Anti-theft Kayak Cable
63,747
34
25
About: When I was a boy, I was amazed how my grandfather could make flotsam and jetsam into useful things. I am proud that I have inherited some of his skill.
The day I bought my first kayak, I had to make several stops on the way home and I realized there was nothing to stop a miscreant from taking it off the roof of my Explorer. After my first paddle, I immediately set out to make it theft resistant.
Supplies:
Step 1:
I had an idea was that a vinyl clad steel clad cable would be ideal for securing the kayak. This left me with two questions to answer: How do I connect the cable to the kayak, and how to I secure the cable to something?
I looked my kayak over, and then took a look at other models and decided that all kayaks are divided into two groups: those with something permanent to connect the cable to and those without.
My first kayak was a Perception Swifty; the seat was molded out of the same piece of plastic that the hull was. A cable wrapped around the seat support in that type vessel (or through the hull, as would be the case with a sit-on-top) cannot be removed without tearing up the boat or cutting the cable. If you have ever tried it, you know how hard that is.
Step 2:
The other kind of kayak or canoe is manufactured with no way to connect the cable permanently. I later purchased a second kayak, an Old Town Loon, and in that vessel the seat mounts to an aluminum rail that is bolted through the plastic hull. Anyone with pliers and a screwdriver can easily unbolt the seat and remove the security cable, so that is not the way we want to approach that situation.
Step 3:
Forget cabling the kayak for a moment. What can we connect the cable to that will hold the kayak securely and keep if from being stolen? Very simply, your vehicle. And we will do it by closing the two ends of the cable in one of the vehicle's doors. Provided there is something that keeps the cable from being pulled through the door opening, the only way the thief will get the cable out is to break the glass and unlock the door. A thief is most likely not planning on making a lot of noise or attracting attention, and as an opportunist, may not be equipped with anything to break the glass with.
Let's begin our Instructable and I will tell you why we do what we do as we go.
Step 4:
First, buy some vinyl clad aircraft cable. You can get this at your neighborhood hardware store. I would get the 1/8" size; it has a working load of about 340 pounds, so nobody's going to break it. With the vinyl coating, it is about 3/16" in diameter, and will easily close in a car door without hurting anything. You will need about fifteen feet; if you buy more of it, you can get a firsthand illustration of just how hard it is to cut.
Second, get two 3/4" PVC pipecaps and some JB Weld. Drill two holes near the sides of the end of each cap, just slightly bigger than the cable. Take one end of the cable and run in in to the open end of a cap, make a loop, and run it back through the second hole. Adjust the cable end so it is not protruding past the end of the cap. Do the same for the other cap, fill them both with JB Weld and let them cure. What you then have is a piece of cable with a knob on each end that will keep somebody from pulling it through the door opening.
Actually, you are done with the cable part of the Instructable unless you want to dip the ends in Plasti Dip rubber tool handle coating to make it look more professional.
Step 5:
Say for the sake of argument that you have a craft like my Swifty. Make it fast to the roof of your vehicle, or throw it in the bed of your pickup, then run one end of the security cable through the seat mount and out. Close both loose ends in the vehicles door and lock it. Your Swifty will be right there when you come back. Couldn't be any simpler.
If you have the other type of kayak, there is a chance you already have a metal security connector on your craft. This may take the shape of a U with both ends connected to the deck, or else a flat plate connected over a depression in the deck. If you don't have one like that, you need to visit your local boating supply store and buy a stainless steel pad eye, a couple of stainless Phillips-head bolts and nylon insert nuts, and a pair of stainless washers. Mount the pad eye on the rear deck near the cockpit, tighten the bolts, and strip the bolt head by drilling it out. ( We don't want somebody with a screwdriver and a pair of pliers removing the nuts.)
Step 6:
Using the pad eye involves a slight trick, since obviously you won't be able to get the PVC cap through it. All you have to do is make a hairpin in the cable about a foot from the end and pass that through the pad eye. Then, pass the other end through the hairpin, pull it tight, and close it in the door.
Now you can take your kayak on vacation with you, or on a weekend paddle, and worry less about it going home with somebody else.
NOTE: I have had comments that perhaps someone could cut the cable and steal the boat. True, they could. But I assume that every potential thief isn't walking down the street with bolt cutters, or even wire cutters. Even if they are, cutting aircraft cable is tough as a rule and it takes time, which is something they will likely shy away from. Try it yourself with a pair of wire cutters and see how hard it is. Lastly, you can make the cable size a little larger to make it harder to cut, if you want.
I can't guarantee it is a perfect solution but so far, nobody has ever told me they made one and had their kayak stolen.
