Broken Scissors Reparation
3,410
49
22
About: http://pavuk.7gods.org/
When your scissors brake you have few options what to do next with it. Probably the most sane idea, especially if you are dealing with "high" quality "Swedish" steel (see above), is to throw them out. And buy a new proper one. But where is the fun in that?
So after my scissors broke I chose to fix them.
Supplies:
Step 1: What I Used to Create Better and Nicer Scissors
For renovation i used (see photo above, starting from upper left corner clockwise):
  • two types of plywood for three layered handle (one plywood is thicker than the other, different colors of plywood results in better looking handles. Make sure that plywood used for middle layer is at least that thick as metal blade),
  • paper template (shape could be same as original handle, but it can be changed to suite better your needs. I tested new shape with a temporary cut cardboard handles (not displayed)),
  • scalpel (to cut paper template),
  • pencil (to draw paper template and to transfer shape from template to plywood),
  • double sided adhesive tape (to put plywood layers temporary together for sanding),
  • pliers (to turn screws and nuts on coping saw and to destroy old handles),
  • sandpaper of different grit (only one type is displayed, I used 60, 120, 240, 400, 1000 for this project),
  • spare saw blades (because they are easy to break, especially when not paying full attention during sawing),
  • wax (to lubricate the saw blade to make it move easier in the wood),
  • coping saw table with clamp,
  • coping saw,
  • drill,
  • and of course, original metal blades of the scissors.
Other thing used but not displayed in the picture:
  • Dremel rotary tool with cutting wheel and drum sander,
  • cardboard (to test new handles shape),
  • epoxy glue (suitable for wood and metal),
  • masking tape (to mask parts I did not want to expose to glue or lacquer),
  • clamps,
  • high gloss clear lacquer spray for surface finish (because it is easy to apply and it happened that I just had one).
Step 2: You Need to Break It First
Before handles removal be sure to copy shape of old handles to paper and mark where handles ends on metal blades so it is possible to position new handles properly. Then remove old plastic handles from the scissors' metal blades. I used Dremel rotary tool with cutting wheel and pliers to pry them away. To not damage scissors' final look be careful not to scratch metal during old handles removal.
Step 3: Cut It Out
Because those scissors are ambidextrous it is possible to use same template for both handles. I was not satisfied with original shape of the handles so I modified (widened) the shape a bit. To test the new shape I cut temporary handle from the cardboard and attached it to the blade to see how it feels and looks. Unfortunately I have no picture from this step, feel free to skip it if you are satisfied with old handles shape.
Take the paper template prepared in previous step and outline it on the plywood. Each handle is composed of three layers of plywood, outside layers are thicker and darker (I used beech), middle part is thinner and lighter (I used pine).
To cut the handle use coping saw. When cutting inside of the handle drill the hole first, pull the saw blade through and fix it in the saw. To make blade movements through wood easier wax the plate before use.
Put middle layer to the scissors blade (use mark you created in the previous step) and outline metal part on the plywood. When cutting the shape be sure on which side of the line to cut so the metal blade will fit the middle layer of plywood tightly. Make sure middle layer is same thickness as metal blade, sand it down if needed.
Use double sided adhesive tape to put three parts of the handle together. Sand both handles to the final shape, use as many grits as you wish to reach the desired surface finish. For rough sanding I used Dremel rotary tool with drum sander and I finished the sanding by hand with sandpapers of grit 60, 120, 240 and 400.
Of course it possible to sand the handles after they are glued to metal blades, but it is more complicated and there is a risk of scratching the metal and damaging the final look.
Step 4: Put It Together
After handles are cut out and sanded properly it is time to put everything together. To glue layers of plywood and metal blades together I used epoxy. Feel free to use any kind of epoxy you want, just be sure it is suitable for gluing wood and metal. My recommendation is to use one that has longer working time so you have time position everything correctly. Read the instructions how to use the epoxy. Use gloves, it is better for your hands to not to clean the epoxy from them after the work. Use masking tape if you are not sure if glue will not stick to clamps used to push glued parts together.
After you put everything together and clamp it properly, remove epoxy squeeze outs from the handles and especially from the metal blades. It is hard to remove hardened epoxy without risk of damaging the metal surface.
After epoxy cures use sandpaper to remove the excess from handles if needed.
Step 5: Finish
After gluing everything together and sanding off excessive cured epoxy I have applied few layers of high gloss clear lacquer to handles. I sanded the surface with 1000 grit sandpaper between applying the lacquer layers.
Be sure to apply masking tape to metal parts of the scissors before using lacquer.
In photos above you can see the final result. Nice, isn't it?
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    22 Discussions
    tacoman8
    1 year ago
    This is a nice looking solution, looks more comfortable to use than the original. You must be retired, sir, to spend all those hours improving a $4 scissors, lol.
    pavuktacoman8
    Reply 1 year ago
    Nah, it was just fun to do in a spare time :-)
    Eh Lie Us!pavuk
    Reply 1 year ago
    Big fan of what you did. Sure, our throw-away culture would expect you go buy another pair but fixing what is fixable is more important.
    Digital high-5!
    Overlord_Laharltacoman8
    Reply 1 year ago
    a good pair of scissors do not cost $4. more like $10-$20. more if its a specialty (like sweing) or better material (like titanium or diamond coated blade)
    the only $4 scissors you will find are the small kids pairs for school. or dollar store scissors.
    and i keep a small kids scissors in the car for when it is needed. (because these came with a sheth (blade guard) and i wont be too worried if they do break due to the heat)
    these car scissors are used for clipping coupons neatly, cutting some rope, or making a stress relieving cut in a bag that is tearing/fraying.
    Robbo_roberto
    1 year ago
    Sensational! Can't wait to try this. I have a pair of Wiess scissors that are about 30 years old that probably cost $50+ back then. Plastic handles have all cracked up. Couldn't bear to throw them out and have been looking for something exactly like this! THANKS! Will post my results when I've finished!
    Overlord_Laharl
    1 year ago
    thanks for this instructable. i have never had a pair of good scissors have a fractured handle
    my only issue with a good pair was in a pair with a rubber inlaid grip. where the rubber came off (im still using them).
    i am marking this as a favorite for when i need it
    poolonu
    1 year ago
    It's possible using them with both hand, but they are right-hand scissors by construction! :)
    CaitD1
    1 year ago
    I have a favorite pair with a broken handle, tried everything from super glue to duct tape...YOU found the answer. It is my project for today.
    Koolman60
    1 year ago
    EXCELLENT POINT MAKING THEM AMBIDEXTROUS
    gm280
    1 year ago
    Nice idea. I'll have to remember this. Thumbs Up!
    tytower
    1 year ago
    Lot of work . Perhaps use a piece of steel for the middle bit . Might last long enough to justify the work.
    Swansong
    1 year ago
    Beautiful work, they look great! Saving this for later. :) I've got a pair we need to fix. The puppy snuck them out of the bucket while I was working outside and chewed up the handle on one side. ^.^;
