Build Your Own Countdown Regatta Box
9,345
79
18
An countdown "box" is a box with horns. When a regatta starts the box sounds the horns at predetermined intervals: 5 minutes before the start, 4 minutes before the start, 1 minute before the start and at the instant of the start. There are two types of sequences: 3 minute and 5 minute. In this instructable me and Chris LaBorde will show you how to build one by yourself. Because marine salt and water environment of boats, the box must be at least splash proof. Using the box will release two volunteers.
Supplies:
Step 1: Components Needed
This photo shows an LCD shield and one realy module.
Arduino UNO from dfrobot
One LCD Shield from dfrobot.com (see photo)
Two relay modules from dfrobot.com
One YUASA deep cycle 12 V 7A battery
One charger for the Battery of 8A
One piezo buzzer
Three push connect only switches
One toggle switch
One on/off interrupter
One splash proof box
A set of two horns and a compressor with the air tubes.
One Tupperware small
Cables, shrink tubes, solder (optional)
Step 2: How to Charge
1. Open the box to charge the battery when needed.
When battery charging push the red toggle switch to charge mode. When not charging push back to 'normal'
Step 3: How to Use
The big green button starts the countdown.
The small button sounds the horn manually (override in case of emergency)
The yellow button inside the box toggles the sequence type between: three minute countdown or five minute countdown.
Step 4: How to Wire
1. Stack the lcd shield on the arduino board.
2. Connect the relays inputs to pins D11 and D2, connect relay D11 to piezo and D2 to the compressor.
3. Connect the big green button to the lcd push buton 'LEFT' (solder cables to the switch pins in the LCD board, the push button will override the lcd 'LEFT' button)
4. Connect the yellow push button the the lcd push button 'SELECT' (same as 3)
5. Connect the small green button between compressor + and battery + poles (to sound it manually)
6. Connect battery to charger via the red switch and baterry to compressor and arduino power input via the 'normal' position of the red switch.
Step 5: The Splash Proof Box
Find a splash proof box with rim seal. Use foam at the bottom so nothing is loose. Once the wiring is done put the Arduino and relay modules inside a Tupperware for added waterproofing. Make holes for the tubes that power the horns. And fix the horns as in the picture.
Step 6: Programming the Arduino
To program the Arduino: Download the Arduino IDE to your laptop. Upload the code to the Arduino with a usb cable. Source is here: https://github.com/orioli/ollie/blob/master/produc... the time units is 100ths of second and the time resolution < 10ms approx.
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
18 Discussions
harrikentomatoskins
Reply 4 years ago on Introduction
The layout is Chris design. Now we are working on a leaner version with no battery. We shoudl attach a sticker that says "sounds hazard - wear protection" LOL
Taorasbk
Question 4 months ago on Introduction
I’m building the Ollie regatta horn. I’m having trouble uploading the code (sketch 8a912bc) to the Arduino Uno. It keeps giving me multiple errors that a function definition is not allowed before ‘{‘ token.
it’s a straight upload of the Audrini.ino file (not the “production” version.).
It creates an error every time there is an opening bracket ‘{‘ in a definition line, such as at
Line 138. void mymenu(){
or
Line 171. Void activate_sound(int a) {
I’m surprised the compiler doesn’t accept the audrini.ino file. I even reloaded the Audrino IDE software and tried again on both the audrino.ino and the production files found on Instructabless.
any ideas?
1 answer
Jose OriolLTaorasbk
Answer 15 days ago
Becuase raspberri pi has become so convenient to program -- I think its better to move to Pi... in the next iteration I ll try to implement in pi. What version of arduino are you using?
RyanS29
3 years ago
Love this and would like to make one for my club. I'm good with the wiring, but not code writing. Your code for the 3 minute start seems to be different than what we use. We use 3 long blast at 3 mins, 2 at two mins, 1 long 3 short at 1:30, 1 at 1 min, 3 short at 30 secs, 2 at 20 secs, 1 at ten secs, and count down from 5 secs to start. Could you lead me through changing the code to achieve this. Thanks for any help
harrikenRyanS29
Reply 3 years ago
modify the vector
unsignedlong sch_3[] <-- indicates horn or buzz time in 10x ms units
h_or_b3[] <-- code: buzz = 0, short horn (sh) = 1, long horn (lh) =2 extralong horn 3
AlR51harriken
Reply 9 months ago
Ryan's 3 min. ver should be the standard 3 min start. Also, we and most clubs roll over the 5 min start, with no break. The start horn is the next class's 5 min horn, and it continues that way until stopped.
Can you modify code for each change?
RyanS29AlR51
Reply 9 months ago
I made the code changes for the 3 minute start and works well. Had no reason for the rolling five as our club doesn't use. I will need to see if I can find which drive i stored it on. If I locate I will post.
AlR51RyanS29
Reply 9 months ago
Thanks Ryan. A rolling 5 should be standard code, and in your case just turn it off after first start. We start 5 classes on Thurs, and JAM and Race on any weekend. I'm not a coder, but should be just a couple of lines?
Silverheels
1 year ago
I have succesfully loaded the program onto the Arduino UNO3. The problem is where do i solder the pushbuttons to on the LCD screen. I know that the select and left switches do all the nessasary functions, I just need to wire the momentary push buttons and am not a computer expert but the soldering is no problem. help me with a simple diagram, or do I solder to the pins on the back side of the board behind the switches? It appears that each switch has 4 pins or is A0 used with other connectors on the LCD board.
dan_2759Silverheels
Reply 1 year ago
Solder your momentary Switches to the back of the LCD Shield on the points next to the board edge. You don't need to do anything with A0
Ciabe1960
1 year ago
I notice that you've not bothered with a schematic... is there one?
NeilB95
2 years ago
This is great but our club uses a combination of lights and horn. I wonder if I could modify this to do our start sequence?
Advance Notice - Two lights flashing and repeated hornApprox 1 minute before warning signal (short duration)
Warning- One light, single horn and flag 5 minutes before start
Preparatory - Two Lights, single horn 4 minutes before start
One Minute - One light, single horn 1 minute before start
Start - No lights, single hornAt start
PcplodNeilB95
Reply 2 years ago
Hi I am also wanting to build start regatta system to include lights and horn, very similar to your start sequence New to electronics and will be buying first UNO
if you move forward with your project let me know :-)
DavidW69
3 years ago on Introduction
Thanks so much for posting this. Going to make one for our J/22 class and if successful one or two more for our junior program. Im pretty good with mechanical things but have no experience with electronics. I've tried to source all the things on your list - but there are a lot of options for each item. Would you mind proofing my shopping list to be sure Im buying the right components? Here is a link to the list I've assembled with SKU's on each item (you can comment on the document)
https://docs.google.com/document/d/1jrpwLfU0zDGcn7...
Also I couldn't find the "on/off interrupter" for the toggle switch -there are many options - could you give me the details on the toggle switch?
Thanks again
Dave
