Arduino Pixel Stick WS2812
32,227
202
38
This is my first instructable I got asked to put one togther for a friend but only after I had assembled it all so some pics i wasnt able to get Im sure there will be bits I have missed out I'm no code genius so I will do my best to answer any questions you have in this build there was a bit of guess work but that is the fun of it.
I will update this as much as I can if anyone spots anything missing please let me know :)
This is my variation on NeoPixel WS2812 DLW by Michael Ross Credit to Him and IS0-Mick for the code and others who contributed to code along the way.
Link to : http://mrossphoto.com/wordpress32/neopixel-ws2812-...
https://www.facebook.com/spicyturtlesphotography
Test run of completed strip :
I have some early videos of it in the concept stage here:
Another one of testing :
Step 1: Step 1 : Parts Tools
I got most of my parts from Aliexpress and Ebay to keep costs down
Parts:
Arduino Mega
AD Keypad http://bit.ly/1L4eGWH
WS2812 144px/m http://bit.ly/1CutXyK
SD Reader http://bit.ly/1Gd4d4A
LCD 16x2 http://bit.ly/1LX1N1j
Momentary Push Button http://bit.ly/1Mlo86U
Switch On/Off
1m Alloy Channel With Diffuser http://www.ecolocityled.com/product/black-thin-fro...
Du Pont Wires http://bit.ly/1NZW36e
12v-5v converter http://bit.ly/1HTQntx
Project Box http://bit.ly/1M0K7D9
Double Sided tape
1m piece of wood as wide as alloy channel for mounting
9v battery connector with DC jack end
Wire - Try to keep size same
Handle http://bit.ly/1NZWSMb
Heat shrink Tube
Nuts & Bolts
Resistors ( a good Selection for contrasting LCD and one 470 for LED data line )
1 12v battery
Tools:
Soldering Iron
Tweezers
Screwdrivers
Dremmel
File
Step 2: LCD and SD Card Hook Up
I breadboard everything before starting you can skip this step if your confident with lcd hook up etc
LCD:
Pin Guide
1 - GroundPin
2 - +5VPin
3 - Contrast AdjustmentPin
4 - H/L Register SelectPin
5 - H/L Read/WritePin
6 - H/L EnablePin
11 - DB4Pin
12 - DB5Pin
13 - DB6Pin
14 - DB7
15 - Backlight Control +
16 - Backlight Control GND
LCD Connection
Pin 1 to GND Pin
2 to 5VPin
3 to Resistor ( bit of trial and error to find right one )
4 to Arduino pin 12
Pin 5 to GND Pin
6 to Arduino pin 11
Pin 11 to Arduino pin 5
Pin 12 to pin 4
Pin 13 to pin 3
Pin 14 to pin 2
Pin 15 to Arduino Pin 10 ( This is for backlight control )
Pin 16 to Arduino GND
I ended up joining the 3 GND's into one pin solder them togther and heathrink tube over top
SD Card :
GND to GND
5v to 5v
CS to Arduino pin 53
MOSI to Arduino pin 51
SCK to Arduino pin 52
MISO to Arduino pin 50
Momentary Push button :
GND - Pin 44
Positive - Pin 45
LED:
LED Strip Data in needs a 470 resistor inline this is talked about in step 5
LED Data In - Arduino Pin 31
Step 3: AD Keypad
Wiring :
5v to Arduino pin 5v
GND to Arduino pin GND
Signal to Arduino pin A0
I ran the Resistor Button Sketch to get the button press values
1. Sketch load
2. Open Serial Monitor
3. Press each button to get the value write these down for later to add into the code.
Video Of it in action
Step 4: Boxing Time
1. Mount the the AD keypad in the middle of the top of the project box I held it down with nuts and bolts and adjusted them so the buttons just sit under flush, cut slot for the sd card ( this doesnt have to be here) . See Pic 1 & 2
2. Cut hole for LCD using a dremmel or sharp knife drill holes for nut and bolt to secure it. See Pic 3
3. Drill hole for momentary push button ( doesnt have to be on the box wherever is good for yourself ) Attach wires before mounting add another hole for the On off Switch and 1 more on the bottom for the DC panel mount jack . See Pic 4
4. Mount : SD Card, Arduino Mega, 12v to 5v converter I used double sided tape and mounted the Mega on the side of the box next to the SD card. See Pic 4
5. Wire everything up I ran the DC jack Positive to the switch then to the converter and the Ground strait to the Ground on the converter the arduino gets its power from the 12v input.
