CNC Drum Plotter
39,145
376
33
About: 55+ years in electronics, computers, and teaching ... now retired.
This instructable describes an A4/A3 plotter made from a section of plastic pipe, two BYJ-48 stepper motors and an SG-90 servo. Essentially it is a flat-bed plotter rolled up into a drum.
One motor rotates the drum while the other moves the print-head. The servo is used to raise and lower the pen.
This plotter has a number of advantages over a traditional flatbed plotter:
  • significantly smaller footprint
  • only requires one linear guide rail
  • simple to construct
  • cheap
An on-board interpreter accepts the gcode output from Inkscape.
Communication with the plotter is via a bluetooth link.
The plotter is compatible with the CNC Graphics Tablet described in my instructable https://www.instructables.com/id/CNC-Graphics-Table...
While not a precision instrument the accuracy of this plotter is satisfactory for its intended purpose of transferring watercolor outlines on to paper.
Step 1: The Circuit
The circuit comprises an Arduino UNO R3 microcontroller and a custom shield on which the discrete components are mounted. Power is applied via an external 5 volt 1 amp regulator. The average current is around 500mA.
The BYJ-48 stepping motors are attached to PORTB (pins D8,D9,D10, D11) and PORTC (pins A0,A1,A2,A3). The SG-90 pen-lift servo is attached to pin D3.
The 560 ohm resistors, which may be omitted, provide a measure of short-circuit protection to the arduino should something go wrong. They also make it easier to wire the shield as they act as "jumpers" across the supply rails.
The 1k2 and 2K2 resistors prevent damage to the HC-06 bluetooth module [1] by dropping the 5 volt output from the arduino down to the 3.3 volts.
[1] Unplug the HC-06 bluetooth module when uploading code to the arduino via the USB port. This will avoid any serial port conflicts.
Step 2: The Linear Drive
The linear drive is made from a length of 3mm x 32mm aluminium bar, a strip of aluminium sheet, and four small ball-bearing pulleys.
The aluminum is available from most hardware stores. The U624ZZ 4x13x7mm U-groove pulleys are available from https://www.aliexpress.com
Simple hand tools are all that you require. Cut the aluminium bar to suit your plotter dimensions.
The motor assembly
Mount the BJY-48 stepping motor through the bar at one end and attach a GT2 20 tooth, 5mm bore, pulley to the motor shaft. Now mount another GT2 pulley at the other end of your bar such that the pulley is able to rotate freely. I used a 5mm diameter tubular (radio) spacer and a 3mm bolt to achieve this.
Now loop a length of GT2 timing belt around the pulleys. Join the timing belt ends by means of a half-twist such that the teeth interleave and fix with a cable tie.
Finally attach the carriage assembly to the timing belt with a cable tie.
The carriage assemby
The carriage assembly is made from a strip of aluminium sheet [1] on to which the U624ZZ pulleys are bolted. If necessary use a 4mm washer to space the pulleys from the aluminium sheet.
The pulleys, which have a 4mm groove, straddle the aluminium bar top and bottom such that there is no vertical movement yet the aluminium strip moves freely left and right.
To ensure that the carriage runs freely, mount the top two pulleys first then, with the pulleys sitting on the bar, mark the positions of the bottom two pulleys. The holes for these two pulleys may now be drilled. Use a small "pilot" drill first to prevent the larger 4mm drill from drifting.
Prior to bending the alumium strip into a "U", drill a hole top and bottom to suit your pen diameter. Now complete the bends.
Attach the timing-belt to the carriage assembly by means of a cable tie and 3mm bolt between the top two pulleys.
The pen-lift assembly
Attach an SG-90 servo to the top of the carriage assembly using one or two cable ties.
Drop your pen down the two holes you have drilled. Ensure that the pen slides up and down freely.
Fasten a "collar" to your pen such that the pen is just clear of the drum when the servo is in the pen-up position.
[1] Aluminium may be cut by scoring both sides of the sheet with a sharp knife (box-cutter) then flexing the cut over the edge of a table. A few wiggles and the the sheet will fracture leaving a straight break. Unlike tin-snips this method doesn't kink the aluminium.
