Build Your Own Motor Driver
29,173
360
35
About: So, I got a bunch of LEDs when I was 8 or 9 something.
Hello everyone,
In this instructable we'll be making our own motor driver using transistors.
In my last attempt to use transistor as motor driver I was unable to control the speed of the motor using it.
But, Thanks to valuable comments from instructables users who suggested me to use PWM pins to control motor speed and to improve the circuit. So, this circuit is able to control motor speed using PWM pins, protect arduino and other electronics from back emf and electrical noise generated by the DC motor.
Supplies:
Step 1: Gather the Parts
  1. An Arduino
  2. A breadboard
  3. A 220ohm resistor
  4. A 2N2222 transistor
  5. A IN4001 diode
  6. A 0.1 microfarad ceramic capacitor
  7. A DC motor
  8. A 9V battery
  9. Some jumper or hookup wires
Step 2: Wiring
Hookup all the components according to the circuit diagram shown above.
Why we need a A 0.1 microfarad ceramic capacitor in parallel with the motor?
When DC motors operate they produce a lot of electrical noise, The main cause of this noise is the brushes of the brushed DC motor.
These noise can interfere with the sensors and even impair the micro-controller.
That's why we need a 0.1 microfarad ceramic capacitor in parallel with the motor.
Why we need a IN4001 diode in parallel with the motor?
When the DC motor is turned OFF or current being changed across the motor, The motor generates Back EMF.
This back emf can damage electronics or can cause data loss.
To counter this we need a IN4001 diode in parallel with the motor.
Step 3: The Code
Upload the following code to arduino.
The following code runs the motor at a Higher speed for 10 sec and then lowers the speed for the next 10 sec.
int MotorPin = 10;
void setup()
pinMode(MotorPin, OUTPUT);
void loop()
analogWrite(MotorPin, 200); //Any value between 0 to 255
delay(10000);//Wait for 10 secs
analogWrite(MotorPin, 100); //Any value between 0 to 255
Step 4: Done
Now Power the arduino and see your motor spinning with varying speeds.
Thanks for viewing.
Please write your questions or suggestions below.
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    35 Discussions
    Ishayu
    14 days ago
    Can I use a IN4007 instead of IN4001?
    AditiA8
    Question 8 months ago on Introduction
    Hi! Here you used a 9V source, if we wish to run a 200W motor at 48V, what all specifications will change? And to what extent?
    1 answer
    Anshu ARAditiA8
    Answer 8 months ago
    Hi, you'll probably need to use a MOSFET like an IRF640. With a different circuit.
    I would recommend using Digikey part search to find the MOSFET as per your requirements.
    IbrahimA196
    1 year ago
    hi
    i just want to know how you select 0.1 microfarad capacitor, if i'm going to use higher amps transistor how to calculate the required capacitor or it depends on the motor? also, do you suggest any further components for protection?
    Anshu ARIbrahimA196
    Reply 1 year ago
    Selection of capacitor basically does not matters.
    It's just a precaution. Just in case you are using this circuit with RC models or such. So that electrical noises doesn't interfare the RC signal.
    tim939
    2 years ago
    info-Sam, thank you for posting this! I am new to Arduino stuff and looking forward to building on this instruct able as I work towards creating a small bot as a hobby.
    rjmcnealy
    2 years ago
    Nice work. Could you please suggest components that would control a small 12 V water pump? The pump is 1.5 A at 12v
    Anshu ARrjmcnealy
    Reply 2 years ago
    Why don't you try relays.
    But you won't be able to control the motor speed.
    jimvandammerjmcnealy
    Reply 2 years ago
    Do you need to control the speed, or just turn it on and off? You'll need a higher power transistor, and a FET would be easier to drive.
    Anshu ARjimvandamme
    Reply 2 years ago
    I am controlling the speed too.
    Yes, but in this project I used small hobby DC motor that runs on a relatively small amount of current so I used general purpose transistor.
    Israeld7rjmcnealy
    Reply 2 years ago
    The componentes would be the same as listed, but 1.5 amps using 12 volts would need a decent power source. Look for an old router power supply or some speakers powers supply, if they are 12v and 1.5amps (or greater amp) they would make the job.
    BambiB
    2 years ago
    Massive overkill to use an arduino for this. If you just want to control speed, a 555 timer circuit is WAY cheaper (about a 5-10 cents). If you want to control various intervals, a dedicated processor (ATTINY24/45/85 or ATTINY 13 - less than $1) will do the job.
    For switching applications (PWM), especially in battery-operated circuits, a MOSFET is generally preferred over a BJT because it wastes less power.
    TheFireManBambiB
    Reply 2 years ago
    Of COURSE its "massive over-kill"..
    This is an INSTRUCTable.. it's meant to INSTRUCT or TEACH a process or idea..
    It's NOT meant to mini-max or optimize a production item...
    Indeed, the majority of the articles fall under the "teachable moments"...
    BambiBTheFireMan
    Reply 2 years ago
    Well, in that case, why not go out and buy a new MacBook, a USB to serial converter, an arduino and a motor. That way you could have the MacBook send instructions to the arduino, which could then control the motor.
    Oh wait!
    Why not hire someone full time at $100/hour to watch the MacBook, and use a timer to alert them when they should adjust the motor speed.
    Oh wait! Why not have a government department to set rules and conditions and regulations and...
    Part of learning is understanding when a "solution" makes sense, and when it doesn't. If you need programmable motor control, an arduino isn't a bad first approximation. But if you just need motor control - well, maybe you ought to put an ad on line for motor speed watcher guy positions.
    Francisco JavierC11BambiB
    Reply 2 years ago
    Hahaha! Really funny dude, Your sarcasm is great!
    #MacBookWatcher vacancy?- dial me
    CarlosMC
    2 years ago
    nice circuit, and very useful information. thanks for the detailed explanation about the need of use diode and capacitor... i'm a lot of cheap toy to make with this and arduino nano.
    toasterizer
    2 years ago
    I'm wondering is there a way to code it to run for 10 seconds, pause 10, run in reverse 10 seconds, rinse and repeat?
    ottojtoasterizer
    Reply 2 years ago
    It takes 3 more transistors and a bit more space on the breadboard. Look up references to H-bridge to get the details. You'll be using another output pin on the Arduino, and an input pin to switch directions. Also have to be careful about changing directions when the motor is running--you might let the smoke out of your electronics. Also watch out for the polarity on your electrolytic caps--they're exciting when you violate them!
