Build a Window Seat With Storage
540,130
619
65
What's a bay window without a window seat?  An unfinished and underutilized space waiting to be transformed!  Building a window seat is a basic "build-in" project and here's how you can do it.
Step 1: Plan It Out
Since bay windows are not all created equal, you'll need to measure the angles of the walls.  The standard is 135° but there are other variations and the "as built" angles will probably be different.  Walls are never perfectly straight, corners are never perfectly square...you get the picture.  In the end, you don't have to be super exact since a piece of trim will cover the gap between the wall and the seat, but the angle needs to follow the wall.
How deep you'd like your seat to be is the next question.  I build this one to be 24" deep so we could use a rug runner instead of cushions.  Runners are 21"-23" wide.  How deep your seat is will also determine how wide it will be.  At 24" deep, mine turned out to be 8' 5" long.  Since sheets of plywood are 8' long it would have been easier to make the front shorter than 8' long and let the depth work itself out.  In that way you could rip an 8' piece of plywood for the front whereas I used 2 pieces.
On www.askthebuilder.com I found a sketch of the framing for a window seat (pic 2).  The height they recommend is 19" with a 21" deep seat.  You can see from the drawing that a window seat is actually a short floating wall achored to 2x4 cleats on the wall.  The front can be wood, sheetrock or other materials since it is only decorative.  The one thing I did differently from the drawing was to place the 2x4s on edge as opposed to typical wall framing.  This makes a sufficiently strong wall and also creates a bit more storage space inside the bench.
Step 2: Supplies You'll Need.
Your vision of how you'd like your window seat to look will also determine the supplies you need to acquire.  The possibilities range from basic plywood  to sheetrock to expensive trim to reclaimed wood.  The basic frame, however, will not vary greatly and I used two 10' 2x4s and four 8' 2x4s.  For the front, I used a 4'x4' sheet of bead board and around 24' of 1x4 poplar for the trim.  One 4'x8' sheet of 3/4" plywood is more than enough for the top.  3/4" is the minimum thickness for the top since people will be sitting on it.  To strengthen the front edge of the top, I ripped 1 1/2" poplar strips from 3/4" thick stock on my tablesaw.  To finish the junction of seat top & wall, I used 12' of 3/4" cove molding.  And lastly, 3/4" quarter round was used along the bottom of the front and a couple short pieces of baseboard were also necessary to finish the trim.
Other things you'll need for this project are construction adhesive (Liquid Nails), silicone caulk, wood putty, sandpaper, primer, paint, 3 1/2" wood screws and nails.  A trim nail gun and air compressor are ideal and worth renting if you don't have them.  A miter saw is also very nice for the many angle cuts.  In addition, you'll need the usual carpentry tools such as a level, stud finder, hammer, nail punch, circular saw, etc.
You'll see as we go along that I used pocket screws for constructing the 2x4 frame and also the poplar trim.  Pocket screws are a quick and easy way to make strong tight joints and are applicable to virtually every type of woodworking.  If you aren't using pocket screws, check out http://www.kregtool.com/pocket-hole-jigs-prodlist.html and join the fun!
I don't hate painting if painting is my project (e.g. paint the kitchen).  What I hate is building my project and then having to paint it.  I get that "You did it!" feeling and then realize I have to paint it.  To remedy this problem I paint before I start my projects when possible.  While I'm scratching my head and measuring and figuring, I run to the shop periodically to lay down a coat of paint.  It only took me about 30-45 minutes to paint the boards and plywood each time.  As it dries, I go back to scratching and starring blankly at the walls.  When the project is built, just dab some wood putty in the holes, touch up the paint and you're done.  It is so much easier it's insane.
Step 3: Building the Frame
To begin framing the box, use a stud finder to locate the studs inside the wall.  Normally studs are 16" apart on center, however, there is likely to be some variation under the windows.  With the stud locations marked, mount a 2x4 along the back wall using 3 1/2" wood screws.  The top of this board is 18 1/4" off the floor so the final height will be 19" when the 3/4" plywood is added.  Make sure the 2x4s mounted to the wall are level.  There is no reason to miter the 2x4s in the corners as there is no benefit to doing so.  These ends will be hidden from sight and mitering the ends would have no effect on strength.
The next step is to remove the baseboard and build the front wall frame.  I chose to build the wall next so I could insure it was parallel to the back wall.  Alternatively you could mount the other 2x4s on the side walls, however, this seemed a simplier way to determine where the wall would actually be located.  Both the top and bottom 2x4s have 45° cuts on both ends to match the wall.  The front wall is only 18 1/8" tall so shims could be placed underneath it to bring it to level with the wall mounted 2x4.  True to form, my floor had a crown in the middle and it was necessary to shim both ends.
My design was for 4 front panels so I placed five 2x4 blocks in the front wall.  These blocks are located behind where the poplar vertical trim pieces will be which allows for nailing.  I'm not sure why I didn't have the furthest left & right blocks all the way at the ends of the wall, but I ended up adding a block on each end for trim nailing (pic 3).  Note the pocket screw holes in the blocks.