Step 3: The Drum
The drum comprises a section of plastic pipe with two wooden end-plugs [1].
Use a compass, set to the inside radius of your pipe, to draw the end-plug outlines. Now cut around each outline using a fine blade saw ("coping", "fret") then custom fit each end-plug with the aid of a wood rasp. Fasten the end plugs using small counter-sunk wood screws.
A 6 mm engineering bolt through the center of each end-plug forms the axle.
Drum Dimensions
The drum dimensions are determined by your paper size. A drum diameter of 100mm supports A4 portrait and A3 landscape. A drum diameter of 80 mm will only support A4 landscape. Use as small a drum diameter as possible to reduce the inertia ... the BYJ-48 motors are only small.
A drum diameter of 90mm is ideal for A4 portrait and A3 landscape paper as the opposite edges, when wrapped around the drum, overlap by approximately 10mm which means that you only have one seam to tape into place.
Rotating the drum
Each axle passes through an aluminium end bracket such that the drum is able to rotate freely. End float is prevented by means of a GT-2, 20 tooth, 6mm bore, pulley fastened to the axle at one end. A continuous GT-2 timing belt links the BJY-48 geared stepping motor to the drum. The motor requires a pulley with a bore size of 5mm.
[1] Plastic end-plugs are available for most pipe diameters but were rejected as they fit over the pipe rather than inside and the plastic tends to flex. They would probably be okay if a continuous axle was used instead of the bolts ... but then you require some method of fixing the axle to the end-plugs.
Step 4: Construction Tips
Ensure that the pen travels along the center of the drum. This may be achieved by cutting the corners out of the wooden supports. If the pen is off-center it will tend to slide down the side of the drum.
Accurate drilling of the two pen holes is important. Any wobble in the pen guide or carriage assembly will cause wobbles along the X-axis.
Don't over-tighten the GT-2 timing belts ... they just need to be taut. BYJ-48 stepping motors don't have a lot of torque.
BJY-48 stepping motors often exhibit small amounts of backlash which is insignificant along the X-axis but is of concern when it comes to the Y-axis. The reason for this is that one rotation of the Y-axis motor equates to one rotation of the drum, whereas the pen-carriage requires many turns of the X-axis motor to traverse the length of the drum. Any Y-axis backlash can be eliminated by keeping a constant torque on the drum. A simple method is to attach a small weight to a nylon cord wrapped around the drum.
Step 5: Bresenham's Line Drawing Algorithm
This plotter uses an optimised version [1] of Bresenham's line drawing algorithm. Unfortunately this algorithm is only valid for line slopes less than or equal to 45 degrees (i.e one octant of a circle).
To get around this limitation I "map" all XY inputs to the first "octant", then "unmap" them when it's time to plot. The input and output mapping functions to achieve this are shown in the above diagram.
Derivation
The remainder of this step may be omitted if you are familiar with Bresenham's algorithm.
Let us draw a line from (0,0) to (x1,y1) where:
  • x1=8=horizontal distance
  • y1=6=vertical distance
The equation for a straight line passing through the origin (0,0) is given by the equation y=m*x where:
  • m=y1/x1=6/8=0.75=slope
Simple Algorithm
A simple algorithm for plotting this line is:
  • int x1=8;
  • int y1=6;
  • float m=y1/x1;
  • plot(0,0);
  • for (int x=1; x<=x1; x++) {
  • int y=round(m*x);
  • plot(x,y);
Table 1: Simple Algorithm
xmm*xy
00.750 0
10.750.75 1
20.751.5 2
30.752.25 2
40.7533
50.753.754
60.754.55
70.755.255
80.7566
There are two problems with this simple algorithm:
  • the main loop contains a multiplication which is slow
  • it uses floating point numbers which is also slow
A graph of y versus x for this line is shown above.
