Bluetooth NES Controller Mod
28,034
62
6
Parts you'll need:
NES controller - $5 (I had one with a dead IC: Perfect)
Adafruit Bluefruit EZ-Key HID - $20
Kensington Pocket Battery k38056us - $16
Toggle Switch $4
CD tray opener switch
LED
Dremel Bits - $15 (WOW)
Supplies:
Step 1: Back of the Controller
I started by making some room for the battery. The one I used is 3.7v 1200mAh which for this controller is definitely overkill.
I removed a post because I needed room for the charging circuit/EZ-Key but I had room above the buttons and behind the board so this was unneccesary.
Step 2: Front of the Controller
I had already performed the LED logo mod and I reused the face. Don't pay attention to anything but the hole behind the logo because that's where the CD drive opener switch will go.
Step 3: Battery / Charging Circuit
This is the battery/ charging circuit. If you need to make room for the charge circuit you can solder the connectors for the USB cable/battery to the other side of the board.
Step 4: Controller Board
I cut the board right above the lower solder points to reuse the dpad connections. but I overlooked the start/select B and A buttons so I had to solder onto the traces to get those working again. This could probably have been left alone, but I had a dead IC.
The solder point labled GND - L will be the ground for all of the buttons, the EZ-Key sends button down events when the inputs are pulled to ground so you need 9 wires total: GND - L, Right, Left, Down, UP, A B Select and Start.
These solder right onto the EZ-Key's inputs
If you wanted to wire them so the buttons will sort of match up it would be:
Controller to EZ-Key Mapping:
GND-L to EZ-Key Ground
Right to #3
Left to #2
Down to #1
Up to #0
Start to #4
Select to #5
B to #6
A to #7
Keep your wires short there's not much room in the case.
Step 5: Wiring
If you wanted to wire the inputs so the buttons will sort of match up it would be:
Right to #3
Left to #2
Down to #1
Up to #0
Start to #4
Select to #5
B to #6
A to #7
The power switch will break the positive or negative lead going from the charge circuit to the battery so we're not wasting power when it's off.
Step 6: Final Product
Congratulations!
You've somehow managed to cram all of that stuff into this little case. Turn it on with the switch, check the LED placeholder to see if you've got power, test that pair button, connect it to your PC or phone, send some key-presses map the buttons in an emulator and enjoy!
  • Classroom Science Contest
  • Party Challenge
    Party Challenge
  • Fandom Contest
    Fandom Contest
6 Discussions
Zaee
5 years ago on Introduction
Anyone willing to make one (preferably the creator) and sell it to me for 70 USD? I need one by June 3rd. Private Message please.
mx28Zaee
Reply 4 years ago
you can buy them online ready to use for 30-45 bucks (USD)
JakeH1
4 years ago on Introduction
Is it possible to apply this mod to a volume control remote, and sync it with my Galaxy S5? I really want a little wireless remote for the music on my phone. Or, on a larger scale, where can I find a Bluetooth manufacturer that I can pay to make such a device.
mx28JakeH1
Reply 4 years ago
simple Bluetooth wristwatch lol
pthrizzle
Awesome post, I just did one like this, but changed the charging circuit a bit.
jlang9
The 1.1+ versions of the Adafruit EZ-KEY have a much lower latency 25ms vs 110ms, new versions should be a solid 4x faster than what was used in this project.
