Build a Real Ray Gun at Home (Homemade Ray Gun or Burning Pulse Laser Pistol)
266,711
186
57
About: IF YOU HAVE QUESTIONS PLEASE EMAIL ME AT trevornestorslab@gmail.com Hello I'm Mad Scientist Trevor Nestor. If you like my instructables see my youtube channel! http://www.youtube.com/channel/UCksEFn8xaLP0...
Supplies:
Step 1: Getting Cameras
CALL ME AT 8059157065. I DON'T USE MY INBOX
For more cool projects, visit my youtube page: http://www.youtube.com/channel/UCksEFn8xaLP0z4rsiHa9zcA?feature=mhee
To begin with, you are going to need a ton of disposable cameras. Depending on how powerful you would like your ray gun to be, you will choose how many disposable cameras (though at a sufficient amount there is a ceiling to how much the pistol can pump out). Politely go to a nearby photo developing store and ask if they have any used disposable cameras.
From my experience, the store employees' willingness to cooperate is dependent on a few things:
1.) How old you look
2.) How much you look like you know what you are doing
3.) How dangerous your project sounds when they ask you what you need the cameras for
Once you have a big bag full of cameras, its time to start shucking! Inside each camera there are many useful components we will need. But before removing the outer plastic container, you must first remove the camera's battery, and have a thick piece of metal insulated from your hand. Use this to discharge the camera's capacitor very carefully by tapping the two pieces of metal jutting out from it. Once the capacitor is discharged and the battery is removed, the electronics are safe to touch. Remove them. I have attached a photo with the basic information on it. Though there are many different designs for disposable camera circuits, they all work similarly.
Step 2: Make a Capacitor Bank
Use a soldering iron to remove the capacitors from the camera circuits. Gather an even number of capacitors with the same ratings. Most capacitors will have a label telling you their designed voltage and capacitance. In the bank you are making, you need all of the same type of capacitor. Keep in mind that the more capacitors you add, the less life your flash lamp will theoretically have (though I have used over 20 100uF capacitors and mine continually works, but to be safe you should use much less). The amount recommended is between 4 and 10 120uF capacitors.
Use the soldering iron to wire half of the capacitors in parallel. Do the same with the other half in a different row. Tape the two rows together and connect the two rows in series.
MAKE SURE that when you are connecting in parallel, + terminals are connected to other + terminals and - terminals are connected to other - terminals! Failure to regard polarity with these flash capacitors will lead to all sorts of nasty things! A stripe on the side of the capacitors indicates NEGATIVE polarity.
Save one disposable camera circuit with the capacitor still in it. We will need it later.
Step 3: Power Section
On the circuit that you saved with the capacitor still in it, there should be a charge button on the disposable camera circuit. Make sure that it is set to charge ON. If yours forces you to hold the button to charge, solder the button connection so that it is always ON. On another circuit with the capacitor removed, do the same.
Get a 2x AA battery holder (usually $2 online) and solder the positive end from the holder to both the positive battery terminal on the circuit with the capacitor and the one without it. The terminal is where you first removed the battery from the disposable camera circuit. Make sure that you are observing the correct polarity!
Do the same with the negative end.
Refer back to step 2 for a simple labeled picture of the flash circuit.
Step 4: Wiring the Charging Circuits
For the raygun to work, all of the capacitors must be charged. The indicator light with the capacitor on the board that it was left in should blink almost immediately when turned on. Solder in switches to switch between charging either of the two rows of capacitors in the capacitor bank with the other board. Refer back to step 2 for a picture. The two different places the switch should switch to are labeled "Switch 1" and "Switch 2."
Remember, polarity is very important. So make sure the positive from the charging circuit is connected to the positive on the capacitors and vice versa.
NOTE: You will need to wire switches so that before switching between charging ROW 1 and ROW 2 the row that you were charging is DISCONNECTED otherwise there will be a big spark. Use HEAVY DUTY switches also. Touching the capacitor terminals at any time is DANGEROUS! Use adequate insulation. Similar insulation to what is found in disposable cameras should work fine (thick plastic).
Step 5: Ionizer and the SSY-1
You will need a laser head. I used an SSY-1 laser head off of ebay (approximately $100), but if you are lucky you can salvage it from a laser rangefinder.
Although the capacitors will be connected directly to the SSY-1 laser head at all times, the energy from them cannot flow through. First, the gas in the flashlamp must be IONIZED.
