Bottle Lamp 2
About: I am IT professional, living in Bangalore, India. As new gadgets come out everyday, we indulge in spending significant time and money on these gadgets. And our kids are learning from us, they know how to use...
It is Christmas time, time to decorate home... In this instructable I will share how i recycled old Whisky bottle and transformed it into a simple bottle lamp
It you have the right tools, the build is simple enough to be completed in 4 to 6 hrs of lazy efforts
Step 1: What Do We Need ?
Material
  • an nice shaped Whisky bottle
  • 3/4" plywood plank ( we need 2 squares 3" x 3" )
  • LED copper string lights (5 mtrs)
Tools
  • Drilling machine
  • 6 mm drill bit for wood
  • Hole saw 35mm and 62mm
  • G clamps
  • PVA glue / fevicol
  • Wood polish
Step 2: Base
  • The whisky bottle came with a cap. I wanted to sandwich this in between two wooden pieces
  • Before we cut the wood, we must make the holes, this is more safe and easier
  • I am using "Stanleys hole saw", I first drilled few mm with the 62 mm and then through hole with 35mm diameter
  • Make sure the cap fits, mine was bit bigger, so I cut it using the 62mm hole saw
  • Now cut this piece into a 3" x 3" square and another of same size but without any hole
  • Sandwich the cap between two squares and glue it
  • Hold the wooden pieces in position using clamps for 2 hours
Step 3: Finishing Base
Sanding
  • Since wooden pieces were cut using a jigsaw, the edges are not aligned
  • I used a 60 grit sand paper and got all the edges aligned
  • Then used 180 and 220 grit to smoothen it further
  • I used natural wood polish to coat the base
Step 4: Bottle
  • The bottle did not have wide enough hole for the led string to enter, so used a soldering iron to make a wider hole
  • I did not want to remove the plastic as the cap would not fit and the neck wold become too small
  • At every stage, I tested that the bottle still can fit the cap
Step 5: Wiring
  • I drilled a 6mm hole from on of the edge till the cap
  • I had a 10 mtrs les string light, which had required register to limit current, so I just cut the led string light at 5mtrs length and save rest for another project in future
  • Do test LED string is still working
  • Pass the led string holes the base and the cap
  • Randomly fill in the bottle with the led string light
Light it up !!
I hope you liked the instruable and share your comments
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Jewelry Challenge
      Jewelry Challenge
