Bike Wheel Gyroscope
17,734
98
14
About: I made a book with some new projects in it! It's called Marvelous Makeable Monsters. Check it out here: https://amzn.to/2xN1uWj The Oakland Toy Lab is a community-based wonder lab for students to build, ti...
Why is it so much harder to stay up on a stationary bicycle? Why don't Segway tours always fall flat on their faces? How do smartypantsphones know when they're face up? The answers are wheely similar, and all lie in the realm of angular momentum and gyroscopes. They keep spinning things in check.
Brilliantly, there have been great science demonstrations using a bike wheel like this one at MIT. Also this one from Veritasium or this one from the Exploratorium. These can all demonstrate physics phenomena like gyroscopic procession and conservation of angular momentum. They're also just plain fun.
Since a lot of the gyroscopes require harder to acquire materials than just a bike wheel, companies have made things like these demo tools for sale. Let's make our own instead!
I wanted to make one for my classroom with extremely basic supplies for any bike wheel available. Basically just wood, clamps, and a wheel. Here we go!
  • What: Bike Wheel Gyroscope
  • Concepts: angular momentum, gyroscopic effects, centripetal force, torque
  • Cost: bike wheel + $2
  • Time: 30 minutes to make
  • Materials:
    • Bike Wheel (from dump, thrift stores, old bikes, anywhere!)
    • Thick Dowel (I used 2" diameter and worked great. You'll need about 2 feet of it)
    • Hose Clamp x 2 (from hardware store, big enough to fit around dowels)
    • Firm Plastic (optional, for guards)
    • Zip-Ties (optional, for guards)
  • Tools:
    • Saw
    • Sander (optional)
    • Drill
    • Mallet (optional)
    • Hole Puncher (optional)
URBAN LEGEND SIDENOTE: The urban legend goes like this. The Gravitron at the carnival starts up, spinning faster and faster. People find themselves "glued" to the wall, their limbs barely able to be lifted toward the center of the ride. The floor drops out. The teenagers are holding hands, the brothers are playfully "punching" each other by putting their fists in front of the other's face and letting them go limp. One woman is completely upside down. The ride operator isn't in the middle both. No, she is sideways, walking along the walls with her head toward the middle of the rotating ride. She is hopping over people playfully as she goes. She is living the dream of angular momentum. Is it possible? Let's find out!
Supplies:
Step 1: Make Some Handles
I started out cutting the 2" diameter dowel into two 9" lengths. This seemed like a good length for gripping. I sanded down the two ends that aren't going around the bike bolt to look a wee bit niftier.
Step 2: Drill Handle Holes
First, remove all extra hardware from your bike wheel so only the axle bolt remains. You want to choose a drill bit that is just a tad bit smaller than your bolt to get a snug fit. Drill holes in one end of each dowel (not the sanded end) so that the depth is about equal to the length of your bike bolt.
Step 3: Saw Some Kerfs
Kerf! What a fun word! It is the process of taking out a little bit of wood for easy bending. Use a saw to cut a slit down the dowel end you just drilled. You want it to slice right through the hole. This is to remove a little wood so that we can cinch the dowel around the bolt even tighter.
Now put on your wooden handles on the both sides of the bike wheel. Ideally it's the perfect tightness where you can screw it on with your hand. If you need, you can also use a mallet to tap it in. Don't worry if it doesn't feel tight yet. That's the next step!
Step 4: Hose Clamps!
Oh these things are brilliant. Take a hose clamp and slide it up the dowel so it's near the bike wheel. It should be surrounding the slit you just kerfed. Use a drill with a flat driving bit to screw the hose clamp, making it tighter. When it's nice and tight, cut off the extra tab. You can throw some duct tape on the end to cover up the sharp parts.
The handle should be snug now. Thank you to Josh at Pier 9 for this amazing trick. May we all use it often.
