Mini Robot DIY Android Bluetooth 4.0 Remote Control
5,103
93
About: i like diy,this site is so great!
this is a simple robot project
here are some Features:
1.Andriod apk
2.bluetooth 4.0 moudle
3.AVR attiny13 MCU(9600 baud rate communication with the bluetooth moudle)
My plan is use the Andriod phone send the command,it is like "A"(0x41),"B"(0x42),"C"..........,then the bluetooth get this code,Transfer to the AT13,AT13 decode the command,like
if(A)then TURN LEFT
if(B)then TURN RIGHT
if(C)..........
so the robot can move.......
i think the hard parts is write an apk run on andriod,maybe also a little hard write a 9600baud rate communicate
program of the AT13,but Practice makes perfect,right?it just take some time
the point of the apk,is getting the characteristicof the bluetooth4.0,it is like a door in a building,so i have to handle some array,one dimensional array,Two dimensional array......... but after fix them all,See the dawn
Supplies:
Step 1: Use Hc164 Extension IO
the Attiny13 has 5 IO,but one for RST,another for the Bluetooth moudle,only three left,so i use a HC164,it Occupy 2 IO,but turn 8 IO
Step 2: LED,IC Socket and the Power Socket
LED Positive pole figure
Step 3: Program Upload Socket
this is for upload program on the AT13,Six holes for VCC GND MOSI MISO SCK RST
Step 4: Battery
Colorful heat shrinkable tube,Hot air heating with electric hair dryer
i havs some Metal decorative adhesive,i choose the Iron Man,because my robot is called "T_man"
Step 5: First Test
first put the AT13 in the socket,Please note that "1" position
then power on ,the Fifth led is on,that means it is ok
Step 6: Motor Drive Board
L9110
Bending Led foot like picture,Resistance in the middle, 100 ohm
Step 7: Welding the Wire on the Mother Board
VCC GND L1`L2 R1 R2
(L1`L2 R1 R2) are four single to control the motor Positive inversion
Step 8: Chassis Assembly
Glue!!!!!!!!
the mother board I use hot melt adhesive,In order to avoid the glue temperature is too high, melt the wire, I will wait for it to cool a little
the motor drive board is not glue yet,just for Determine how long wires stay
Step 9: Connect the Motor Driver and the Mother Board
Six wire to the right place
then glue the motor driver on the front like picture,be careful that the Solder joint do not touch the metal of the motor,because it will short circuit,i just give more glue,so it can Separate them
At last,welding the four wire of the motor,do not care about the positive and negative,if not right,after welding the bluetooth moudle,we can adjust
Step 10: Bluetooth Moudle Welding
P03 is the TX
the Metal strip connection to VCC,better to bend to the right shape,then welding to the pad of VCC on the mother board,but need be careful the back ,beacuse we alreading welding the VCC wire of motor driver on it
GND pad is the middle one
TX is bottom
the led connect the 100ohm is Status indicator ,when your phone connect success to the bluetooth moudle,it will light on
Step 11: Second Test
run the apk on the phone
click the "Search" button,if all the welding is right,the phone can show the robot name on the list of the software interface,one robot,two robot,three.............
click the robot which you want control,then click “Load“ button,the software will open the door of the robot's world
so you can click the Left,Right,Front,Back
Sleep is for the robot Standby
this is just test
if all ok,next step we install the wheels
Step 12:
Step 13: Wheels
wheels like picture
battery glue on the back
so the robot finished
Let's celebrate.
Step 14: FINISHED
the robot finished
Enjoy~
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    2 Discussions
    JayWeeks
    2 years ago
    This is cute and compact and elegant! I love it!
    GalaxyUser
    2 years ago
    saying sh** is inappropriate