Notes:
I used a 9v battery lead with DC connector for Arduino just chopped of the battery terminal
You can use a buck converter but the led strip can draw a lot of amp when under full load
Step 5: Putting It All Togther
I started by drilling holes in the project box to attach to the wood using short grabber screws 2 should be fine
I then drilled a bigger hole in the box for the wires for the LED to come through ( See Pic 1 )
I channled out the wood enough so the hole in the project box matched the channel for the wires to sit in ( see Pic 2 I dont have a pic of the actual channel )
I drilled 3 holes to mount the channel to the wood I countersunk them so the led strip will sit level ( no pics sorry)
at one end of the channel i drilled out a big hole were the wire feeds into the channel in the wood to go to the box ( see pic 3 ) you will have to solder some more wire to make it long enough this is a good time to solder in a 470 resistor on the data line the green wire from the strip.
The Green Data line from the strip will go to pin 31 ( You can Change this in the code )
Attach your LED power wires to the 5v output of the converte
Note : I had to shorten the led strip by 2 pixels to fit in the channel
Step 6: Code
The code is included here in the Light wand.ino
You will need to edit line 84 int adc_key_val[5] ={ 30, 170, 390, 600, }; these are the numbers from the resistor sketch you will need to put them in to replace the ones in bold above. but there is a trick to this the buttons dont seem to read in order so I had to swap them round this is the combination that worked for me ( 142, 329, 0, 506, ) I only use 4 of the 5 buttons as the Momentary pushbutton works as the 5th button.
You will need to change this line as well: #73 LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
to this: LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
Upload the sketch and see if everything is all go
If not check you wiring make sure all plugs are in the right socket
Note: make sure you have the AD keypad plugged in or you menu will go on a loop through
Step 7: Misc Photos and Acknowledgments
Once again a big thank you to Michael Ross for his guide on this and the code he did all the hard work
Thanks to Joinerman James for the help figuring it all out
And to My Wonderful Girlfriend for putting up with the late nites and swearing
Step 8: Notes : Just a Couple of Notes
1. On LED strip I had to cut 2 pixels off the strip to fit in the alloy channel so make sure in the code you change the number of pixels to suit.
2. Setting up the pictures you can use photo shop or if you want to batch convert there is also irfanview. You will need to set the longest edge to 142 pixel ( Or how many LEDS you have ) and rotate the image I have included a couple of samples above.
3. I plan on doing a 2m one down the track this project can be used for 2m but the power draw will get up there so maybe look at a higher amp converter and adjust the strip- length in the code.
6 People Made This Project!
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
38 Discussions
KDLaun
17 days ago
I recently doubled the length of my display stick to 288 pixels. I did get twice the resolution, but I have found, like moggymad1, that the playback is EXTREMELY slow, even with the frame delay set at zero. (the flag takes about 35 seconds to play through) As a result, you have to move VERY slowly, and it's hard to hold the stick steady while doing it.
I'm seeing a lot of vertical lines in the photos where I didn't with the 144 pixel version. The speed issue may be a limitation of the Mega. I was excited to add more pixels, but right now, I'm inclined to return to my smaller display. Maybe someone can come up with a modernized version with a bit more punch. :-)
moggymad1
2 months ago
Great project!, Thanks. I made one and it works nice but I have a question. How can I increase the speed that it displays the frames? With the frame delay set to zero I have to move the wand very slowly to get an image to look right. But apart from the speed issue I am loving what I can do with it.
