Belt Buckle Knife
4,610
50
12
Is it a simple belt that holds my pants?
Tired of losing knives, I was thinking about making one that was part of my belt, so I made one of 420 stainless steel. This discreetly hides in the belt taking advantage of the shape of the buckle.
If you like the video please Subscribe to my Youtube channel
I would also apologize for my English as a non-native English speaker some terms are very difficult for me. Forward, Instructable!! I will be happy to answer any question.
Supplies:
Step 1: Materials and Tools
MATERIALS
Stainless Steel sheet 420:
  • This steel is recommended for beginners with stainless steel due to the medium-low level of difficulty to work it.
  • Tempering (oil): 980 to 1030 ºC
  • Hardening: it's recommended a temperatura range from 100 to 190 ºC (minimum recommended time is of 50')
Old belt
One metal nail
Kidex (black)
A selection of sandpaper from coarse grit to as fine as you can get
Super glue
TOOLS
Hand tools
Metal files
Hacksaw
Hammer
Ruler/Square
Drill bits
Clamps
Mitutoyo caliper
Sharpening stone
Power Tools
BTS900 Scheppach Belt sander
Optimum B14 Drill press
Goxawee 240W Die grinder
Bosch Grinding machine
Proxxon fd150 Mini lathe
Oven
Heat Gun
Step 2: Drawing and Cut
Using a stainless steel sheet 420 (5x40x150mm) I began marking the silhouette (document attached). To make this easier and not to move the papel I used small neodymiums which were very useful :-))
Once the silhouette marked using the grinding machine roughly cut out the knife outline leaving about 2mm of waste around the profile.
Step 3: Defining Silhouette
I used the belt sander to gradually work down the profile until I reach the line I made all the way around.
For hard-to-access curved areas I used round metal files and finally with a die grinder for a finer finish.
The 420 steel untempered works fairly easily with power and hand tools (metal files), but once hardened it does not allow manual machining.
Step 4: Buckle
To empty the interior of what the buckle will be, previosuly I delimited the area and drilled the entire contour with the idea of removing as much material as possible. In this way, later it would be easier for me to finish cutting it with the disk of the die grinder.
Finally, I filed all the areas leaving the interior with a uniform appearance.
Step 5: Bottle Opener
At first, I did not have the idea of adding an opener to the knife, but I thought that if I did not make it, someday I would regret it :-))
So I returned to the initial drawing and marked the area where the opener would be. I drilled a hole with a drill bit and cut the rest with the metal saw.
Step 6: Adding the Bevel
Draw a line down the middle of the steel where you want the edge of the blade to be.
Clamp the blade horizontally to a table and use the file to slowly grind the edge to add the chamfer profile.
I decided to make it this way to have more control and that the angle was always the right one. It worked great but takes a while! :-(
Turn the blade over and repeat on the other side.
Using sand paper to gradually sand out all of the marks created by the file and create a good finish. Firstly I used rough grains until finish using 1000 grit paper. It is important to make sure that the whole blade is sanded!
Finally, I wanted to give it a sharpening in the water stones before give the blade is heat treated.
Step 7: Prong Belt
I take advantage that the metal is not yet tempered to make two holes that I will use later to put the prong of the buckle and a piece that will prevent the knife from coming loose from the belt.
Step 8: Heat Treating
The treating actually quite hard to complete accurately, heating the steel to a temperature 980º-1030º (Stainless 420) and then quenching in oil of the car, this hardens the blade and makes it very brittle.
The next stage to the process is tempering, I heated the oven of my house to 200º and I introduced the knife during approximately one hour.
This process requires a lot of practice and knowledge. Sure that in this operation I made mistakes but I think that is where you learn (learn by trial and error).
Finally after all the process, the metal acquires a dark tone that I removed it using sandpaper with soapy water.
Step 9: Prong Belt
To make the prong of the buckle I use one metal nail, which I process in the belt sander turning it into a 50mm long stainless bar. I file one of its sides leaving a smooth surface and with a hammer and patience I give it the desired shape .
Step 10: Knife Stopper
For fixing the knife to the belt, I made a small stainless steel piece with my little lathe, which I later heated red-hot and hammered until it was fixed in the knife.
