Build a Battery Pack Using PVC Pipes
65,749
138
58
Using a 1 1/4 PVC tube, make a D-cell battery pack for 7.2 V at 17,000 millamp hours. This is a nice tubular battery pack.
This instructables was made at Tech Shop , visit techshop.ws
Step 1: Bill of Materials
PVC pipe, 1 1/4" x 60cm in length
1 1/4" PVC pipe caps
1 1/4" test plugs
6 D-cell batteries
wire (~20 gauge)
battery contacts (negative ends I use for both, the spring I find has a better contact)
urethane sealant  or another epoxy that will stick to pvc + metal + wood..
pvc cement
clamps
solder iron
Drill press
scroll saw or router
2x4 wood block, 1.5"
rubber (1/8")
Step 2: Cut the Pvc Pipe
Cut the PVC pipe down to 2x23 cm pieces.  Sand the inside if it has a rough edge. You should have a spare piece, which you'll use later.
Step 3: Make a Hole for the Power and Ground Wires
-Place the cap on the PVC tube as far as it goes on, on 1 PVC pipe. Mark a spot on the pipe right at the seam where the cap ends.
-Drill a hole in this using a drill press. The hole should be just bigger than the thickness of your wire so that the wire can come through.
-You can take the caps off (if you need assistance pulling it off, slide a battery in the tube and bounce it up and down so it lands on the inside of the cap a few times. This should pop the cap off).
Step 4: Wire the Tubes in Series
-Place the tubes so that one hole faces up towards the ceiling, and one faces towards the far wall (ie the holes are pointing at 90 degrees from each other).
-Hold the test plug next to the pvc tube as if it were fully in place. Mark a dot at the seam on the INSIDE of the pipes (ie the spots where they face each other). See the photo for reference.
-Drill a hole at each dot.
Step 5: Solder Wire to 2 Battery Connects
Prepare the battery connects that will go on the caps:
Solder long wire onto two of the battery connect springs. This will be the power and ground wires that extend from your battery. If you like to use different color wire, ie red + black for power and ground, do one red and one black.
Step 6: Glue on the Battery Connects
-Sand the whole inside of the pvc caps.
-Bend the four corners of the square mount slightly upwards, attached to the springs from the battery connects. This will help it sit in place in the bottom of the inside of the cap.
-Glue the battery connects in the bottom of the cap by applying epoxy to the inside of the cap and to the back of the battery connect.
-Put the connect down into the bottom of the cap and press firmly.
-Let it dry.
Step 7: Put the Caps On
Put the two caps + battery connects that have been prepared onto the PVC pipe.
-First, feed the wire coming off the battery connects into the holes that you cut at the seam of the cap / pipe. Feed them from inside outwards.
-For a permanent seal,  sand the outside of the PVC pipe where the cap will touch when put on the pipe. Apply PVC cement onto both surfaces of the inside of the cap and the outside of the pipe.
-Slide the cap on firmly all the way.
-Let it dry.
Step 8: Wire It Up
-Cut a piece of wire about 6".
-In the holes that you cut where the test plug sits, thread it from the inside of one tube to the outside, then through the outside of the other tube extending out through the inside.
-Solder the battery connects onto the end of one wire.
-Adjust the length so that the connect that you just soldered comes out through the battery tube about half an inch.
-With the tubes parallel, and the caps flush against each other, The unsoldered wire end coming out the other pipe hole, cut this at about 3 inches from where it comes out of the hole, so it sticks out of the pipe a little bit.
-Solder on the final battery connect here.
-Now your two pipes are sort of joined as one unit.
Step 9: Prepare the Batteries
If the batteries are snug when you put them in the tubes, you might have trouble just sliding them in and out. If so, wrap a cord around the FIRST battery you will enter the tube. Wrap two cords around it using scotch tape.
Step 10: Attach a Rubber Piece to the Connects
-Cut a rubber circle a bit smaller than the pipe's inner diameter.
-Epoxy this to the battery connect.
-Let it dry. Once finished, put batteries in the tubes. Put them in series, so that towards the red (positive) wire you insert three batteries with the nub (+) facing down, towards the pvc cap, and the opposite in the other tube. Put in the spring + rubber to touch the batteries. Put the test plugs and test the voltage of the power and ground wires that are protruding. You should see about 7.2 volts.
