Another DIY Vacuum Former
92,584
721
17
About: A materials scientist gone electrical engineer my hobbies include experimenting with electronics and making fun and interesting things. I rarely know what I'm doing when I start a project, but learning new s...
I know I'm certainly not the first person to make their own vacuum forming table, and I know I won't be the last. But since I am making one I thought I would share it anyway.
This is a pretty standard design. I have a wooden frame to hold the material to be vacuum formed, and a wooden box with holes on the top to act as the vacuum forming bed. It was cheap to build and works really well.
Supplies:
Step 1: Design and Supplies
My goal was to create a simple and cheap vacuum former. I knew the sheets of material I would be forming would be 12in x 12in and so I would design the vacuum former around that . I came up with this design that follows similarly to many other DIY vacuum formers out there.
Design
A base board would have a hole in it for a household vacuum hose. A small frame would be built in the center of that measuring 11in x 11in. It would be glued to the base and then later sealed with caulk. A square section of pegboard would be glued to the top of that frame and act as the bed for the vacuum former. Separately, two frames made of MDF would sandwich the material to be vacuum formed and those would be held together with bolts. Some sort of rubber tape would run around the perimeter of the frame to form a vacuum seal. This frame with the material in it would go into the oven to heat the plastic and then be placed over the bed to form the part.
Parts
 I bought the following parts from Home Depot for this project:
  • 1x2-8ft Strip: $0.98
  • White Peg Board Panel: $8.45
  • 3/8"-16 Wingnut (3 bags): $3.54
  • Hex Bolt, 3/8x2-1/2 (8x): $2.96
  • Foam Tape: $5.67
  • 1/2" 2'x4' MDF Project Panel: $9.73
The following are extra parts that I used to make the table a little more user friendly and had lying around:
  • 1x4-8ft Common Board: $4.12
  • 3/4 PVC Pipe: $1.23
  • 3/4 90º PVC Elbow: ~$1
The total cost before tax of this vacuum form system is about $38.
Tools
You'll need basic wood working tools for this one: a miter saw, circular saw, and a power drill. Wood glue is a must and caulking is optional but recommended. I found a Dremel was just fine to do the job of cutting the center out of the frames, but any method you prefer will work too. You may also want some type of square to make sure those corners are 90 degrees.
Step 2: Cut the Wood
For the table you'll need to cut the following to size:
  • 1x2 Strip cut into 4 pieces with 45º  miter joints on either side, 11in on the longest side
  • Pegboard cut to an 11inx11in panel
  • MDF cut into 3 18inx18in sheets, one will be used for the base, the other two for the frames
See the drawings for a visual.
Step 3: Assemble the Base
Building the base is straightforward- the hardest part being centering the 1x2 frame on the base board. I recommend marking the center of the base board with chalk or a marker to aid in centering the frame and the hole for the hose.
I used a large square with inch markings on it help both center the frame and the make sure it was square. Once satisfied with the placement, glue the 2x1 frame pieces in place and allow the glue to dry. While drying the center hole can be drilled. Since I was using PVC pipe I found a hole saw of that size and used it to cut the hole. At this point caulking can be applied to fill any gaps that may cause air leaks.
Once any caulking is dried, place glue all the around the 1x2 frame. A continuous line of glue will help prevent any unwanted air gaps as caulking around the pegboard would be difficult. Finally, place the pegboard on the frame and allow the glue to dry.
Step 4: Cut the Two Frames
Now take the other two 18inx18in MDF panels an cut a square out of the center. The square should be around 11inx11in but note that it may need to be slightly larger in order to fit around the 1x2 frame on the base. I used a Dremel for this, but any method will do. After the center squares are cut out I stacked the two panels on top of each other and drilled holes around the perimeter. The holes are about 1in off the outside edge and 5in off of each side. See the drawing for a visual.
Step 5: Add Final Touches
Here are some extra steps I took to make the unit a little more user friendly. These are optional and you could just hook up your vacuum's hose directly to the base if you want.
The first modification was to add the plumbing. I coated the short piece of PVC pipe with adhesive/caulking and placed it in the hole on the bottom of the base. I then put another piece of PVC pipe that went to the outside of the base so I could easily connect the vacuum.