Sylvain2
Question 10 months ago on Step 8
Hello,
i try to upload in arduino but this message appear, :
Arduino : 1.8.5 (Windows 8.1), Carte : "Arduino/Genuino Uno"
FPVJP4KIBW26AZI:760: error: 'prog_uchar' does not name a type
PROGMEM prog_uchar gammaTable[] = {
In file included from D:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
from sketch\FPVJP4KIBW26AZI.ino.cpp:1:
C:\Users\sylvain\AppData\Local\Temp\FPVJP4KIBW26AZI\FPVJP4KIBW26AZI.ino: In function 'byte gamma(byte)':
FPVJP4KIBW26AZI:781: error: 'gammaTable' was not declared in this scope
return pgm_read_byte(&gammaTable[x]);
exit status 1
can you help me, thank you
KDLaunSylvain2
Answer 2 months ago
I did a little digging, and apparently there's been some changes in the way the compiler handles variable names since the original code was produced. I changed the offending line and it compiled correctly using IDE 1.8.8. Hope that's helpful.
const PROGMEM unsigned char gammaTable[] = {
DARKHOURSSylvain2
Answer 3 months ago
I found i had to use Arduino:1.0.5 R2 to upload had the same errors with Arduino : 1.8.5
SamerS27
2 months ago
really thanks i try to make it but have erorr with code i wish u can help me
CrazeUK
Question 9 months ago
Hey.
Why did you choose the arduino mega instead of the Arduino Uno or Arduino Nano?
And will this make a difference?
slyac3
Question 9 months ago on Step 8
Do you think this would work with teensy3.6 and apa102c
mdeore
Question 1 year ago on Step 8
Hello!
I am facing a problem in probably the last step of this instructable! I built the wand succesfully but I am not able to light up the strip due to some reason! I am pretty sure the connections are alright since I was able to run the example code for the WS2812 strip and the strip works just fine with this setup but loading the images it simply doesn't work.
I am using a 32gb memory card along with MS Paint to convert it to Bitmaps of width 144 pixels and the files are displayed on the screen but the led strip simply won't turn on! I also tried using the images in this instructables after converting them to Bitmap ofc but still no luck!
Can you probably mail me a sample file so I know that maybe I am making a wrong file?
1 answer
indrajitbhatmdeore
Answer 1 year ago
I was facing similar issue and spent couple of hours troubleshooting. Problem was with GND. We need to connect LED strip GND to Arduino GND. I connected both GND common and everything stared working... may be this is one of the reason in your case.
indrajitbhat
Tip 1 year ago
As a power source for this project mobile power bank can be used. It gives 5V output.. hence perfect to power Arduino board as well as LED strip. (Use power bank with 2 USB outputs) - I used 20000 mAh power bank and it worked perfectly.
indrajitbhat
1 year ago
Thank you so much. I was able to build this PixelStick by following this tutorial.
I used 1 meter 144 LED ws2813 LED strip and 2813 worked just fine without any code change. As a power source I used mobile power bank of 20000 mAh capacity - which has 2 USB outputs; 1 used to power Arduino mega board and 2nd used to power the LED strip.
Attached is the first test shot.... tried to light paint Monalisa
243514225
1 year ago
I have tried this method, but there is a problem for interrupting me ,the sd card can not recognized the bmp files, and the LCD print that " not a bitmap", i do not know why,who can tell me?
coelho69
1 year ago
Good Morning
Great project, many congratulations.
How does the movement?
Is it circular or horizontal?
Manual or with the aid of some mechanical "Motor" system?
thank you
Spicy Turtlescoelho69
Reply 1 year ago
Its all manual hold it vertical and walk it can take awhile to get the right speed
coelho69Spicy Turtles
Reply 1 year ago
OK, it's a very interesting project, I walk with the idea of building a panel but this one will take many LED's and this is a better solution.
I'll start by creating something smaller, rotating or somehow attempting horizontal but mechanical movement.
Good work.
Thank you
MarcelloB
2 years ago
Hello where can I submit source code? I have added some features to the firmware that I would like to share. I have added in a way for settings to be saved and recalled using the EEPROM. I have also made some changes to the analog button reading code that helps deal with anomalies where a buttons value floats slightly.
andreasP47MarcelloB
Reply 2 years ago
could you send me a copy of the changed code
please.
happy new year
TonyM56
2 years ago
Amazing! I'm thinking for building one myself! So what power consumption do you get from the led strip and the whole system? Thank you for the instructable!
thomerow
2 years ago
Nice work! I'm looking into building a Pixelstick-clone myself and stumbled upon your instructable while doing some research. Is there a reason your gamma table only goes up to 127? As far as I know the WS2812 LEDs use 8 bits per color channel.
