Arduino Segway
125,717
737
34
Hello!
More than 3 years ago I started to tinker a homemade segway. Though it's still not really finished (I have to replace the 250W Motors by 500W-models) my children are able to drive around.
If you're going to build one you will Need the following parts:
* wheelset: In my case I use 12 1/2 x 2.75 tires usually taken for dirt bikes (f.e. www.amazon.de/HMParts-REIFEN-MIT-SCHLAUCH-12/dp/B0038X9ODA; http://www.ebay.com/itm/Tire-Rear-Wheel-Mini-Pocket-Dirt-Bike-47cc-49cc-50cc-COOLSTER-QG-50-RX1-Traxxis-/182346539856?hash=item2a74b36350:g:BxUAAOSwh6xTtmwX&vxp=mtr)
* batteries: I use two 12V/12Ah lead accumulators to get 24V for the Motors
* Motors: At the moment two 24V/250W models but the 500W-motors are already waiting for their use
* for the axle I asked a local welder and some of my bicycle-parts (bar, stem) fit perfect too.
Step 1: The Motor Driver
First I tried a homemade full-bridge. To control it I used the analog-out (pwm) of the arduino. But with this variant I didn't succeed. Therefore I bought a commercial product, a 2x60A Motor Driver from sabertooth (www.dimensionengineering.com/products/sabertooth2x60).
The arduino is able to communicate with the sabertooth via a simplified serial code.
Step 2: The Angle Determination
To determinate the current angle I first used a separate accelerometer (ADXL335) and gyroscope (LY530AL). Last week I changed this Setup and the two boards have been replaced by the MPU6050.sensor, which combines the two elements.
The advantage of the gyroscope is, that accelerations don't influence the measurements. The disadvantage is, that the gyro has a drift and after a while the angle goes higher and higher.
The Advantage of the accelerometer is, that it doesn't show any drift like the gyro. But it's being influenced by accelerations, which change the Output.
A filter combines both pro's so the calculated angle is near the real value. This filter can be a simple complementary-filter (like in the Picture) or the more complicated kalman-filter. The Input of the kalman-filter is the actual angle measured by the accelerometer, the angular Speed measured by the gyroscope and the time-step between two measurements. With these Parameters the kalman-filter is able to calculate an angle, which follows the gyro in times of high accelerations and in times of less accelerations it approaches the value of the accelerometer. In the Picture you can see the drift of the gyro and the good Job of the filter.
Step 3: The PID-controller
The segway tries to get the angle down to 0°. If the angle is positive, the segway brakes or accelerates backwards. If it's negative the segway accelerates forward.
But which signal get the motors? This is exactly the task of the pid-Controller.
The proportional-part: The angle should be 0°. So the greater the angle, the higher the speed of the motors.
Mathematically you can write:
angle_error = angle_should - angle_is
p-Motor-value = k_p * angle_error
The integral-part: When the current angle isn't zero, the Controller tries to get the segway horizontally again. But this approach shouldn't be slow and the smaller the angle-values, the slower the changes. Therefore the Controller allows a faster approach with the disadvantage, that the movement doesn't stop at 0° and goes a bit to the other side. This behaviour is guaranteed by the integral-part. All the angles are added (integrated) and this integral over time should be Zero. So if the angle is f.e. positive for a while, the Controller tries to get the seqway into the negative area. This guaranteeds faster approaches...
error_sum_new = error_sum_old + error
i-motor-value = k_i * (error_sum_new)
error_sum_old = error_sum_new
The derivative-part: Not just the current angle is important but also the changes of the angle. Let me explain: If the angle is f.e. 10° and it doesn't Change a lot, the Motors don't need to correct this shift very fast. But if the angle is 10° and it changes very fast (high derivative), than the motors have to correct this also very fast.
d-motor-value = k_d * angular Speed
Finally you get: motor-value = p-motor-value + i-motor-value + d-motor-value
Step 4: The Complete Setup
Now it's time to start the segway. To drive not only straight ahead you have to mount two buttons. When you push f.e. the right one, the left Motor increases Speed and the right Motor slows down. To ensure smooth transitions the added and deducted value starts at zero and increases step by step (+0.5 every loop) until he reaches the maximum value (f.e. 30).
