Arduino Internet Time Client
96,748
89
43
About: Professionally, I'm an IT Engineer (Executive Level) and Electronics Tech. I'm a Amateur Radio Operator (KK4HFJ). I lived off grid, with Solar (PV), Wind, and veggie oil fueled diesel generator power for 6 y...
UPDATE! 11/15/2015
Added a WiFi and rechargeable battery option (step 10).
UPDATE!
Added 12h/24h switch and Standard / Daylight Savings Time Switch! See steps 7 & 8.
Have you ever wanted a clock that kept accurate time to a official time source? There are official time servers on the internet that you can attach to and sync your time. Most people have their computers set up to do this, now the Arduino can as well. (For GPS Time Client, see http://arduinotronics.blogspot.com/2014/03/gps-on-lcd.html and for a standalone DS1307 clock, see http://arduinotronics.blogspot.com/2014/03/the-arduino-lcd-clock.html)
All you need is an Arduino and a Ethernet shield, but we will be adding a LCD display as well. We may add alarm clock functions later.
Arduino UNO
Arduino Ethernet Shield
Optional:
I2C LCD Display
Step 1: Connecting the Hardware
First, write down the MAC address printed on the bottom of your ethernet shield. You will need it for the next step.
It looks something like 90 A2 DA 00 23 36 but will get inserted into the code as 0x90, 0xA2, 0xDA, 0x00, 0x23, 0x36
Plug the Ethernet Shield on top of the Arduino UNO. Connect it to your internet router with a Ethernet cable.
Step 2: Code
Only one additional library needs to be installed into your Arduino libraries folder. That is the Time Library available at http://www.pjrc.com/teensy/td_libs_Time.html
You will need the mac address from the bottom of your Ethernet Shield, but IP, Gateway and Subnet mask are all obtained throgh DHCP. You will also need the time server address (see next step)
The code that needs to be uploaded to your Arduino is as follows:
//sample code originated at http://www.openreefs.com/ntpServer
//modified by Steve Spence, http://arduinotronics.blogspot.com
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Time.h>
/* ******** Ethernet Card Settings ******** */
// Set this to your Ethernet Card Mac Address
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x23, 0x36 };
/* ******** NTP Server Settings ******** */
/* us.pool.ntp.org NTP server
   (Set to your time server of choice) */
IPAddress timeServer(216, 23, 247, 62);
/* Set this to the offset (in seconds) to your local time
   This example is GMT - 4 */
const long timeZoneOffset = -14400L;
/* Syncs to NTP server every 15 seconds for testing,
   set to 1 hour or more to be reasonable */
unsigned int ntpSyncTime = 3600;
/* ALTER THESE VARIABLES AT YOUR OWN RISK */
// local port to listen for UDP packets
unsigned int localPort = 8888;
// NTP time stamp is in the first 48 bytes of the message
const int NTP_PACKET_SIZE= 48;
// Buffer to hold incoming and outgoing packets
byte packetBuffer[NTP_PACKET_SIZE];
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
// Keeps track of how long ago we updated the NTP server
unsigned long ntpLastUpdate = 0;
// Check last time clock displayed (Not in Production)
time_t prevDisplay = 0;
void setup() {
   Serial.begin(9600);
   // Ethernet shield and NTP setup
   int i = 0;
   int DHCP = 0;
   DHCP = Ethernet.begin(mac);
   //Try to get dhcp settings 30 times before giving up
   while( DHCP == 0 && i < 30){
     delay(1000);
     i++;
   if(!DHCP){
    Serial.println("DHCP FAILED");
     for(;;); //Infinite loop because DHCP Failed
   Serial.println("DHCP Success");
   //Try to get the date and time
   int trys=0;
   while(!getTimeAndDate() && trys<10) {
     trys++;
// Do not alter this function, it is used by the system
int getTimeAndDate() {
   int flag=0;
   Udp.begin(localPort);
   sendNTPpacket(timeServer);
   delay(1000);
   if (Udp.parsePacket()){
     Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
     unsigned long highWord, lowWord, epoch;
     highWord = word(packetBuffer[40], packetBuffer[41]);
     lowWord = word(packetBuffer[42], packetBuffer[43]);
     epoch = highWord << 16 | lowWord;
     epoch = epoch - 2208988800 + timeZoneOffset;
     flag=1;
     setTime(epoch);
     ntpLastUpdate = now();
   return flag;
unsigned long sendNTPpacket(IPAddress& address)
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  packetBuffer[0] = 0b11100011;
  packetBuffer[1] = 0;
  packetBuffer[2] = 6;
  packetBuffer[3] = 0xEC;
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  Udp.beginPacket(address, 123);
  Udp.write(packetBuffer,NTP_PACKET_SIZE);
  Udp.endPacket();
// Clock display of the time and date (Basic)
void clockDisplay(){
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
  Serial.println();
// Utility function for clock display: prints preceding colon and leading 0
void printDigits(int digits){
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
// This is where all the magic happens...
