Bike Handlebar Smartphone Mount
4,472
74
4
About: ''Não está acabado até que eu vença!'' -Autor desconhecido.
I've been looking for some easy and strong way to put my smartphone in my bike as i walk around ciclyng or catching Pokemons, but none of the suports that i've found were strong enough. The last one that I bought doesn't held the smartphone in impacts like a road bump or a rocky way so I decided to make myself one that could be a little more 'hardcore' and came up with this. Works flawlessly tho.
Supplies:
Step 1: What We Will Need?
For this one I used a GoPro bike handlebar mount, a GoPro tripod mount, a GoPro thumbscrew and an old smartphone cover.
Step 2: Preparing the Pieces
All the 'hard work' you'll have here is to remove the nut that holds the thumbscrew and cut away the bump where the nut used to be. If you don't cut this excess your screw won't get to the nut from the handlebar mount and you won't be able to tighten it up. You can also sand the side from where you removed the nut and the bump to a cleaner look. I haven't done it because I hadn't sandpaper here.
After that you just need to superglue this piece behind your smartphone cover (pay attention to the right position. If in doubt you can mount it in your bike to see wich way to glue the pieces). After that just let it dry for a few minutes and we are done.
Step 3: Mounting the Suport
Now you just need to go to your bike and put all together where you preffer. I have mounted mine like that and then put the cover over it with the thumbscrew.
A few kilometers later and everything is still holding on better than the pre made old suport that I had.
Sorry for any english mistake and thank you!
(P.S.: Those velcro tabs in the cover are from a previous and not so secure build that i've tryed.)
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    4 Discussions
    gabriellmaiaDhruv Bose
    Reply 2 years ago
    As long as you have a case for the phone, it might work. I've tested with my Sony Z3 Compact and one iPhone 5c with the same setup and I also have a friend that I made one of these for his Galaxy Note 4 and it has worked flawlesly..
    tomatoskins
    2 years ago
    What a great idea! I've been thinking of a way to mount mine, and your idea is just great!
    gabriellmaiatomatoskins
    Reply 2 years ago
    Thanks! I've spent a couple of days thinking the best way to make it with several different pieces and that one was the easiest and simplest one that came up.