To try out your own segway I 've attached the simple program for you. Good luck and don't follow the segway-inventor James Heselden down a cliff ;-)
Maybe you want to take a look at my YouTube-channel: www.youtube.com/user/stopperl16/Videos
Arduino Contest 2016
Second Prize in the
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    34 Discussions
    stoppi71
    2 years ago
    Yes, you'll need a second button (voltage-divider with the 10 kOhm-resistor)... Pin 12 and 13 are low, if the button isn't pushed. If you push the button for steering, the signal goes high...
    Therefore I ask in the program: if (steering-button-right or left) = high then ...
    I've changed the Picture of the circuit, because in the first version the status was low if the button was pressed ;-)
    Jinu Jogystoppi71
    Reply 4 months ago
    can u explain briefly about it. Also can we use potentiometer for steering the direction?
    meghabhosale1503
    7 months ago
    Can i get full pdf of segways construction
    YashS142
    Question 8 months ago on Introduction
    i m using 2 350 watt motors for segway.i have two 12 volt batteries that connect in series giving 24 volts.i want 14 amps current for each motor. how can i get that? what possible combination capacity of battery (voltage and current) should i use? i m using sebertooth motor driver 30*2 channels.please guide me for motor driver function and how i couple motors with wheels
    YOSHIMINE
    Question 1 year ago
    Nice to meet you
    Your research is very good
    I am a teacher of an industrial high school in Japan.
    I have a request
    I referred to ”Step 4: The Complete Setup”, but the motor does not work.
    ”FXLSYHKIW6PNEU6.ino” could also be compiled.
    I'm sorry.I still need to study more.
    It would be greatly appreciated if you could explain the details.
    AirraB
    1 year ago
    Can i use another motor driver? i would like to use your project as reference in my project but the driver that you used is not available in our country and the cost was too high heheh... can you give me some advice about the motor driver? thanks ^_^
    sonasec
    1 year ago
    thank you for sharing, you have making the best project for me ..you're actually a professional engineer.!
    pachanoid
    1 year ago
    very good, am making a robot with that code, and its working!
    HippieC
    2 years ago
    Way too advanced for me but i know some people in stockholm that made one at maker space. Was very impressed!
    KonstantinL8
    2 years ago
    Cool project and nicely documented!
    How much weight does the current setup (250W motors) carry around?
    and do you have some kind of encoders or odometry for the wheels?
    clothier_bruce
    2 years ago
    My question, too: why did the Arduino PWM O/P and a bridge cct not work? What does the commercial controller do that a basic DIY set-up not do?
    stoppi71clothier_bruce
    Reply 2 years ago
    Take a look at my YouTube-Video "segway - first Version" ;-)
    nezmar007za
    2 years ago
    Hi. What problems did you encounter with Arduino PWM control and H-bridge?
    stoppi71nezmar007za
    Reply 2 years ago
    Hi!
    Take a look at my YouTube-Video: Segway-first Version...
    Then you'll clearly see the Problems I had with the first Setup ;-)
    lynnduvall
    2 years ago
    Do you have a cost estimate? What are its safety features? I'm a senior, hoping to move to a walkable community where I still might have a need for speed. This looks better than an electric bike. Could a double kick-stand be added to the front edge of the platform to make it stand upright while parked, if it doesn't do that already?
    stoppi71lynnduvall
    Reply 2 years ago
    Concerning the costs:
    * Motors 100 Euro
    * Sabertooth motor driver 150 Euro
    * complete wheelset: 120 Euro
    * chain, pinion: 30 Euro
    * arduino, MPU6050 sensor and other electronics: 15 Euro
    * lead batteries (used): 30 Euro
    The safety Features are, that in the program the maximum-angle is limited with 30 degrees. But I don't have a redundant-System like in the original segways. So it's just a bit for stunt-Drivers ;-)
    If you let the segway alone, it keeps standing horizontally. If you incline it Forwards or backwards the Motors will stop.
    rafununu
    2 years ago
    Did you already try the 500W motors ? I think that maybe your 250W motors aren't driven properly, or maybe they are old and have lost some power. 500W is about 0.7 hp, which is one fourth of the average power of a 50cm3 gas engine. Such an engine can carry a load of 200kg at a speed of 100km/h (62 mph) !