The final steps are to add the 2x4s on the side walls and add some bracing for the top.  The side 2x4s have a 45° angle on the front end so it can butt up to the front wall.  Once they are screwed to the walls using 3 1/2" wood screws you can also place screws through the front wall and into the side 2x4s to lock the corner. Three 2x4 were installed between the front and back walls using pocket screws.  The middle 2x4 is centered and the outer 2x4s are located where the end of the lid will rest.
Lastly, this is a very good time to reinstall the baseboard & quarter round on the inside of the box.
Step 4: Building the Faceframe
For a project of this size, I find it easier to build a faceframe in my shop as opposed to installing each board individually.  Although it is not important in this case, faceframes also add considerable strength.  I build the faceframe to be 18" tall to accomodate the floor crowning which made the stiles (vertical pieces) roughly 11" long.  When this is installed, any gap will be along the floor and covered by the quarter round.  Since the faceframe is shorter than the wall, it can be lifted flush with the top of the 2x4s before you nail it.
Picture 2 shows the finished faceframe.  Doesn't it look nice painted!!  You may also notice that the 2 inside rectangles are slightly smaller than the outside rectangles.  This is by design to make the box look less symmetrical and "exact".  When something you build is very precise and regular, it doesn't look natural.  Nature is much more random than it is regular which can make a large symmetrical piece appear odd and less pleasing to the eye.  When I have the opportunity, I try to add a bit of asymmetry to projects.  No one will be able to tell you why they like it better, but they will like it better.
Step 5: Cover the Front Wall
Now that the faceframe is ready, it's time to cover the front of the box.  I don't have pictures of this step but it's very straight forward.  Apply a bead of Liquid Nails construction adhesive to the front of the 2x4s and nail the beadboard/plywood to the 2x4s.  The only edge which will be visible is along the top lip so position the beadboard flush with the top of the 2x4s.  Installing the faceframe is essentially the procedure.  Run a bead of Liquid Nails on the back of the faceframe and nail it in place.  Fill the nail holes with wood putty and caulk the seams with silicone window caulk.
Step 6: Building the Window Seat Top
The top of the window seat is comprised of 4 pieces of 3/4" plywood with a 1 1/2" strip of trim along the front edge.  Pic 2 shows the shape of the pieces.  I began by cutting the rear piece which is 5" wide with 45° angles on each end.  After a bit of trial and error, I found 5" to be sufficiently wide to allow the lid to rest against the window and remain open.  This piece could be wider, but not much narrower or the lid will fall down all the time.
Next I measured the distance from the front edge of the 5" piece to the front of the box to get the width of the lid.  Since the piano hinge requires almost 3/16" space I cut the lid to 19" which was the actual distance measured.  This gave me 3/16" overhang on the front of the box when the hinge was installed.  I chose to make one large lid, however, you could easily make two.  Alternatively, you could also make a solid top and doors on the front.  In this case, I made one lid which extended to the center line of the outside 2x4s.  In this way, the side edges of the lid rest on the 2x4 for support.  The lid measures 19" x 51".
Before you glue & nail the 5" back piece in place, it's much easier to go ahead and attach the lid to it.  This is a job you don't want to do from inside the box.  Picture 3 shows how a piano hinge is attached.  A piano hinge is a long continuous hinge which is very strong and a perfect solution for this project.  PIano hinges commonly come in 30" and 48" versions and 48" would have done the job.  I chose instead to use two 30" hinges so the entire gap would be filled.  This was easier than mortising a space for the 48" hinge.  Piano hinges can be cut to the desired length using a hacksaw or portable grinder.  The hinges I used have sides that are 3/4" wide so I mounted them flush with the bottom of the 3/4" plywood.  In picture 4 you see that the hinges protrude a small bit but it's not noticeable when the rug in laying on top of it.
With the 2 pieces hinged together, there's a couple things that need to be done before permanently attaching them to the box.  First is to mark out and cut the 2 smaller side pieces.  This is most easily accomplished with the lid & back piece in place so you can measure size.  Leave a 1/16" gap between the lid and the side pieces in case the wood expands.  Plywood doesn't move much but a little gap is needed.  Once the side pieces are cut, the second thing is to attach the 1 1/2" trim to the front of the lid and 2 side pieces as in picture 5.  Some wood glue and nails is sufficient.
Now put it all together with some Liquid Nails and some solid nails.  Lay down a bead of Liquid Nails on the 2x4s which are under the 5" back piece and nail it in place.  Then do the same with the 2 side pieces.  Make sure to avoid getting the adhesive under the lid --especially when positioning & nailing the side pieces.  The last picture is the 3/4" cove molding along the top edge of window seat.  I like cove molding here but you could also use quarter round or a larger piece of trim.
With everything in place it's time to touch up the finish by filling nails holes with wood putty, caulking the seams and giving it another coat of paint.
Step 7: All Done!
