Adult Storm Trooper Costume
297,918
404
35
About: I eat food, sometimes I'm funny.
In this how to I will show you to create a adult storm trooper costume using leftover cardboard boxes, Fiberglass cloth, resin and paint.
Other resources which were invaluable can be found here.
http://www.studiocreations.com/howto/stormtrooper/index.html
this is my first instructable be kind.
Supplies:
Step 1: Research.
The Storm trooper costume is a classic, I had always wanted to purchase a suit for myself, but since they can cost in the thousands of dollars for a quality replica I opted to make mine on the cheap.
I started with research. Couple of sources which were paramount and I think tipped the scale in finishing a difficult project like this.
This first link provides detailed measurements of all pieces which create this costume.  They deserved a shout out.
https://www.instructables.com/id/Kids-Stormtrooper-Costume/
The second which is by the author HIREROB details a childs version of the costume.
Step 2: Materials and Tools
MATS.
Cardboard - as much as you can get.
Fiberglass Resin - about 1 1/2 gallons.
Fiberglass Cloth - about 4 packs
Fiberglass all purpose filler.  1 can
Bottle of contact cement.
Box of 5/8s drywall screws
white spray paint.
Painters tape. - 3 rolls. Blue or tan.
white Electrical tape - roll
Cheap throwaway grade paint brushes. - for use with Resin
Velcro
White zip ties. - Not red. X)
Nine cents in pennies.
Tools.
Metal snips.
Sharpie marker
Razor / utility knife.
Extra blades.
Other items
Black sweats
Black jersey gloves
Black turtle neck shirt.
Cement boots from homedepot
Lots of time.
One patient friend about 6 feet tall.
Other safety items which could be included.  A paint respirator, some Nitrile or Latex gloves, and Safety glasses.
Step 3: Creating the Card Board Forums.
I have only included basic paper templates which I had scribbled into a notebook, I exploded these into full size pieces after taking detailed measurements of my body. After exploding these onto my cardboard each piece was hand rolled with the corrugations, this left my cardboard blanks flexible and in the basic contours of my body. Symmetry isn't really my forte so be kind and use your imaginations when cutting and creating your own templates.
And yes I spelled pieces wrong on purpose :P.
Step 4: Applying the Fiberglass
After bending your pieces to the correct shape, use screws, pins and tape to keep the basic body curves.  Once you apply your fiber Glass cloth and resin you can remove these binding materials.
On the shin guards and forearms. I created them in one piece and ended up cutting them in half.
The pictures below are the left and right Forearms.
Now this was a helpful I found that after fiber glassing the outer parts the surface was left extremely stippled.  I overcame this by applying a layer of painters tape over my fiber cloth after it dried, then laying another layer of resin. which left me with a passably smooth surface.
Step 5: Creating Costume Details.
This was one of the hardest parts.
If you take the time to view the studio creations website there is a number of intricate details which these armors have that goes missing under the pass of the movie camera.
Like any cardboard work project the details again were added using cardboard.
The chest piece, knee, Groin, and shoulders and belt are just stacks of layered cardboard, cut to appropriate size using a utility knife. Then using painter I like the exposed edge which hid all the corrugation and applied my final layer of fiberglass resin.
These layers were glued together using contact cement, and Alex plus white caulk as a filler for joints.
For any details that required ribbing I simply peeled away the first layer of cardboard and exposed the corrugation.
Step 6: Sticking the Whole Project Together.
Now Alot of my friends asked HOW the firetrucks was I suppose to get this to stick to my body.....  Simple using multiple contact points and industrial strength Velcro.  each part interconnected using small strips of Velcro painted white to match the costume.
Most of the costume bulk is support by the abdomen plating, and chest and back plates.  Pieces such as the thighs were supported through large velcro pads attached to the belt,  which in turn was connected to the abdomen via Velcro strips.
Parts such as the shin guards, and forearms supported themselves
Step 7: Final Results.
The final results were something that was a little rougher then I was happy with. so the close up scrutiny of the costume came with a great deal of criticism.  at about 10 feet the imagery was impressive and as you can see the pictures look pretty bad-ass.
If anyone has any questions feel free to post.
  • Woodworking Contest
    Woodworking Contest
  • Fandom Contest
    Fandom Contest
35 Discussions
itsmeandu11
1 year ago
Yea, great job! I was just curious, how much did you pay for all of the supplies?
YaelT2
2 years ago
Now, im started mine clone
!!! you are my inspo!
IsaacB49
2 years ago
Would paper mache work as someting to make it sturdy
NakedS1
3 years ago
Where did you get the helmet?
SpidermanHero124
3 years ago
how much is the total cost of you costume?
Stickman939
3 years ago
I've a couple questions.
First off, how do I measure out my body for the parts
And is the resin absolutely required, or is there a cheaper alternative to it? (Cause I don't want to put too much money into something that might flop)
TheGreatCoonStickman939
Reply 3 years ago
I didn't use Resin when I put mine together I just formed cardboard to the shape that I wanted and super glued it all then I spray painted it and it worked fairly well obviously it only lasted for the day I needed it too it could have lasted longer if I hadn't chosen to tear it off but resin would be great for making it look more realistic like the movies
TheGreatCoon
3 years ago
So I made a Suit out of Cardboard for the new movie it wasn't Beautiful but it worked for the night and still turned a few heads I used this as a great tool to reference for building it and it only took me about 2 days to do what I did have anyways I am building a better one over the next few weeks for Great Lakes Comic con and this will be used again thanks for posting this I really appreciate it
BoromirO
3 years ago
This is awesome! I'll probably use this same techniques when I start to make a Cyberman costume!
THANK YOU SO MUCH FOR SHOWING EVERYONE HOW TO MAKE THIS =D
StephenYellow00
4 years ago
This looks great. I will end up making something similar when I stop growing.
nickwrdlw
4 years ago on Introduction
I started to make this same thing. I covered my cardboard in wide strip scotch tape pretty much. If I cover this with bondo will the bondo stick to it? and if not can I get the bondo to come off in one piece, like a mold pretty much??
Running Wolf
Thanks for posting this. I saw some guys at the zoo (Zoo Boo @ the Erie Zoo) last year with some Clone Trooper Costumes.
I might do a few things differently but you have a really good concept that makes it easy even for an idiot like me to make something this awesome.
Darth Caius
6 years ago on Introduction
Dude you've done a great job the only thing is im to young to use fibre glass could i use something else
nof-z
if you are using fiber glass and you want it smoother, just sand it down, and if you reach the base, just apply more resin.
jiangpanda
If you do this and it doesnt look too good, just scuff it up and make it look dirty and say it was a battle.
craftsmithjiangpanda
Reply 6 years ago on Introduction
either that or add an orange pauldren, really scuff up and dirty and claim you are a sand trooper........
