Better Than My House Shed
100,128
746
68
About: Like inventing, woodworking, tractor gadgets, gardening, making Youtube videos, wind turbines, ham radio, making instructables, etc
I needed a shed suitable for year-round use. The "Better than my house" shed described here in pictures and video fits the bill. The wall studs are 2x6 and the spaces between are fully filled with fibre glass insulation. The ceiling insulation meets the R40 specification. The shed is mounted on a pressure treated skid foundation. Additional foundation support is achieved with blocking between the floor joists and a concrete walkway that runs under the shed.
I started out with a 12x16 floor and decided to add an extra four feet to get 12x20. Now I wish it was 12x30.
Other features include pressure treated sill plates, pressure treated plywood floor deck with solid foam insulation between it and the plywood interior floor, roof underlayment, roof ridge vent, and sealed double-paned windows and insulated doors. Because we almost always end up getting the tail end of hurricanes coming up the eastern seaboard I also included galvanized hurricane brackets between the top plates and the roof structure.
The Steps that follow consist of photos taken during the construction phase of the shed. The Steps are more or less arranged to show construction from foundation to roof, and then on to some frills.
I made up a video My shed building story that includes most of these photos and many more related shots.
Supplies:
Step 1: Foundation and Floor
I went with pressure treated skids for the foundation with one skid under each side of the floor. I first dug out the existing sods and soil and replaced it with runs of 3/4 inch gravel. I then set the skids in the gravel. An existing concrete walkway running right under the middle of the shed gives substantial extra support by means of blocking between the walkway and the floor joists.
The last photo in this step shows how I used the shed floor to design and size the roof rafters. Playing around with the roof pitch and notching, etc. is a lot easier at the floor level rather than working on it from the top of the erected walls.
Step 2: Erecting the Stud Walls
2x6 studs and pressure treated sill (sole) plates are featured in the wall construction. I wanted to have the shed easy to heat with thick walls, and good sealing to reduce air infiltration. The pressure treated sill plates should prevent any wood rot due to any standing water on the shed floor (mainly from tracked-in snow).
Step 3: Rafters and Roof Sheathing
A few sheets of 1/2 inch plywood temporarily laid on the ceiling joists gave a good working platform to help with the installation of the ridge board, rafters, and eventually, the roof sheathing.
Step 4: A Simple Scaffold for Safety and Convenience
Even if I wanted to use a regular metal scaffolding to work on the roof I didn't have space enough between the shed and the fence to erect one. The temporary wooden scaffold worked just fine and was not a big deal erecting in terms of time and materials. I first installed the aluminum fascia and then got to work installing the roof underlayment. The roof underlayment will prevent water damage from any ice dams and provide a good leak prevention backup for the asphalt shingles.
Step 5: Shingles and Ridge Vent
It's common practice around here to glue down asphalt shingles with roofing cement. The underlayment, cement, roofing nails, along with the built-in shingle adhesive, should give a long lasting, windproof and waterproof, roofing system.
I went with a plastic ridge vent on the roof rather than louvered gable vents. Ridge vents are generally less inclined to let horizontally travelling snow and rain from getting in. I nailed the roof vent in place and then covered it will nailed on, overlapping, shingle sections.
Step 6: Exterior Wall Sheathing, Windows and Doors
I picked up the two doors and two windows early on as I found good deals. That approach also made sense in terms of sizing, laying-out, and building the stud walls. The two doors have lots of glass and they are double-paned sealed units that have foam insulation between the metal/wood cladding. (I wanted a shed brightened with as much natural light as possible). Both vinyl windows are double-paned horizontal sliders.
Step 7: House Wrap and Vinyl Siding
House wrap and associated tape keeps the shed air and water tight so I took a lot of care with that part of the project. Vinyl siding is by far the most used siding around here (and in all of North America) so that is what I went with. It's the same siding I installed on my house, so now I have a perfect match.
In the process of installing siding on my house (that was before the shed project) I came up with a "siding hammer" invention. It was so good :) that I applied for and received a Canadian and US patent. My Vinyl siding hammer inventionInstructable gives more details.
Step 8: Strapping, Insulation, and Interior Sheathing
Fibre glass insulation in the ceiling and walls and solid foam insulation on the floor combine to make an easy to heat and comfortable shed setup. I laid the solid foam insulating boards over the pressure treated plywood floor deck. I topped that with 1/2 inch exterior grade plywood. I installed the same plywood on the walls and ceiling because I wanted to nail, screw or drive whatever I wanted, without having to worry about not having a solid surface to work with. I installed plastic vapour barrier between the insulation and the sheathing on both the walls and ceiling.
