Battery Cases for Electronic Kits.
11,281
141
4
About: Fixer, Finder, Fabricator.
If you have built one of the cheap electronic kits featured in my previous instructable, you probably want to put in some sort of case. Having your project in a nice looking case will really make your project look great and will impress your friends much more than a naked PCB with wires and a battery hanging off it. Your project should be something you can be proud of, take to a job interview and say look what I made!
This instructable will show you whats possible with a little thought and a laser cutter.
There are four types of cases shown here,
  • Case without a battery or switch: The easiest to make but you will need to run a lead to your power supply.
  • Case with a battery: Great if your kit has a switch.
  • Case with a battery and switch: The most challenging to build, but some kits don't have a switch.
  • Case with a push button, battery and switch.
Step 1: Tools and Supplies
You will need a few bits and pieces to build these cases, but once you have everything, they are very cheap to make.
  • Laser Cutter
  • CAD drawing program
  • 3mm acrylic sheet.
  • Selection of 3mm screws and nuts
  • Selection of 3mm standoffs
  • Super Glue
  • 3mm flat washers
  • Solder and soldering iron
  • Digital Caliper
  • Button cell batteries (CR2032)
Step 2: Flip Flop Case, No Battery
The flip-flop circuit is the easiest to make a case for, as the PCB has four mounting holes. Shown are 2 types of case one with a battery and switch and one without.
The case without the switch and battery holder has the advantage of being very easy to make, but you still have the problem of powering the device and switching it off and on.
The student project shown, solved this by fitting a button cell on lead with a header plug that can be disconnected.
There are lots of photos with notes to help you assemble your project.
Step 3: Flip Flop Case With Battery and Switch
The case with a switch and battery is a bit more challenging, but it makes for a much better display than having wires and stuff hanging out the side.
The switched case can be turned off and on by pushing the button/lever on the side of the case and is the basis for the design of the other cases shown here.
Step 4: Dice Case
The dice case has 2 button cells a switch and a push button on the top. The kit itself looks great but doesn't really work very well, It possible to throw a zero, and it has some weird combinations of LEDs
The PCB is held down with washes on each corner as the PCB has no mounting holes, so you will have to cut the component leads very short to get everything to fit correctly.
Step 5: Sound Flasher
The assembly process for the sound flasher is almost identical to the dice and flip-flop with a battery.The case is the same design just smaller, only has one battery and it has no push button on the top. There is not as much detail in the photos as the flip-flop or dice, so if you get stuck, just look back at those projects.
Make sure the component leads on the back of the PCB are cut very short, to give you space for the wires.
It's a great little project and will flash when there is a sound.
Step 6: Door Bell Case
This case has two button cells and no switch. It is very easy to put together, but you need to make sure that the pigtails on the back of the PCB are cut off very short, and the wires to the battery are also short as possible.
After going to all the effort of making this case I found that the battery will run down after 2 weeks just sitting on the shelf, doing nothing...Damn it! Really needs a switch to turn it off.
Step 7: Lucky Wheel Case
The Lucky wheel case has 2 button cells an on-off switch and a button to make the lights spin. A little more challenging to put together, and you will have to super glue a wire to the rocker switch
Step 8: Chaser
Ok If you got this far you will have a good idea on how to put the cases together. The last three kits are very similar to what has already been shown, so you shouldn't have any difficulty assembling them, so I haven't put as much detail in the assembly photos.
The chaser is almost identical to the dice, so if you get stuck, you can go back and have a look at that.
Step 9: FM Transmitter
The FM Transmitter is one of the easiest cases to make as the kit already has a battery holder and switch.
With only 3 pieces some screws, standoffs and some washers you should have no problems assembling this case.
Step 10: LED Hour Glass Case
The LED Hour Glass Case is also very easy to put together, as it only requires two batteries and no switch. If you want to run the hourglass for more than a few minutes I would suggest that you use either bigger batteries or a power supply, as the little button cells will run flat very quickly.
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    4 Discussions
    ОлегК15
    1 year ago on Step 2
    The case costs more than electronics! ;)
    If you order laser cutting in another company, then the price will increase once more in two.
    As a result, the case turned out beautiful and strong.
    pgs070947
    1 year ago
    If you have a device like an MCU that can sleep to save battery life, you can use a reed switch and magnet to activate it in a sealed case.
    Neat little assemblies - I use steel or nylon spacers a lot to stack boards.
    I also use Acrylic like yours to in layers to embed sensors if you need to see what's going on underneath like utility meters
    Neat PCBs
    liquidhandwashpgs070947
    Reply 1 year ago
    Thanks for the tip, The case were designed for my students to show off there work, and so far has been a hit with them. I was also thinking of using a tilt switch, turn it upside down to turn off.