void loop() {
    // Update the time via NTP server as often as the time you set at the top
    if(now()-ntpLastUpdate > ntpSyncTime) {
      int trys=0;
      while(!getTimeAndDate() && trys<10){
        trys++;
      if(trys<10){
        Serial.println("ntp server update success");
      else{
        Serial.println("ntp server update failed");
    // Display the time if it has changed by more than a second.
    if( now() != prevDisplay){
      prevDisplay = now();
      clockDisplay();
Step 3: Time Server Address
If you know the IP address of a working time server, enter it into your code.
Look for this section of your code:
Otherwise, run this sketch to get a valid time server ip. If you really want to get techy, merge the following code into the main sketch so that it finds a valid time server on every update. Don't forget to update your MAC address below.
  DHCP-based IP printer
This sketch uses the DHCP extensions to the Ethernet library
to get an IP address via DHCP and print the address obtained.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 12 April 2011
by Tom Igoe
#include <SPI.h>
#include <Dns.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
void setup() {
  // start the serial library:
  Serial.begin(9600);
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)
  // print your local IP address:
  Serial.print("My IP address: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.print(Ethernet.localIP()[thisByte], DEC);
    Serial.print(".");
  Serial.println();
  IPAddress testIP;
  DNSClient dns;
  dns.begin(Ethernet.dnsServerIP());
  dns.getHostByName("pool.ntp.org",testIP);
  Serial.print("NTP IP from the pool: ");
  Serial.println(testIP);
void loop() {
Step 4: Time Offsets
You need to plug in your time offset for your time zone. As I am currently on East Coast Day Light Savings Time, I used -14400, which is the number of seconds off GMT. Here is a chart to help you determine your offset:
http://www.epochconverter.com/epoch/timezones.php
L
ook for this section in the code:
Step 5: Is It Working?
At this point, with the hardware connected (UNO and Ethernet Shield), and plugged into your router, with your MAC address and time server address plugged in (and of course uploaded to the Arduino), you should see something similar to the following:
Step 6: Adding the LCD
If you are using the Serial LCD Display, connect it now. There is an additional library you will need, the I2C LCD library. You can find that at http://arduinotronics.blogspot.com/2014/02/sainsmart-i2c-lcd.html
LCD       Arduino UNO
SCL        A5
SDA       A4
VCC       +5v
GND       Gnd
The preceding NTP code with the LCD additions are below:
#include <SPI.h>
#include <Time.h>
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h>
//LCD Settings
#define I2C_ADDR    0x3F // <<----- Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
EthernetUDP Udp;
void setup() {
   lcd.begin (16,2);
   lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
   lcd.setBacklight(HIGH);
   Serial.begin(9600);
   int i = 0;
   int DHCP = 0;
     delay(1000);
     i++;
   if(!DHCP){
   int trys=0;
     trys++;
   int flag=0;
   delay(1000);
     flag=1;
     setTime(epoch);
   return flag;
  Udp.endPacket();
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.println();
 lcd.setCursor (0,0);
  if (hour() < 10){
    lcd.print("0"); }
  if (hour() > 12){
    lcd.print("0");
    lcd.print(hour()-12); } else {
    lcd.print(hour()); }
    lcd.print(":");
  if (minute() < 10){
    lcd.print("0"); }
    lcd.print(minute());
    lcd.print(":");
  if (second() < 10){
    lcd.print("0"); }
    lcd.print(second());
   if (hour() > 12){
    lcd.print(" PM"); }
    else {
    lcd.print(" AM"); }
  lcd.setCursor (0,1);
  if (month() < 10){
   lcd.print("0"); }
   lcd.print(month());
   lcd.print("/");
  if (day() < 10){
   lcd.print("0"); }
   lcd.print(day());
   lcd.print("/");
   lcd.print(year());
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
void loop() {
      int trys=0;
        trys++;
      if(trys<10){
      else{
      clockDisplay();
Step 7: 12h Vs. 24h Time
Originally I built this sketch for 24h time, so 1pm actually displayed as 13. Many folks prefer a 12h clock, with AM/PM, so I modified the final sketch for that instead. Now I'm having second thoughts, so I'm adding a switch to choose which format you prefer to see.