Bresenham's Algorithm
Bresenham introduced the concept of an error term 'e' which is initialised to zero. He realised that the m*x values shown in table 1 can be obtained by successive addition of 'm' to 'e'. He further realised that y is only incremented if the fractional part of m*x is greater than 0.5. To keep his comparison within the range 0<=0.5<=1 he substracts 1 from 'e' whenever y is incremented.
  • int x1=8;
  • int y1=6;
  • float m=y1/x1;
  • int y=0;
  • float e=0;
  • plot(0,0);
  • for ( int x=1; x<=x1; x++) {
  • e+= m;
  • if (e>= 0.5) {
  • e -= 1;
  • y++;
  • plot(x,y);
Table 2: Bresenham's Algorithm
xmee-1y
00.75000
10.750.75-0.251
20.750.5-0.52
30.750.252
40.75103
50.750.75-0.254
60.750.5-0.55
70.750.255
80.75106
If you examine the algorithm and table 2 you will observe that;
  • the main loop only uses addition and subtraction ... there is no multiplication
  • the pattern for y is the same as for table 1.
But we are still using floating point numbers ... let's fix this.
Bresenham's (Optimized) Algorithm
Bresenham's floating point algorithm can be converted to an integer form if we scale 'm' and 'e' by 2*x1 in which case m=(y1/x1)*2*x1=2*y1
Apart from scaling 'm' and 'e' the algorithm is similar to that above except:
  • we add 2*y1 to 'e' each time we increment 'x"
  • we increment y if e is equal or greater than x1.
  • we subtract 2*x1 from 'e' instead of 1
  • x1 is used for the comparison instead of 0.5
The speed of the algorithm can be further increased if the loop uses zero for the test. To do this we need to add an offset to the error term 'e'.
  • int x1=8;
  • int y1=6;
  • int m=(y1<<1); //constant: slope scaled by 2*x1
  • int E=(x1<<1); //constant: 2*x1 for use in loop
  • int e = -x1; //offset of -E/2: test now done at zero
  • plot(0,0);
  • int y=0;
  • for (x=1; x<=x1; x++) {
  • e += m;
  • if (e>=x1) {
  • e -= E
  • y++;
  • plot(x,y);
Table 3: Bresenham's (Optimized) Algorithm
xmEee - Ey
01216-80
112164-121
212160-162
31216-42
412168-83
512164-124
612160-165
71216-45
812168-86
Once again the pattern for y is the same as in the other tables. It is interesting to note that table 3 only contains integers and that the ratio of m/E=12/16=0.75 which is the slope 'm' of the line.
This algorithm is extremely fast as the main loop only involves addition, subtraction, and a comparison with zero. Multiplication is not used apart from when we initialize the values for 'E' and 'm' using a "left-shift" to double the values of x1 and y1.
[1] This optimised version of Bresenham's algorithm is from a paper "Bresenham Line and Circle Drawing", copyright © 1994-2006, W Randolph Franklin (WRF). His material may be used for non-profit research and education, provided that you credit him, and link back to his home page, https://www.ecse.rpi.edu/Homepages/wrf/Research/S...
Step 6: The Code
Download the attached file into a folder of the same name then upload it to the plotter using your arduino IDE (integrated development environment).
Unplug the HC-06 bluetoorh module before attempting the upload. This is necessary to avoid a serial port conflict with the USB cable.
Third Party Code
In addition to the above .ino code you will need the following software packages which are free / donation-ware:
Instructions for installing and using each of the above third party packages may be found in my article https://www.instructables.com/id/CNC-Robot-Plotter/
Step 7: Menu
Make a bluetooth connection with your plotter using "Teraterm".
Switch your "caps lock" on as all commands are in upper case.
Type the letter 'M' and a menu should appear as shown above.
The menu is reasonably self explanatory:
  • M (or M0) brings up the menu
  • G0 allows you to send the pen to a specific XY co-ordinate with the pen raised.
  • G1 allows you to send the pen to a specific XY co-ordinate with the pen lowered.
  • T1 allows you to position your pen over your 0,0 co-ordinate. Type 'E' to exit.
