Beebeecraft Tutorial on How to Make a Pair of Glass Pearl Dangle Earrings
34
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Summary: How do you like beaded dangle earrings? Here I will share a pair of white glass pearl beads dangle earrings with you all. Hope u will like!
This pair of glass beaded earrings is made with white glass pearl beads and golden pins mainly, there is also two tibetan style alloy pendant flower, it is quite easy to make.
Supplies:
Step 1: Supplies You’ll Need in Making Pearl Dangle Earrings:
14x12x4mm Brass Flower Enamel Charms
6mm White Glass Pearl beads
Golden Clip-on Earring settings
5cm Golden pins
Jewelry making tools pliers
Step 2: Make 2 Beaded Dangle Patterns
1st, slide a white glass pearl to a eyepin, and make a loop at the other end of the eyepin;
2nd, make 4 beaded loop as before to connect them together;
Step 3: Add the Earring Hooks and Finish the Glass Beads Earrings
1st, add the flower pendant to the connected pearl pattern links and attach a earrings hook to top of the dangle;
2nd, repeat above steps to make the other one earrings.
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