First, we need to read a switch to determine the format, then we need to switch some code based on the results of that read.
We will use pin 5 for the switch, as the Ethernet Shield itself uses pins 4, 10, 11, 12, & 13.
Connect a switch between pin 5 and ground. You don't need a pullup resistor, as we will use the one built into the arduino using the INPUT_PULLUP command.
Here is the affected code as it currently stands:
if (hour() < 10){
lcd.print("0"); }
if (hour() > 12){
lcd.print("0");
lcd.print(":");
if (minute() < 10){
lcd.print("0"); }
lcd.print(":");
if (second() < 10){
lcd.print("0"); }
if (hour() > 12){
lcd.print(" PM"); }
else {
lcd.print(" AM"); }
Here is how the new code with the option of switching back and forth would look like:
//12h_24h (at top of sketch before void setup
int timeFormatPin = 5; // switch connected to digital pin 5
int timeFormatVal= 0; // variable to store the read value
//put in void setup replaceing the original code listed above
if (hour() < 10){
lcd.print("0"); }
//12h/24h
pinMode(timeFormatPin, INPUT_PULLUP); // sets the digital pin 5 as input and activates pull up resistor
timeFormatVal= digitalRead(timeFormatPin); // read the input pin
if (timeFormatVal == 1) {
if (hour() < 10){
lcd.print("0");}
lcd.print(hour());
} else {
if (hour() > 12){
if (hour()-12 < 10){
lcd.print("0");}
lcd.print(":");
if (minute() < 10){
lcd.print("0"); }
lcd.print(":");
if (second() < 10){
lcd.print("0"); }
if (timeFormatVal == 1){
lcd.print(" 24");
} else {
if (hour() > 12){
lcd.print(" PM"); }
else {
lcd.print(" AM"); }
Step 8: Standard Vs. Daylight Savings Time
Originally I built this sketch for my current time, and we are on Daylight Savings time, which is GMT -4. When we switch back to Standard time (GMT -5), the clock code would have to be edited and re uploaded, so lets add a switch to eliminate that headache.
We will use pin 6 for the switch, as the Ethernet Shield itself uses pins 4, 10, 11, 12, & 13.
Connect a switch between pin 6 and ground. You don't need a pullup resistor, as we will use the one built into the arduino using the INPUT_PULLUP command.
To make this work, you need to RESET or power cycle your Arduino between changes, as the switch code is not in void loop.
change to /* Set this to the offset (in seconds) to your local time
long timeZoneOffset;
add this before void setup:
//DST Switch
int dstPin = 6;   // switch connected to digital pin 5
int dstVal= 0;     // variable to store the read value
and change out the whole int getTimeAndDate() function with the code below:
   // Time zone switch
  pinMode(dstPin, INPUT_PULLUP);      // sets the digital pin 6 as input and activates pull up resistor
  dstVal= digitalRead(dstPin);   // read the input pin
  if (dstVal == 1) {
   } else {
   timeZoneOffset = -18000L;
   int flag=0;
   delay(1000);
     flag=1;
     setTime(epoch);
   return flag;
Step 9: Future Upgrades
Upgrades I'm contemplating are:
  • An automatic function for finding a available time server
  • Auto switching of Daylight Savings Time
  • Alalrm Clock functions with a audible alarm, gradually brightening light, and / or relays.
  • RTC for power failure with no network startup
What Would you add?
Step 10: WiFi Rechargeable Version
This version of the Internet Clock uses WiFi instead of Ethernet, and an onboard rechargeable Lithium Ion Battery. There is a power switch that turns the clock off, and it resync's time with the internet on powerup. It notifies you when the battery is low with a led, and just plug in a USB cable to recharge.
Adafruit RGB I2C LCD Display
Adafruit Powerboost Lipo Shield
Arduino WiFi Shield (retired, there is a newer version out)
Arduino UNO
Code and Libraries
    • Trash to Treasure
      Trash to Treasure
    • Pie Contest
      Pie Contest
    • Tape Contest
      Tape Contest
    43 Discussions
    Ajay34
    Question 2 months ago on Step 2
    Error: setTime() not defined
    ayeshar13
    1 year ago
    i used your code to get time using internet servers but i am getting a time in 1970. i am not getting the present time. please suggest a way to get this done.
