Arduino 3D Printed Can Robot (one More Object Avoiding Robot) ​
11,199
149
14
In this "how to" guide I will show you how to make your own 3D printed Can Robot with the Arduino UNO micro-controller.
This is a remake of the Attiny Canbot that I found at Thingiverse.com by Wingman94 (link here) .
I made my own circuit with ATmega328 IC and I add a buzzer to make a beep tone every time that robot finds an object in front of it. I didn't include the IR remote control function.
This little robot is powered by one 3.7V 500mAh rechargeable battery and can be charged from the builtin charging circuit .
Watch my little robot in action:
Project page - future updates can be found here.
Let's get started!
Supplies:
Step 1: What You Will Need - Hardware
For this project you will need:
  • Atmega328 (with Arduino UNO bootloader)
  • 28 dip socket
  • 16 MHz crystal oscillator
  • 2x22 pF capacitors
  • 10 kOhm resistor
  • 2 continuous rotation servo FS90R
  • HC-SR04 ultrasonic sensor
  • Buzzer
  • 3.7V 500mAh rechargeable battery
  • Charging circuit
  • On/Off micro switch
  • PCB prototype board
*You will also need a TTL to USB module or an Arduino UNO board for the programming procedure.
Tools: You will need a soldering iron and hot melt glue gun and of course a 3D printer.
Step 2: The Circuit
Take your time and make your circuit as small as you can so it can fit inside the can robot.
Step 3: The Code
Connect your circuit with TTL to USB module (or Arduino uno board - note - remove ATmega328) with 5 cables to the programming header. The pins RX and TX must be cross-connected. You can change the speed of your small robot by changing the "speedS=10" variable - line 14.
Download the code from this step and open it with Arduino IDE. Inside you will also find all necessary libraries.
Step 4: 3D Printing Files
Here you will find the 3D files, download them from the official project page.
I would advice you to use support at your 3D printing procedure.
Step 5: Finally...
It's time to use your hot melt glue gun, watch the above images for reference.
That's it!
I hope you liked this, let me know in the comments!
I would also like to see some photos with your new 3d printed robot!
Sensors Contest 2017
Second Prize in the
  • Arduino Contest 2019
  • Party Challenge
    Party Challenge
14 Discussions
LoganRodriguez
1 year ago
what size PCB prototype board do i need
ROBO HUB
2 years ago
mini robot that avoids obstacles..great instructable..
HeritierB
2 years ago
Hey !!
Is it possible to pilot it ? With Android or an Iphone ?
I think it's an great idea to try !
Nice work !
Ardumotive_comHeritierB
Reply 2 years ago
Hello, it is possible to add a bluetooth module, but it must be placed outside of main body.
PabloP22
2 years ago
GREAT !! But i tried to build my own and i can't , because the code don't open , can you upload another or send me by email (pa.echauri19@gmail.com)
Ardumotive_comPabloP22
Reply 2 years ago
Hello, if you can open the .zip file, you can copy-paste the code from this link into your Arduino IDE.
http://www.ardumotive.com/can-robot-en.html
