Automatic Chicken Feeder
5,642
54
12
About: Fixer, Finder, Fabricator.
This chicken feeder is designed to keep unwanted visitors from your chicken food and helping themselves to your chickens dinner. The chicken has to stand on the pedal to open the top and get lunch, most birds, rats, mice, are not heavy enough to push the pedal down. It also keeps the food dry as the top will keep the rain out.
To train your chickens just put some grain on the lid for a few days they soon get the hang of it. Or if you have some very stupid chickens like mine you may have to prop the lid open for a few days.
The chicken feeder needs to be place on a hard flat surface, as if it rocks around too much the chickens get spooked and it is diffcult for them to open.
Step 1: Stuf You Will Need
You can make this project from galvanized sheet metal or aluminum.
The design has safety edges to help with strength and sharp edges if you use galv
  • .6 galv sheet or 1.6 aluminum
  • 2 hinges
  • pop rivets and a rivet gun
  • tin snips
  • big square
  • 6 bolts and locking nuts
  • 6mm drill
  • 3mm drill
  • 3mm X 12mm flat aluminum
  • ruler
  • scriber
  • sheet metal folder or brake
  • sheet metal guillotine is also very useful
  • spot welder can also be used if you wish
Step 2: Start With the Base
The base is the easiest part to make, cut yourself a piece of sheet metal 530mm X 390mm and make sure it is square. Follow the measurements on the drawings. The design drawing without measurements are shown for clarity through out this instructable.
The photos have pop up note on them to help you with the build
Step 3: The Sides Are Next
Cut yourself 2 pieces of sheet metal 220 X 220mm and follow the photos with pop ups. Remember there is a safety edge on top and the two part are a mirror image of each other, so the holes need to go on opposite sides to each other.
You can either spot weld or pop rivet the sides to the base.
Step 4: The Links
The 4 links are easy to make and it is a good idea to tape them together so you mark and drill both sides at once.
You will need to 12mm x 3mm flat aluminum, 2 X 290mm and 2 x at 150mm
Click on the photos and follow the pop ups
Step 5: Making the Lid
The lid is a little more challenging as there are lot of lines to confuse you. If your not sure on the exact size of your hinge centers it can be easier to attach the hinge on with one rivet then drill the other holes.
You will need a couple of small hinges, pop rivets, and a rivet gun to fit the lid.
Start with a sheet 249 X 624 mm and start by marking out the safety edges at 12 mm.
It is much easier to drill the holes before you fold sheet.
Click on the photos and follow along.
Step 6: The Pedal
The pedal is also quite challenging with lots of lines which can get confusing.
Watch out for the final bend on the ends it needs to have gap for the links to fit into and it would be very easy to bend it on the wrong line
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    12 Discussions
    lukee1986
    14 days ago
    cant u just use a old toolbox and put ur design of hinges and pedal on it
    wannabemadsci
    6 weeks ago
    Nice design and great explanation.
    liquidhandwash
    2 years ago
    click on the photos in step 5, and use the arrows to see the side show. the measurements are there.
    heereliquidhandwash
    Reply 1 year ago
    Thanks a lot for your reaction about the measurements of the step ,
    i fond them ! Do you have a electricalscheme for a automatic-opener for the
    chickendoor in the chickenched , witch relais and a car-sidewindow-opener ???
    It will be great , thanks a lot again , Heere van den Engel
    liquidhandwashheere
    Reply 1 year ago
    I have an automatic chicken door opener, its my 8 year old daughter :-)
    I dont have any plans to make one
    thanks
    We dont have squirrels in Australia, so I dont know, but they are basically a furry rat so i would think it would keep them out.
