Arduino Reed Switch
57,786
42
8
Hello everyone!
The Reed devices are electronic or electromechanical components that work using the technology of the reed contacts, realized for the first time by the Bell.
The Reed contact switch is a lamina (normally open) which closes in the presence of a magnetic field.
The reed contacts have found use in the production of various types of sensors. There are two modes of use of these contacts:
simple pure contacts, for the detection of a magnetic field; complex equipment, in which the reed contact is used as the transduction element. In this guide I'll show you how to use this switch to turn on an LED.
Step 1: The Circuit
We will need:
- Arduino Uno
- Breadboard (base)
- Wires for links
- Reed Switch
- A resistor 10KOhm
- A resistor 220ohm
- An LED
Once procured components assemble the circuit:
Step 2: The Sketch
Now we can load the sketch on our board.
const int pinSwitch = 12; //Pin Reed
const int pinLed = 9; //Pin LED
int StatoSwitch = 0;
void setup()
pinMode(pinLed, OUTPUT); //Imposto i PIN
pinMode(pinSwitch, INPUT);
void loop()
StatoSwitch = digitalRead(pinSwitch); //Leggo il valore del Reed
if (StatoSwitch == HIGH)
digitalWrite(pinLed, HIGH);
else
digitalWrite(pinLed, LOW);
Step 3: Video
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    8 Discussions
    FlorianE3
    2 years ago
    Is there any particular reason why you're not using the internal pull-up resistors of the Arduino and just use the switch as the connection to ground?
    edcalles
    2 years ago
    Why does it works backwards to me? If I don't approximate a magnet, the led is on, and if I approximate a magnet, the led is off.