Refer back to step 1. Find where the Ionization coil is labeled. Desolder the metal on top of the ionization coil on the board that you left the capacitor in. Solder a hanging wire to it. We will use it later.
The SSY-1 has 3 wires:
1.) RED (goes to the POSITIVE on the capacitors, see picture on step 2)
2.) BLACK (goes to the NEGATIVE on the capacitors, see picture on step 2)
3.) WHITE (solder to the hanging wire from the ionization coil that we discussed)
Get a trigger button and solder the two ends of it to the flash trigger on the board in which you had left in the capacitor. Remove metal trigger bits from the other board.
Step 6: Optional Addons
Adding in a sound bit is optional, and you can get a recordable sound module from your local Radio Shack or electronics retailer. Glue everything together how you like it, but make sure NEVER TO LEAVE THE CAPACITOR TERMINALS WHERE YOUR HANDS WILL BE. An infrared lens may be useful in focusing the laser beam and can be used to burn holes in metal or causing air to break down into a plasma at the focus point (it will appear like a ball of light the size of a BB).
That's it!
Step 7: Author's Notes
Safety, Safety, Safety... Beating a Dead Horse to Stop Trolls and Flame Wars from Condescending Enthusiasts
On "Proper Eye Protection"
I know that I have discussed the necessity to shield one's eyes several times, but I cannot stress it enough! I cannot tell you about all of the senseless banter and condescending comments that I have received about the safety of this project and my apparent "lack of respect for the laser." Optics engineer “Sam” from a leading solid state laser enthusiast site who has had experience with these lasers has this to say: “What can be said, but that this is a fun little device. It's also the only part of an Abrams tank I will likely ever own. The SSY1 laser was used in the tank's rangefinder. These ND:YAG lasers have been replaced with an eye-safe kind, (but) these surplus lasers are great for educational purposes. It was extremely easy to get the laser to work the first time. A child could do it. At this point the usual thing should be harped on again, tirelessly ad nauseam. We have all heard it before. It's not so much that some idiot will look into the laser, it is more likely that a reflection could come back from an unintended target and strike the eye. one should use laser safety glasses when working with this unit. If one does not have them, closing the eyes during firing is better than nothing.” If you do not have access to infrared safety wear, at least cover your eyes! I cannot tell you how many times people have mistaken this advisory with "you don't need infrared safety goggles" and argued with me about how I lacked "respect for what I was dealing with." I am arguing feasibility and necessity, not optimization. Even some of the trolls that I have dealt with have eventually agreed that closing eyes and/or shielding with the hand is adequate (not optimal) protection!
On Capacitors:
Capacitors need to be discharged by an insulated piece of metal, try a screwdriver with a rubber/plastic handle. Do not touch the metal portions of the capacitors at any time! Use as much insulation as possible. One troll I was dealing with suggested that 800v was too much for the flashlamp to handle, though it can handle 900v! In addition, the flashlamp does not stay ionized before all of the capacitors have a chance to discharge, and the q-switch limits how much goes into it (though I do not recomment pumping too much into the laser, SSY-1's have a wide range of performances).
On Posting a Dangerous Tutorial:
This project is no more dangerous than building a tesla coil, using MOT power supplies, or many other hobby projects that exist with tutorials online. As long as sufficient safety precautions are taken, there should be no problem. I hold no responsibility for the abuse or partial reading of my tutorial. Some trolls have suggested that somehow solid state laser DIY'ing is a "secret knowledge" that should not be made available to the public. Hogwash! The SSY-1 is a well-documented laser. Whether or not a MOT is dangerous at a distance is not the issue (almost all dangerous devices have instances when they aren't dangerous). Even professionals sometimes make mistakes. It is no easier or harder to observe necessary safety measures for using a MOT device as it is to use an SSY-1 device. MOTs can be lethal if not handled properly. Any laser device can pose a hazard to bystanders. Recently, one story in the news was that a guy with a laser pointer forced a helicopter to land! This is not the sort of activity I suggest fostering. If you follow the necessary safety precautions, just as you should for any other dangerous tutorial, no problems should arise. One story I've also heard was that a guy was experimenting in his garage with high voltage and set his house on fire. There are plenty of ways that any dangerous project may pose a hazard to others, yet, if handled in a safe way, should be fine. (Unless you wish to also ban archery, shooting skeet, campfires, AC power (as suggested by Edison because of the dangers of AC over DC), laser pointers, cars, planes, and pretty much any other item that can possibly pose a hazard). I am saying that unsafe projects should not be banned for the sake of them posing a danger such as tesla coils or MOTs (which DO pose just as strong a hazard), as long as the user is following safety precautions. In the words of Sam, the leading SSY-1 hobbyist:
"these surplus lasers are great for educational purposes."