Next I added some legs to raise the platform a little bit and clear the PVC pipe. These are just scrap wood I had that I glued to the base board.
Lastly, I put some foam rubber weather stripping around the perimeter of the 1x2 frame for some extra sealing.
Step 6: Using the Vacuum Former
I built this vacuum former in order to make an enclosure for another project I'm working on. That's what you see in the images.
I sourced my ABS plastic from Widget Works Unlimited. I found that they had very reasonable prices on material meant for vacuum forming. There's also a video on their product page that will show you essentially the same thing that I will here.
First, sandwich the material to be formed between the two MDF frames. I found it easiest to loosen all the nuts but only remove two bolts on the same side and slide the material in. Tight down all the nuts. Place the base somewhere close to the oven and connect your vacuum. Any vacuum will do. Place your mold on top of the peg board. Heat your oven and then load the entire frame assembly into your oven.
Ok, I know what you're thinking: "I'm not going to put that in my oven, it'll get ruined!" And believe me my parents weren't thrilled about it at first either, but as long as you keep the temperature set to the forming point of the material and use materials that don't tend to outgas at low temperatures you should be fine.
For the ABS I used, the forming temperature was 325-350F, I went with 340F. After a few minutes (depending on the thickness) you'll see the material start to sag in the frame. That's how you'll know it's ready to be formed. Turn on the vacuum and quickly move the frame assembly from the oven to the vacuum table and slide it down over the part. Be sure to use oven mits, it'll be hot! The vacuum should suck the material close to the mold and the pegboard. Wait about 30 seconds or until your material hardens and then remove the vacuum.
If you're part didn't quite form right you may not have heated the material long enough or your part may be too tall for the material to stretch around. It took me a couple of tried to get it right. Also, depending on the intricacies of your mold you may need to prep it a certain way. A quick web search should return all the information you should need. I'm not an expert and my only experience is making simple parts.
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    17 Discussions
    mark.tuttle
    2 years ago
    Question:
    In your instructions you say to purchase:
    and then cut that into 3 18" x 18" panels. That doesn't work. You can't get three panels that size out of a 2'x4' piece. What am I missing here?
    wood doctor
    2 years ago
    very cleaver and easy to understand
    J-rex
    3 years ago
    Could I use a heat gun to melt the plastic?
    Novali
    5 years ago on Introduction
    this is great!
    I want to use this in a classroom situation to teach kids about vacuum forming, No oven in my classroom so I'll try scaling it down to toaster oven size. Do you think a small hand held dustbuster type thing would work?
    cmonaco3Novali
    Reply 5 years ago on Introduction
    Thanks, I'm glad you like it. Check out this video: http://www.youtube.com/watch?v=maH5Ech0wK8 The person in it made box to heat the plastic with a space heater; maybe something like that could help you out. I'm not sure about the vacuum, you may just have to try it out.
    RyErickson11
    If the material doesn't completely wrap around the mold or doesn't follow all the contours, try drilling some holes in key or detailed locations that would aid the vaccum to suck the material to the mold. Using a sort of wax to coatr the mold also helps the material release the mold when completed. It also gives a bit of life to the mold as well. This would make it possible to make more detailed/complex forms. Just a few tips! Great project.
    Great looking box. Easy to follow using your diagram. And oh so timely, as I was just starting to look to make one this weekend.
    BTW OP, nice shirt. PKS 1997 Sigma Chapter.
    aspen42
    When you update will you please also show us what you are using for the heat source and anything we need to know about that? Thanks!
    bertus52x11
    Ver well and clear Instructable! Just two questions: what kind of vacuum pump do you use and at which pressure do you operate it?
    cmonaco3bertus52x11
    Thanks! I'll be updating the instructable this evening with a step detailing the how to actually use the former, but to answer your question in the mean time: a household upright vacuum cleaner and I have no idea. haha
    cmonaco3SlickSqueegie
    I actually realized this morning that I left out the step about actually operating the thing. I'll be updating it today with instructions and pictures on the actual use of the vacuum former. But to answer your question any household vacuum should work. I'm just using an old upright vacuum cleaner I had at home.
    kristell1119
    great instructable! easy to fallow and great direction. no mumbo jumbo. good job
    Lovely tidy instructable, looks like just the thing I'm looking for to finish a project I'm working on, thanks!