I made up a four legged wheeled working platform to help me install the plywood sheets for the ceiling. A simple system of plywood support brackets and a car jack mounted on the platform held the sheets securely while I nailed them in place.
Step 9: Shelves, Shields, and Finishing Up
I made simple built-in shelves to take care of my hoarded junk. Outside the shed I built a couple of high-backed garden chairs to give some extra privacy and wind shielding. I was working on my front and back decks and a garden pond in the same time frame as the deck - the photos give a glimpse of those projects too. Overall I am very pleased with the final outcome of it all.
Step 10: Wintertime
A cozy shed at wintertime!
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    68 Discussions
    jompon2547
    1 year ago
    can i add the AC to the shed
    since Texas is darn hot
    themhs65
    2 years ago
    Hi there,
    Very good job despite some minor failures if you had on building the shed. After all you have a sturdy and good place near your house. I can't have one like this in Greece due to the rules for constructions and the the huge taxes you have to pay if someone do it by the rule.
    nlinventorthemhs65
    Reply 2 years ago
    Thanks and I understand what you mean by the rules and taxes. I'm getting good use out of the shed since its been finished.
    silvertank
    Reply 4 years ago on Step 10
    Does not your keyboard have a way to turn off caps lock?
    Wheatridgesilvertank
    Yes it does. I just typed my reply without looking at the screen. My question was does not your town have fencing requirement for pools?
    silvertankWheatridge
    Reply 3 years ago on Introduction
    I see a large fence around the property, so that may fulfill the fencing requirement. Also, it may not apply to decorative pools. These requirements vary greatly across regions and counties. In my area, you need to fence the poll or the surrounding yard, whichever is more cost effective. In the city areas, you have to fence both the yard and pool.
    nlinventorWheatridge
    Reply 4 years ago on Introduction
    Wheatridge is this question for me (author)? Anyway I'm pretty sure nothing has been developed yet re pools and ponds for my city. Pools and man-made ponds are as rare as hens teeth around here - perhaps because of our climate :)
    For a cheaper alternative to plywood on the walls/ceiling, OSB works nice. 4x8 sheets are under $10 and you can drive screws into it just like plywood.
    lynndevollNitroRustlerDriver
    Reply 4 years ago
    Unlike plywood, OSB will pull out under weight unless you screw into a stud. With plywood, you can place your screws or nails any where without worrying about hitting a stud.
    NitroRustlerDriverlynndevoll
    Reply 4 years ago
    I've screw lots of stuff to OSB and never had a problem with it pulling out. Are you sure you aren't thinking of MDF or particle board?
    The stuff I'm talking about is 7/16" thick and is more than adequate enough to hang most things on. Basically anything that could hang from a screw, you can hang in this stuff. I also use it for garage shelving as the decking.
    nlinventor
    Thanks - Yeah it's pretty hard to post an article here or a video on youtube (for example) without some kind of non-constructive criticism. But for the most part positive comments far outweigh the negative and that's why we all keep posting.
    vincent7520
    Photos are great ! You've got a photographers eye. Definitely.
    Congrats for your achievement… I just wondered why you didn't make it bigger as a shed ALWAYS become crowded and too small at one point.
    Well… maybe you are an optiomistic fellow !…
    Cheers. ;)))
    nlinventorvincent7520
    Thanks - I mentioned in the introduction that I should have made it bigger than it is... but no plans to expand at the moment. I made the roof overhang on the "far" end of the shed longer with the intention of making a small deck for doing some outside work. Not done yet :)
    ashnman2
    Just wondering why there is no Wood burning Fireplace in there???? I think its time for another Instructable. Just Sayin...
    Nikiniku
    inoble,
    That's true, but in order to decide on how much insulation to provide, you'd have to consider many variables. I started to make a list of them, but things got out of hand. You just have to consider many things, unless, of course, just building a shed is the most important thing. If that's the case, you can forget about cost or efficiency. I've been there. Supposedly, I was undertaking a project for its benefits, but I finally realized that it was the project itself that was most important to me.
    Nikiniku
    Sorry, but I don't understand why you put so much time and money into this project. Don't you have a house? What were you trying to accomplish?
    weishNikiniku
    Reply 4 years ago
    having a shed is nice for projects that are noisy, smell, or are crowded out of the garage by cars or stored stuff. it only makes sense to insulate it and build to last in a climate where snow and high winds can be a problem.
