Arduino Based Humanoid Robot Using Servo Motors
43,874
146
49
Hello everyone,
This is my first humanoid robot, made by PVC foam sheet. It is available in various thickness. Here, I used 0.5mm. At now this robot can just walk when I switched ON. Now I'm working on connecting Arduino and Mobile through Bluetooth module. I have already done an App like Cortana and Siri for windows phone which is available in app store https://www.microsoft.com/en-us/store/apps/patrick... After Successfully connecting both, I can control it through voice command in Windows Phone.
I've spent many months in solving the battery over weight problem and ended with an epic fail due to budget problem. So, finally I decided to give power from external Lead-Acid Battery.
Lets see how I figured out the perfect design of the body for the robot.
Supplies:
Step 1: Trials and Errors on Designing the Model
At first I have no idea about the power of Servo motors and Electronics-Electricals that deals with batteries and circuits. I first planned for a life size robot for about 5 to 6 feet. After trying almost 6 or 7 times I realized the maximum torque of a servo and reduced upto 2 to 3 feet of total height of the robot.
I then tried upto hip of the robot to check the walking algorithm.
Step 2: Designing the Model and Algorithm
Before moving on we need to decide how many motors needed, where we need to fix. Then design the body parts according to the images given.
Step 3: Components Required
1) Plastic sheet
2) Super Glue
3) 15 - High torque Servo motors ( I used TowerPro MG995 )
4) Arduino Atmega 2560 or other Arduino boards
5) 6V Battery (minimum 3 nos. Atmost 5 motors for each battery)
6) HC-05 Bluetooth module for communication
7) Other basic stuffs which every hobbyist have!
Step 4: Building the Body
After struggling with wooden pieces I found this plastic sheet pretty easy to cut and paste to make various shapes.
I cut holes to fit servo motors directly into the sheet by applying super glue (I used 743).
Step 5: Wiring
I'm not studying an electronics or electrical major. And I have not enough patience to design a PCB or designing proper wiring. That's why this messy wiring.
Step 6: Increasing Power
You can see that I used only 11 servo motors at first. due to over weight problem, It fell down and broken during testing. So, I increased 4 more servos at each joins of legs.
Step 7: Coding
I've attached Arduino code.
for(i=0;i<180;i++)
servo.write(i);
This is the basic code for rotate any servo motor attached to any Arduino board.
But calibrating the rotating degrees and deciding which motors should run during the movement of each leg is the most tricky part of coding. It can be done by another Sketch called (Servo_Test). By testing the degree of rotation of each motors through serial communication through Arduino board, we can calibrate every motors.
Finally, the robot begins to walk after entering the value "0" in serial monitor window.
I have also included a sample windows phone 8.1 sample source code for connecting Arduino and Mobile using bluetooth.
  • Woodworking Contest
    Woodworking Contest
  • Fandom Contest
    Fandom Contest
49 Discussions
unglaublich
3 months ago
well, you have done very well, the "errors"/problems were more of a budget problem,
you used: TowerPro MG995 which has approx cost between 7 to 20$...for the size you have
now will work as you have proved it, but for a 5/6 feet ...for the hip to the feet, you will need
4 servos with 180kg/cm...and these total cost approx. 400$, and 2 rds3135 (for rotation at
the hip ) and these are also cheap...so save some $ and do not give up...and enjoy!!!
BlackStar Vvekunglaublich
Reply 3 months ago
well thank you. Yes I'm aware of that and I'm now trying with 3D printed light-weighted but stronger parts with custom built linear actuators using steppers in some places and servos in other places.
unglaublichBlackStar Vvek
Reply 3 months ago
all the best to you, and if you are planning to use 3d printer for body parts, you
might want to consider using nylon/carbon-pla...but try to avoid abs for health
reasons...with steppers and/or actuators...you might end up terrying your hair
out because of the programming hahaha...again all the best to you..
Ccit
4 months ago
Hello sir
I want to ask about the servo motor that you are using. The type is whether the servo type rotates 360 degrees or 180 degrees. Please help me, with my email: ccit.micro@gmail.com
Thanks.
akshaybodhi
1 year ago
sir please send circuit diagram and coding of robot to my e-mail akshaybodhi15@gmail.com sir please send body part coding and leg walking coding please send on my e-mail sir please
AmulS
1 year ago
I tried this robot myself and i face some problems?
1. how you manage robot balancing problem after putting battery as battery is so heavy?
2.what are the ratings of battery used, and how many battery need for below hip portion?
3.how you provide power to servo motor? directly via battery or via Arduino pin (VIN/VCC)?
please reply asap, my mail id - sharmaamul01@gmail.com
akshaybodhiAmulS
Reply 1 year ago
akshaybodhi
Question 1 year ago on Step 7
akshaybodhi
Question 1 year ago on Step 5
sir i am making a robot so please tell me the circuit diagram and the coding which you have made sir please send sir please on my g-mail akshaybodhi15@gmail.com
JaydenY1
Is it possible we could see a diagram of the wiring (sorry for necroposting)
f.altamura.07
1 year ago
Wiring Please i need it Please!!!
shreyansh1115
2 years ago
please provide connection diagram
shreyansh1115
2 years ago
please add me on whatsapp 8585990755 please its a request
SaiP45
2 years ago
hey... u hav done with the hardware work... can u plzz send the arduino bluetooth cmplt coding for the above nd app to be used to control it....patric app is not available now.... any simmilar app
BlackStar VvekSaiP45
Reply 2 years ago
try this for bluetooth com
https://bluetoothmgrwp81.codeplex.com/documentation
ShaikhG1
2 years ago
Awsome thing! A small doubt about the position of servo motors in the code "Julie_2.0". Can't figure out which motor corresponds to which position.