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    25 Discussions
    framakers
    4 years ago on Step 6
    Warning on your cable-trick: that knot can be untied, even if the end of the cable is firmly attached (e.g. to your car door)!
    NB: I appreciate the instructable. I am only posting this, because I would hate for your (or anyone else reading this) canoe being stolen.
    RangerJframakers
    Reply 3 years ago on Step 6
    Take another look; the big end won't go through the pad eye. Nothing is theft proof, tho. Just make it harder on them.
    framakersRangerJ
    Reply 3 years ago
    Yes, I can see the end cap does not fit through the eye. This is hard to explain in words, but I'll give it a try:
    The rope goes through the eye twice, grab both ends on the side of the end cap (on the right side of the eye in the picture). Now pull them both (to the right as seen on the foto), and pull the loop through the eye completely. Now, another part of the rope will end up through the eye, leaving a (new) loop. Pass the end cap through this loop and the kayak is free from the rope.
    NB: This is a trick that also solves some rope-puzzles.
    I see a solution too: the end cap already has got a tiny (and closed) loop on one end. If you make this loop a bit bigger and leave it open, you can use it to attach the rope to the eye with a padlock. It would be even better, if the eye can't be undone by unscrewing it.
    kgaddyframakers
    Reply 10 months ago
    I get exactly what you are saying on both how to quickly and easily “undo” the first step that attaches the cable to the kayak. In addition to the solution to keep it from being “undone” in the first place. Good thinking!
    kgaddykgaddy
    Reply 10 months ago
    Oops just noticed your illustration below. Lol! Great job on it too! Lol
    RangerJframakers
    Reply 1 year ago
    Nope ☺ the other end is locked in the vehicle.
    framakersRangerJ
    Reply 1 year ago
    Please see fotos.
    At the same time, your instructable is not intended to be completely theft proof. It is valid as a cheap and easy way to protect a kajak from disappearing all to easy, e.g. it still sends a clear message that it's not an abandoned kayak, but one the owner will return for.
    turbobug
    2 years ago
    What is stopping the theif from unscrewing the screws on the on the security thingy. They make one way screws that don't come out and or carriage bolts. nice try may friend has a strip kayak that she uses three bike cables and two trees I didn't try but I didn't think her solution wouldn'y do more that slow someone down either but that's all it takes sometimes.
    RangerJturbobug
    Reply 1 year ago
    Once the bolts are installed, you use a drill bit to strip the head; a do it yourself security bolt.
    DaveB13
    5 years ago on Step 3
    I like it. If I were to do it I would drill two holes in the end of the cap. Run the wire up the inside and back inside to form a loop, maybe strip off the plastic of the portions of wire to be buried in the JB weld. Would look a little more finished and leave a loop to run the entire cable through and have the option of padlocking the end to something. Longer, cheaper, and lighter than what is usualy available for a security cable without the swaging equipment, and good enough to stop casual theft. Personaly I 'd prefer what looks like a security cable to be a giant snare powered by a old garage door spring, but that would be the rural model.
    RangerJDaveB13
    Reply 5 years ago on Step 3
    Or maybe a giant mousetrap...
    Thanks for the kind words, and you got the point - enough to stop a casual thief.
    RangerJSchmidty16
    Reply 6 years ago on Introduction
    My first kayak was a Perception Swifty 3.1 meter kayak. I bought it from a local outfitter. I liked it, and used to throw it in the pickup and take it all kinds of places, but it was too little for me. My brother said I looked like I was paddling a decoy.
    mrbill5834
    7 years ago on Step 4
    This is just what I'm looking for. Thanks for the instructions and clear pictures. What type of JB WELD product did you use?
    RangerJmrbill5834
    Reply 7 years ago on Step 4
    Thanks! I hope it works out for you.
    As for the JB weld, it was the regular kind with one tube with black lettering and the other with red.
    mrbill5834RangerJ
    RangerJ,
    Thanks for your reply. I'm going to start my kayak theft prevention project this morning.
    dr_insane
    7 years ago on Introduction
    You will need something much stronger than that cable, my friend had his locked up with that stuff, and guess what? It was stolen. You need a motorbike lock/chain, or anyone with a pair of bolt cutters will be able to steal it in a few seconds. But the way you attach it to the kayak is great.
    eg_colon73
    I own a 15'sit on top fishing kayak and my friends and I use a Bell Sports KEVLAR Bike Locks. Just past them thru the holes on the yak and lock it to the rack on top of your SUVor the utility holes on the bed of truck.This locks come on different length and they are super strong! Very hard to cup, trust me!! I lost the keys ones and want easy to cut them.