Step 5: Make Some Spoke Guards
If you want to avoid spinning spokes + fingers, these are great to add. I made some circles on some firm plastic by tracing a glue bottle, but any big circle around you will do. Cut it out and cut out holes in the middle that are big enough to slide around your bike bolts. These discs are the guards!
Step 6: Attach Your Guards
We're going to use zip-ties to keep this all together. Take off your handles, and place your guards over the bolt. Use a Sharpie to mark points near the outer perimeter where spokes run underneath. Drill these out (I used a nail as a drill bit) or use a hole-punch to make the holes. You can then zip tie them to the spokes, and cut of the extra stems. Huzzah! Safe fingers are happy fingers.
Step 7: Take It for a Spin!
Oh there is just so much to do with a spinning bike wheel gyroscope!
Here are a few to start out with:
  • Get it going fast, and then start to rotate it side to side. Sit in a swivel chair and see which way it pushes you back.
  • Take the wheel in one hand while it's spinning, and rotate around in a circle. Which way does the wheel push your arm? What happens when you rotate it?
  • Attach one handle to a hanging string or chain and get the wheel spinning. What happens?
All of the effects depend on the speed of rotation, the mass of the wheel, and how that mass is distributed. Basically, faster/heavier/furtheroutmass makes the forces go wahoo! I sized up to another bike wheel in the third picture, and the effect was amazing.
The effect is a great illustration of the conservation of angular momentum. Namely that when something is spinning, it will continue to spin unless forces act otherwise. And something staying still will remain still. When you have the spinning bike wheel in your and, and you rotate it, you are applying torque to change its angular momentum. By Newton's Third Law, every action will have an equal and opposite reaction, which just means that it's going to push back. Take that! When you rotate the bike wheel in your hands, see which way it pushed your body.
The overall effect is to keep you still, which is why gyroscopes are so commonly used as stabilizers. It helps keep you upright on a bicycle, keeps spaceships alligned, and even lets the operator walk perpendicular to the ground and seemingly float in The Gravitron. :)
Have fun, share what you find, and keep exploring. :)
3 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Classroom Science Contest
  • Arduino Contest 2019
14 Discussions
Alex in NZ
5 months ago
I first saw this at Jodrell Bank and it blew me away. Thank you for introducing it and showing your method :-)
eeltaay
Question 11 months ago on Step 7
Hi. Thank you very much for this tutorial. I'm definitely gonna give it a try.
I do have a question though: do you think an ab wheel could be used as a gyroscope?
cootzippy
1 year ago
Hi:
I am looking to build a bike-tire gyro, as you describe. I am undecided on the appropriate diameter wheel (somewhere between 18 and 24 inches, I imaging). I realize that a larger wheel will create a greater angular momentum (AM), but it also becomes more cumbersome, especially since I will be having kids as young as 5 and 6 years participate in the demos.. What do you feel is the smallest diameter that will demonstrate all the fun AM phenomena, such as causing a person on a rotating platform or chair to turn.?Thanks a million.
Barry
AbedLShah AlHasan
Reply 3 years ago
Auto-pilots on planes. Guidance systems use them as well as several industrial applications including walking robots.
AbedL
Reply 3 years ago
Gyros are at the heart of all electronic navigation systems including auto-pilots, missle and rocket guidance systems and satellites. They have industrial uses as well.
Jobar007
3 years ago
In my college class on physics of dynamic systems, my professor used this to explain angular momentum and the right-hand rule. It is really neat to see someone spin based on the force applied from another spinning thing.
robothumanitis
3 years ago
This is fantastic! Love your explanation. I didn't even know what a gravitron was before this - can't wait to find out more!
The Oakland Toy Lab
Reply 3 years ago
Definitely a practical educational use (see step 1), and definitely just spins. :)
ShadowPatriot90
3 years ago
I remember seeing something like this some years ago. Can this be used for exercise?
Hmmm, I like! I imagine you could indeed! I use it in science class to show certain physics principles (in Step 1), but exercise sounds great too! You could use it as an ab roller indeed.