On Video:
Sorry, but hey, what's a guy to do when he is poor and has to pay for college and can only afford a handy cam and a small place to live? XD
On Memes Appearing Online:
Yeah they're here
    • Classroom Science Contest
    • Arduino Contest 2019
    57 Discussions
    HAIL_ZANZIBARNightmare77
    Reply 7 months ago
    No. The laser in an optical CD drive is designed for low voltage continuous running.
    EricC313
    1 year ago
    hi
    i want make this and with my father (he is an Electronics Engineer ) help do some upgrade plz if anyone have more details send for me
    my E_mails:
    Eric.crow@yahoo.com
    jack.asndlr@yahoo.com or my telegram link https://t.me/Stanley_Pines or my twitter : https://twitter.com/_Eric_winter_
    Triton7777
    2 years ago
    okay forget the last two comments, im curious as i have a wide variety of capacitors, the biggest being 200v, then going down to 10v. I am wondering how much voltage will be at the end of the line if i line them all up in order of: 10, 15, 16, 26, 36, and 200v x2. i am also wondering if i should dissasemble a burning laser from japan as a cheap alternative to the ssy-1 head.
    Triton7777
    2 years ago
    hey i was wondering by any chance would one be able to use larger flash capacitors and stronger lasers along with a bigger power source
    Triton7777Triton7777
    Reply 2 years ago
    just in case ur wondering i have a 1500uf flash capacitor
    Makeoscopy
    3 years ago
    I would love to find one of these laser heads. If anyone would like to sell one, contact me. I already have loads of camera capacitors!
    Nader79Makeoscopy
    Reply 3 years ago
    Check on ebay you could get one less than $ 100 just make sure its including the lamp and the rod, also try to get the rod already with mirrors at the ends for less hasle
    Re: Nader
    MakeoscopyMakeoscopy
    Reply 3 years ago
    I have found one for a good price on http://mi-lasers.com/product-category/other-lasers...
    Make sure you show 36 items per page. I am wondering based on research how many volts of capacitors you added. Research showed that the laser's life is decreased going over 750 volts. I have seen camera circuits w/ 150 volts so I will use 5 of those. Surprisingly, the inside of the laser has a flashtube not unlike the disposable camera's, just way bigger. I might buy a small laser rod like the one in the SSY-1 and test it out with multiple camera flashtubes.
    Nader79
    3 years ago
    If any one wants capacitors you can get any volt with any size for good price you can get them from ebay, usually they offer discount on price as a pack of 10 or more.
    Nader79
    3 years ago
    I meant the diameter of the rod is small about 2 mm I guess
    Nader79
    3 years ago
    Nader79
    3 years ago
    Just got a question, what's the best way to hook up the flash tubes from the disposable cameras if I want to align them parallel to the laser rod? I have a 50mm long rod but very small did the seller told me I can use a standard flash from the disposable camera unit by using one or two capacitors which should be enough to fire the rod. I'll wait for a reply
    Re: Nader
    Makeoscopyweargle
    Reply 3 years ago
    YAG means Yttrium Aluminium Garnet. Nd:YAG's are Neodymium-doped. The SSY-1 is one of the many YAG lasers available.
    Now I'm wondering if there are differences between coilgun and railgun... It works the same I think, the coilgun what I had made, has also a capacitorbank of disposable camera's and it works by flashcircuit of it: https://m.instructables.com/id/DIY-How-to-make-a-coilgun-from-disposable-camera-/
    I think that your explanation is very clear and interesting! :)
    M3rknootsdeliciouscupcake
    Reply 3 years ago
    Actually, a railgun is a sniperrifle, only its mounted on a rail system and not handheld. A coilgun uses magnets or electric magnets to propel metal projectils. If look up a youtube channel called laser gadgets if that didnt help.
    Well, a railgun fires a projectile by using electricity to create a magnetic field, and a coilgun does this. If you really have made a railgun, get that ible out there i'd like a railgun