I hope this instructable has been helpful to you.  A window seat is pretty easy to build for such a large project and there's a lot of bang for the buck too.  In it's simplest form, this seat can be built for around $100.  Mine was a bit more because of the poplar trim and bead board on the front.  Regardless it's been worth every penny and it's great to have some extra storage in our kitchen.
Thanks for looking!  I look forward to any questions or comments.
4 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
65 Discussions
kbbaktha
3 months ago
Brilliant Build Tutorial. I liked it very much and is added to my next project list to be carried out in our home. Thanks
Marti9t9
8 months ago
Another thank you from me for this instructable. I would not have tackled this job only for it. I got a crazy quote from a carpenter so I bought some tools and made it for cheap. AND I still have the tools afterwards!
My wall was more curved than angular which worried me. I made a template from cardboard before I took the plunge in cutting the semi-circle. Anyway thanks again!
IMG_20180802_210216.jpgIMG_20180802_200559.jpgIMG_20180802_202030__01.jpgIMG_20180802_200922.jpg
kentdvmMarti9t9
Reply 8 months ago
Wow that looks so nice! Love the curved wall and all the windows. Your window seat looks so professional too. Well done. Glad it was helpful!
Jwaldorf2
Question 9 months ago
I'm thinking about building something similar and I have a question. For the top and bottom horizontal 2x4's of the front of the bench, did you screw them in to studs on the side walls or are they just secured together with the 5 vertical 2x4's and then to the back wall with the 3 horizontal pieces?
kentdvmJwaldorf2
Answer 9 months ago
If you have a stud right there I would screw into it but I'm pretty sure I just attached to the 2x4s. The bottom horizontal 2x4 I believe I anchored to the floor with pocket screws and then into base plate within wall.
Jwaldorf2kentdvm
Reply 9 months ago
I have tile floor so I can't screw into that. Also, the area has straight up 90 degree angles so my horizontal bottom piece will be perpendicular to the side walls. Will just drilling pocket holes and securing the ends to the base plate be sufficient to hold it in or is there a better way for me to secure the bottom? Thanks for the help.
kentdvmJwaldorf2
Reply 9 months ago
It will be enough to hold vertically either way, but if you can push the center of the front wall in then you might want to reinforce it. Options would be adding bracing against the back wall or beefing up across the bottom of the wall. I doubt you'll need to do anything with the 2x4 bracing the top back to the wall.
TyD12
1 year ago
I took the base of your plans and added a little extra. Thank you for all of the help!!
kentdvmTyD12
Reply 1 year ago
Very nice! Glad the plans were helpful.
Basp
2 years ago
Great instructable! I'm looking forward to start making one of these for my own house. One question: do you find the center 2x4 essential? I realize it provides support, but I don't like the way it puts a beam in the middle of the storage space. Would using just 2 2x4s and possibly a thicker board for the top provide enough strength for one or two people to sit on it?
kentdvmBasp
Reply 2 years ago
Thanks! I think you need it or need to add strength with a thicker top as you suggested. You could also make 2 smaller doors between the 3 2x4s as they are currently arranged.
Lody38
3 years ago
Great post! Any words of advice on a curved bay!? Really want a window seat but unsure on how to start with a curved bay ?
kentdvmLody38
Reply 3 years ago
Cutting the top is the trickiest. What I would recommend is to cut a piece of cardboard an 1" smaller than you need and tape it in place so there's a gap. Then use stiff card stock strips to bridge the gap and tape them to the top of your cardboard. This lets you make an exact copy of the wall and any of it's quirks. Lay that facedown on the back of your top and trace the outline and the should match very closely especially with trim. For the trim, the easiest is to use vinyl trim since is bends easily and you won't need to make relief cuts. Can you post a pic of the curved bay?
PaulS126
3 years ago
Great job! Looking forward to a starting a window seat of my own. This is a BIG help.
Thanks
PaulS126
3 years ago
Thanks
ChristopherJames
3 years ago
I've always liked the idea of sitting at a window seat with a whiskey and a cigar and the fact that it'll double up for a storage unit is a pretty awesome idea too. Not to mention I think a lot of wives and daughters will really like to curl up and read a book in the corner somewhere. Definitely a project for the home to consider sometime in the coming year!
MarkSindone
3 years ago
Storage is always welcomed around the house regardless of the size. I have utilized almost every inch of my apartment including the walls and ceiling to their maximum capability to maximize space as much as possible. I have also tried clearing out some closet space for the sheets but there are just too many. This window seat with storage looks perfect even for the rooms.
JamesP167
3 years ago
I've been looking at this project. What is the need or reason for the 2 X 4 in the center where the lid will close? I'm just wondering if I want to put in longer items in here? Is it structural? A way around it?
kentdvmJamesP167
Reply 3 years ago
It's structural. The framing gives support to prevent sagging when someone sits on it. It also supports the lid and provides it a place to close. You could run another 2x6 down the middle length wise and block it to the back. The back half would be solid and the front half a hinged lid.
ShripriyaS
3 years ago
love this post! I'm considering taking up this project in summer. My house is carpeted. so should i rip off the carpet under the seat or build the seat over the existing carpet?