This type of pieces are sold with different fastening systems but I decided to make it myself to practice with my small Proxxon lathe :-)
Step 11: Sheath Part Under the Belt
For the sheath I used Kydex which is a thermoplastic sheet which can be molded to form-fit nearly any shape.
Using an old belt which had nothing special, I cut its buckle and I made a hole in which would fit the piece that I made with the lathe.
Then, with a piece of black kydex I put it over the knife and heat it with a heat gun. I put foam quickly and press it with clamps. After a couple of minutes, when removing the clamps the kydex will have hardened and will have the shape of the knife!
I cut the piece of kydex to the size of the belt and glue it with super glue. After a few days using the belt, I decided also to sew the piece of kydex giving it more resistance.
Step 12: Final Conclusions
I am very happy with the final result and everything went more or less as expected.
Based on this idea, different designs can be made according to the needs of each one, such as a multi-tool.
I hope you liked it and that someone gives the desire to make one.
See you soon!
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    12 Discussions
    ShahzadY1
    2 months ago
    Sir I want to buy this . How is possible
    Shahzad Younis
    Ibrahim jafli road al awali ,makkah, saudia arabia
    00966591517817
    misko13
    2 months ago
    I just experienced love at first sight ✧・:*(◕ヮ◕)*:・✧
    Love the concept and the execution. That's the last thing I could expect to see in a belt.
    tercero
    3 months ago
    A good instructable, but a word of warning for my fellow Canucks.
    This is completely illegal in Canada (also for any Americans crossing the border. Please leave these back in the USA. If found by the CBSA you will be charged, and deported). If this is found in your possession, you will be arrested and charged with felony possession of a concealed weapon.
    If you had this and got into a fight with someone, even if you never used it. You could be charged with assault with a restricted weapon. Just because it is on you at the time. You wouldn't even have to show it or threaten to show it. Being in your possession goes to intent. Same laws that cover restricted weapons, cover this constant companion knife (the correct term).
    The more you know.
    https://www.cbsa-asfc.gc.ca/import/iefw-iefa-eng.h...
    Alex in NZtercero
    Reply 3 months ago
    This is a great, and very well written 'Ible, but the same legal thingy applies in NZ. Thank you for sharing your work, but please be careful where you wear it :-)
    HenmarshAlex in NZ
    Reply 3 months ago
    It is a great shame that such craft and workmanship have been devoted to what is, however you look at it, a concealed offensive weapon with only one purpose - stabbing people. Illegal (and rightly so) here in the UK too.
    cTsVetteHenmarsh
    Reply 3 months ago
    Henmarsh--It's a knife, knives have lots of uses that don't include stabbing people. Like, idk, cutting things? If it's purely for the purpose you claim, it's not a very good design-"Hey, wait, stand still for a minute while I occupy both of my hands with undoing my belt..."
    HenmarshcTsVette
    Reply 3 months ago
    I'd argue why carry a concealed knife that you have to drop your pants to peel an apple with. Personally I'm delighted to live in a civilised country where such items are both illegal and unnecessary.
    Mikhandmaker.tercero
    Reply 3 months ago
    Thank you for the comment and advice, I made this tool with the intention of using it in the mountain and similar. I really hope this won't be an idea for some people to use it for bad purposes.
    terceroMikhandmaker.
    Reply 3 months ago
    No problem Mike. We're very restricted on carry and conceal here in Canada. Even some simple folding knives are now banned. The problem(s) are irresponsible owners and those intending to do harm to others. Plus, the times we live in with terrorism always on peoples mind.
    I like the instructable. I think it's well written and covers everything.
    The only thing I would have changed would be a warning label on the title and in the first paragraph stating that this is completely legal in the United States ONLY, and if you live in other countries you should probably check your own local federal criminal laws and statutes regarding these types of weapons and/or instruments.
    I hope this doesn't put you off providing instrutcables. It's good to see new things.
    RobertW327
    3 months ago
    Two things . your stainless steel must be low quality if it is magnetic . and use vegetable oil not car oil as the fumes are not as toxic .
    deadlegs
    3 months ago
    Nice craftsmanship. Looks to be a very useful tool. In my home state, this could legally be carried with a Concealed Carry Deadly Weapon permit. Weapons can be offensive or defensive. Legal here, and rightfully so.
    Disasterific
    Question 3 months ago
    Very nice, did you purposely type multiple sentences with ‘of the.’