    Alkemist_SEayeshar13
    Reply 1 year ago
    Are you getting a time close to midnight, 1 January 1970? The answer from the NTP server is the number of seconds since the life of Unix began which is pegged as midnight, 1 January 1970. If your time server is not answering then you get a result of 0 seconds which puts you back in the good old days :) Try using pool.ntp.org as the time server or a demo of a local <a href="http://www.bytefusion.com/products/ntm/pts/whatispresentenseserver.htm">time server</a>.
    Sandesh_SP
    2 years ago
    thanks for the reply. Now I'm trying it with Arduino UNO with wifi shield and LED, so that it maybe better visible. Do you by anyways have code for displaying time in LED.
    Sandesh_SP
    2 years ago
    I'm trying the wifi code(provided at the end, which is in drive) using Intel Galileo Gen2 board, Is this code compatible with this board. Actually it shows error when I tried to run the code in Arduino IDE using Intel Galileo board. If you have any code to call the internet time and run it using builtin RTC in Intel Galileo please reply. Thanks in advance.
    sspenceSandesh_SP
    Reply 2 years ago
    I've never used a Galileo, but I'm sure my code won't work on it without modifications. This was designed for a Arduino UNO.
    Tedi SopyanI
    2 years ago
    Arduino: 1.8.1 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
    C:\Users\DEVELOPER\Documents\Arduino\sketch_jan31b\sketch_jan31b.ino: In function 'int getTimeAndDate()':
    sketch_jan31b:78: error: 'setTime' was not declared in this scope
    setTime(epoch);
    sketch_jan31b:79: error: 'now' was not declared in this scope
    C:\Users\DEVELOPER\Documents\Arduino\sketch_jan31b\sketch_jan31b.ino: In function 'void clockDisplay()':
    sketch_jan31b:103: error: 'hour' was not declared in this scope
    sketch_jan31b:104: error: 'minute' was not declared in this scope
    sketch_jan31b:105: error: 'second' was not declared in this scope
    sketch_jan31b:107: error: 'day' was not declared in this scope
    sketch_jan31b:109: error: 'month' was not declared in this scope
    sketch_jan31b:111: error: 'year' was not declared in this scope
    C:\Users\DEVELOPER\Documents\Arduino\sketch_jan31b\sketch_jan31b.ino: In function 'void loop()':
    sketch_jan31b:126: error: 'now' was not declared in this scope
    sketch_jan31b:140: error: 'now' was not declared in this scope
    exit status 1
    This report would have more information with
    "Show verbose output during compilation"
    option enabled in File -> Preferences.
    sspenceTedi SopyanI
    Reply 2 years ago
    did you load the Time library? "Time Library available at http://www.pjrc.com/teensy/td_libs_Time.html"
    GeeksTipsDotCom
    2 years ago
    Nice resource. For those who are not using Ethernet shields but instead WiFi Arduino compatible modules to access the NTP Server, I recommend the following material:
    Arduino ESP8266 NTP Client
    james.bowen2
    2 years ago
    I was unable to compile the code as it was unable to find a whole set up date and time functions.
    To fix it I had to change:
    #include <Time.h>
    to
    #include <TimeLib.h>
    I Think this change is required as of version 1.6.10 build of Arduino
    Thumperup
    2 years ago
    Great job, it worked great for me. Now to edit it and add it to the sketch i'm working on.
    VaughanJ
    2 years ago
    How would i use a 7 segment display to show just time?
    Dustin TR
    2 years ago
    I love what you've done! You sharing this code is greatly appreciated. If I could figure out how to make it use the gateway IP as the NTP server by default I'd be set. Any ideas?
    sspenceDustin TR
    Reply 2 years ago
    if your default gateway is running a ntp server, just set the ip of the ntp server the same as your gateway.
    sspenceDustin TR
    Reply 2 years ago
    Daddy_M
    3 years ago
    Very nice project, is it possible to do this with a ESP8266 instead of a Arduino Wifi shield ?
    sspenceDaddy_M
    Reply 3 years ago
    I'm sure it can be done. I look forward to seeing your instructable.
    Daddy_Msspence
    Reply 3 years ago
    Me too ;-)
    Wished I had the knowledge for it, I dont speak ESP8266 ;-(
    I'm reading about the ESP, but at this moment it's still Latin for me
    GavrielRDaddy_M
    Reply 3 years ago
    I just purchased the ESP8266 and noticed your comment, I want to do the exact same thing, but wasn't able to use the ESP8266 so far, have you done this?