NOTE: I used the flat connectors for the battery's positive side, but I found the spring ones work much better.
Step 11: Cut a Piece of Wood As a Stabilizer for the Two Torpedo Like Battery Tubes
-On the end edge of the 2x4, Mark the center line that goes through lengthwise. Mark 3/8 inch on either side.
-Hold the spare PVC piece flush against the edge of the 2x4, so the low point hits the edge of your 3/8" marking and comes into the corner of the wood. Trace this.
-Do the same thing on the bottom half of the edge of the 2x4.
-Use a scroll saw or a router to cut away the round part you just traced, leaving you with an hourglass shaped piece of wood.
-When you try to fit this flush against the pipe, if it has air space, try to sand this down with a rounded file.
Step 12: Glue Your Pipes Flush Together and Caulk the Holes
-Mount your pvc pipes with the wood in place  between them, flush against one another at the cap and the pipes flush against the wood.
-Apply epoxy sealant to each surface where the pipes are flush, adhering them together. Clamp them in place.
-Apply caulk to the holes where the wires protrude.
NOTE: I am using three pipes because my application is as ballast in the bottom of a boat, and I filled one with ballast.
Let it dry.
Now you have a tubular torpedo 7.2V D-cell battery pack.
    • Classroom Science Contest
    • Arduino Contest 2019
    58 Discussions
    cyberfury
    5 weeks ago on Step 12
    The test plugs alone are about $14,- a pop, you could buy a 20,000mAh battery pack for the price of 3 of those plugs alone. Which makes this a pretty ridiculous 'hack'.
    prini
    6 years ago on Introduction
    hi got a question have you tryed making a 12v battery pack?
    klaurson
    6 years ago on Step 12
    How about using rechargeable cells? Adding a 12V or 16V lighter socket and a USB port could make this into a useful travel pack for gear.
    kage_no_mozaikuWazzupdoc
    Reply 6 years ago on Step 12
    really, it's not that much greater on the difficulty scale and it's also more environmentally sound since rechargeable batteries last longer. for those who wish to go green with this project, klaurson's idea is top notch.
    XboxModzkage_no_mozaiku
    Yea. I would much rather use rechargeable batteries for this. Going through all this work just to house throw -way batteries seems a little much, not to mention the epic waste of good PVC pipe, LOL.
    Eric Forman
    If you put this in your luggage I guarantee you'll end up missing your flight :)
    If you want this to look less like bomb-like (and waterproofness is not a requirement) I'd suggest drilling large holes through the pipes, staggered at 90 degree angles, to make "windows". That way someone looking at it will see batteries inside.
    WazzupdocEric Forman
    Reply 6 years ago on Introduction
    I think you are thinking WAY beyond this project, which is a simple, water-proof battery pack. Check out her other aquatic posts. I love her water-snake!
    Eric FormanWazzupdoc
    Yes...I was thinking way beyond this :)
    I need a 12 volt supply for a homemade field portable ham radio and this instructable is a fantastic idea! I'm going to scale this down for 10 AA NiMH batteries but I also want to avoid being molested by the TSA when they find a box full of electronics and pipes in my bags. My usage does not need to be waterproof.
    I'm doing a portable ham rig myself. Here's where I'm going:
    a. 1 or 2 12V 5AHr rechargeable gel cells (parallel for 2 = 10 AHr)
    b. 100W 12VDC->120VAC inverter for power strip holding plugin transformers for various wall warts for peripherals.
    c. RaspberryPi Linux box running WSPR and/or another ham interface.
    d. Yaesu 817 ND
    e. West Mountain radio/computer interface for digi modes.
    Hopefully fully, back-packable with apprt. antennas.
    My "monitor" is a $20 B/W 5" TV with RCA inputs and audio.
    So far so good. See KB3VLW@gmail.com
    leglessEric Forman
    Then just use clear acrylic tube instead of an opaque plastic tube. All the benefits of the original plus one can see inside it.
    ~Frog~
    I think the step about wood blocks can be eliminated by adding PVC connectors / as collars towards the other end ... would balance tubes ... imho .. ~Frog~
    Denger
    Thanks for the 'structable and especially the test plug link. I have another application which will use those, and it's nice to see the variety available.
    graydog111
    I am missing something......I can not find anything explaining the plugs on the ends with the V shaped wing nuts. What are they?
