicle will be different so estimate how much webbing you will need. For our Explorer we used 18 inches. It should be long enough to come out of the hood a reasonable distance. When not in use you will tuck the strap under the hood so don't make it too long. It will end up greasy, interfere with the engine or even melt from the heat of the exhaust manifold. 3-5 inches hanging out of the hood is about right. Make sure you lightly melt the ends of the webbing or they will fray. A torch or a lighter will work fine.
Be safe working with fire!
Step 3: Plan Your Stitching
Fold the strap in half and pick your location for the grommet. It should be centered on the strap near the two ends but not too close. Mark the area with a fabric pencil (or a Sharpie if you don't mind it staining the straps). Avoid sewing where the grommet will be. It can weaken the stitching later when we cut or burn a hole in the straps later.
Step 4: Sewing
Fortunately my wife is pretty good with a sewing machine. She stitched several times back and forth in a box around the area of the future grommet. There is going to be a lot of strain on the seams closest to the tips so don't skimp.
Step 5: Melting the Hole
The grommet kit might say to pound the tool into the fabric to create the hole but this won't work with 2 layers of tough webbing. I marked the area and melted a hole the size of the center of the grommet. The best tool for this would be a soldering iron or wood-burning set. I just heated a nail with the torch and melted a hole. This is dangerous and should be done very carefully.
You are going to be holding the webbing, the pliers and HOT BURNING PROPANE FIRE! Be safe!
You might have to trim some melted bits with scissors to make a clean hole.
Step 6: Inserting the Grommet
If this is your first time putting in a grommet, practice on some scraps first. The instructions in the kit suggested you do and it was good advice. My first one wasn't so great. I got better with practice.
Step 7: Setting the Grommet
Read the instructions that came with the grommet kit. Read them twice. The advice to tap gently is very important. Tap straight down, too. If you aren't 90 degrees to the washer it will deform.
The last photo is of the 2 strap loops finished.
Step 8: Installing on the Vehicle
Choose a bolt that is free of moving parts and away from any road spray. The front fender bolt is a good choice, though there may be some frame bolts on your vehicle. Put the bolt through the grommet and put it back into the fender. Be aware that some bolts under the hood will have a torque specification so make sure you check. Bad things can happen if you don't, like "we are about to die screaming" kinds of things.
Close the hood and give it a good tug test. They should be solid and not stretch or warp your hood or fender.
Throw on your canoe and head to the lake!
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    22 Discussions
    laxgeo
    2 years ago
    glad to see someone did a write up on this! its a life and paint saver ;)
    9w2xyz
    2 years ago
    Simply brilliant. Thank you very much.
    andyboy
    2 years ago
    Great idea! I made a bunch (6) tonight. I bought stand up paddle boards and a simple roof rack this weekend. This will make putting the boards on the car(s) much easier and better. Even if a car has tie down points they are likely under the car and require straps ropes to go over paint and plastic body parts. This should avoid most if not all of that. I have to look and see if I can use this on the trunk of a sedan. The straps with the grommets came out so nice I will probably use that idea for a bunch of other stuff.
    Suggestion: I read this last week and had a hard time re-finding it. I finally found it searching on "car fender strap kayak". My suggestion is to somehow use the keywords "car roof rack strap" because that returns the car top carriers, etc. that could really use this idea.
    WaiyeeL
    2 years ago
    Great idea! Thank you! Now I just need a kayak...
    MattD7WaiyeeL
    Reply 2 years ago
    This build was featured recently: https://www.instructables.com/id/Sawfish-foam-kayak-build-a-funtional-light-wieght-/
    MrExcitementMattD7
    Reply 2 years ago
    Thanks for sharing this. I know what I'm doing this winter!
    MrExcitementMattD7
    Reply 2 years ago
    Really cool idea. Might tackle this as a winter project.
    WaiyeeLMattD7
    Reply 2 years ago
    Thank you very much MattD7! That looks like a doable kayak project.
    txadams
    2 years ago
    File this under, "Duh, why didn't I think of this?". Thanks
    MrExcitementtxadams
    Reply 2 years ago
    Lol. That's what i thought when i found the Thule ones on Amazon.
    chrwei
    2 years ago
    the stitching and grommet give this a nice professional look, but aren't really necessary. I just put the fender bolt through the hot-nailed hole and that's it, it's a tight fit and gives more bolt to strap surface for holding power than using a grommet, which easily offsets the losses from stitching. I've had mine on for 2 years now and they still look as good as when I added them.
    in either case, always inspect your straps before each use!
    MrExcitementchrwei
    Reply 2 years ago
    That would work and I considered it when I saw how thick the melted area was.
    dhaykus0418
    2 years ago
    Very cool, might give this a try myself. You probably could also use old seat belt material.
    MrExcitementdhaykus0418
    Reply 2 years ago
    That would work for sure. Might be cool if you had the seat belt clasp attached to both the canoe and the fender. After a paddle just click it together and tighten it like a lap belt!
    AllJacksMrExcitement
    Reply 2 years ago
    Hmm,a cunning plan is forming in my head (said Baldrick).
    I have a couple of old VW T3 seatbelts in my garage. :-)
    Uncle Kudzu
    2 years ago
    Excellent idea! Thanks for sharing this!
    EliteB40
    2 years ago
    Easy peasy! Could you add a phoyo with the kayak on the truck?
    Mrballeng
    2 years ago
    This was helpful. Great pictures!
