BARN WOOD STRING ART SIGN
3,749
73
7
About: Hello, I am an artist, novice carpenter, maker, creator. Who flips burgers by day.
This is a faux barn wood string art sign made from cedar fence planks.
Supplies:
Step 1: SIGN BACKING
Cut fence boards to the need dimensions and secure them together with yet more fence boards. Pre-drill and screw boards together from the backside with short screws that wont penetrate through. After this step I built a frame around the outside but it isn't necessary.
Step 2: MAKE THE NEW WOOD OLD
This is new cedar wood at this point. All pink and bright yellow. Its time to change that.
Look up a stain recipe to experiment with. The recipe I used calls for a jar of Vinegar with the addition of a pad of steel wool placed in it. Wait a day or so for the wool to dissolve. This creates a chemical stain which affects the wood fibers to turn grey as if aged. Sounds simple, but it will take some testing. Cedar reacts differently to this mix than Pine, so test, test, test. Cedar will go black if the stain is not diluted while pine will go grey. Take some scrap wood, put the stain in a spray bottle, test, then dilute if necessary. I even added a bit of white paint to act as a greying agent. Use a brush to help feather the affect.
Step 3: THE LETTERING
Choose what you want your sign to say and a font style you would like to use to achieve your desired look.
You could use Word, I used Photoshop because it affords more control, you could always hand draw your lettering too.
In way of planning it is good to know exactly how you want the words on the sign to lay out and how big it needs to be. Do some sketches and play around with it until you think you have it right. I ended up using several different font styles and slight size differences between each letter! On top of that I hand drew some portions to achieve the perfect form in the lettering.
Step 4: GET IT ON THE BOARD
For this method I suggest you take your SMALL sketch and project it onto a paper template.
Create your paper template by cutting / taping paper to fit your desired surface area of the sign.
I did this by laying it directly on top of my sign board and trimming it to fit.
The projector I am talking about is called an opaque projector which you can buy at Michael's. They take some getting used to so experiment a little. Factors to consider will be distance of the projector, elevation of the projector, focus, and 90º angle. Its a challenge.
This is useful to easily compose the lettering onto the sign area without much struggle, but the old fashioned way to just MAN UP and draw it on.... THAT never fails.
Step 5: GET NAILIN'
Tape the template in place and begin nailing. I started out by measuring each nail placement but quickly switched to doing it by eye with a varied distance apart. Where there are curves you need more nails to achieve a smooth appearance and obviously the corners are important points. About 1" to 3/4" apart seemed to work well. just remember if you have too few the string may look sparse and patchy.
Step 6: PAPER REMOVAL
This part was terrible. After pulling the paper template off about a thousand little paper tags were left behind. These I removed with some tweezers, it was the best way I could think of to do it. This is when I wished I had just drawn it by hand, but it came out ok.
Step 7: TWINE IT UP
Tie a loop around your twine or yarn and lasso the first nail. Work on one letter at a time to progress across the whole project. ZigZag patterns up and then back making sure to cross the thread as many times as you can, also string the outline to help with the readability of the letter. This is like half the labor so get some help.
GOOD LUCK!
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    7 Discussions
    hiwakoo
    1 year ago
    Perhaps it would be possible to pirce through the paper into the wood. After removing the paper there should be marks left in the wood where the nails need to go? It looks very good and the letters are clearly outlined and smooth.
    PSSHAKESPEAREhiwakoo
    Reply 1 year ago
    Thank you. Thats actually a great idea. Probably the way to go to avoid pencil marks on the wood for risking charring the wood with a blow torch. Next time for sure!
    astermax
    1 year ago
    No need for the projector when using Photoshop— just scale the design up to the desired size and print it onto multiple pages, tape together and voilà!
    LukeR19
    1 year ago
    If you don't want to remove all of the little pieces of paper, you can also go over the wood lightly with a blowtorch (moving with the grain of the wood) and it will burn the paper off and give the wood a cool burnt look. Here is an example on vimeo: https://vimeo.com/30564597
    kai.h
    1 year ago
    That is a great look, but it really seems painful to have to pull out the bits of paper. What I probably would do is take a blowtorch to it - if you move it around quickly enough it will burn the paper without charring the wood - and any slight singeing or charring would just add to the distressed/weathered look anyway.
    Jamn4god
    1 year ago
    I think it would be easier if you cut out your pattern and nailed around the edges. Then you could pull the paper out with a lot more ease. That's how I've seen it done elsewhere.
    XTL
    1 year ago
    Or lay the text out in Inkscape (a free vector program with no Ads), then print in pdf for real size multi-page printout and tape together.
    1. In Inkscape - Size the paper dimensions to be the same as your wood (inches or mm). (Menu is File/Document Properties)
    2. Layout and scale the text in font of your choice.
    3. Save as PDF - most important because:
    4. Load in adobe Acrobat Reader (probably already on your machine) and look for poster print in the print options. This will print it out at full scale over several sheets.
    5. Tape the sheets together and proceed as described above laying it out onto the wood.