  • T2 allows you to scale your drawiing. For example "T2 S2.5" will scale your drawing 250%. The default scale is 100%
  • T3 and T4 allow you to raise or lower the pen.
  • T5 draws an "ABC" test pattern.
  • T6 draws a "target".
  • T7 draws a set of radial lines, the purpose of which is to verify that Bresenham's algorithm is working in each of the eight "octants"
Notes:
  • all pen moves use the drawing scale set using menu option T2
  • the "17:" and "19:" numbers are the "Xon" and "Xoff" terminal handshake codes from the arduino interpreter.
Step 8: Calibration
The values for X_STEPS_PER_MM and Y_STEPS_PER_MM are for a 90mm diameter drum.
Values for other drum diameters can be calculated using the following relationships:
  • the circumference of the drum is PI*diameter
  • 2048 steps equals one revolution of each motor shaft
  • one revolution of a GT-2 pulley equates to 40 millimeters linear movement of a timing belt
Another method is to enter the following commands,
  • G1 X0 Y100
  • G1 X100 Y100
then measure the length of the resulting lines and "scale" the values for X-STEPS_PER_MM and Y_STEPS_PER_MM
Step 9: Gcode Preprocessing
This plotter only requires four of the Inkscape gcodes (viz: G0, G1, G2, G3). The code will execute significantly faster if we remove all unnecessary gcodes and comments.
In order to do this you need a copy of "Notepad++". This free text editor contains a "regular expression" search engine for finding and removing unwanted text. Notepad++ is available from https://notepad-plus-plus.org/download/v6.9.2.html
Open the file to be modified with Notepad++ and position your cursor at the top of the file.
Select "View/Show Symbol/All Characters" followed by "Search/Replace..." from the top menu bar.
Click the "Regular Expression" check box (see 1st image) and enter each of the following code sequences into the search box.
Click "Replace All" after each entry:
  • ^M.*$
  • Z.*$
The above regular expressions remove all % symbols, all comments shown in brackets, all M codes, all Z codes and the codes which follow.
Now click the "Extended Expression" checkbox (see 2nd image) and enter the following code sequence:
  • \r\n\r\n\r\n
This expression removes the unwanted carriage-returns and line-feeds created by the first sequence.
Save your file under a different name using "Save As".
Done.
Step 10: Results
This plotter was built as "proof of concept" and never intended to be perfect. Having said that the results are not too bad. They definitely meet my design goal of transferring watercolor outlines onto paper.
The first three images are the built-in test patterns T5,T6,T7 respectively.
The "Hello World !" pattern was sent to the plotter via bluetooth. A "pre-processed" copy of this file is attached.
Step 11: Code Update
The code for this plotter has been updated to Drum_Plotter_V2.ino.
Changes from the original Drum_Plotter.ino include:
  • smoother pen positioning
  • now recognises G02 gcode instructions (clockwise arcs)
  • now recognises G03 gcode instructions (counter-clockwise arcs)
The attached diagram outlines my method for calculating the arc angle.
Step 12: Drum_plotter_v3.ino
A code update for "CNC Drum Plotter" is attached.
"drum_plotter_v3.ino" fixes a minor bug that affected the plotter accuracy.
Change history
Version 2:
  • Bi-arc curves added
Version 3:
The following functions were rewritten to address a minor bug that affected the plotter accuracy.
  • (int) replaced with round() in the move_to() function.
  • draw_line() function "octant" search algorithm improved
  • The interpreter now uses string functions rather than pointers which simplifies the design. For example we can now search for "MENU" rather than look for the letter 'M' then extract the integer number that follows. This allows you to personalize the plotter with your own commands.
Step 13: Drum_plotter_plotter_v4.ino
16 January 2017:
The code for this drum plotter has been further optimised. Additional features have been added.
The changes include:
  • faster draw_line() algorithm
  • matching move_to() function
  • step counters
  • minor bug fix
For further details read the comments within "drum_plotter_v4.ino" attached.
  Click here   to view my other instructables.
  • Gardening Contest
    Gardening Contest
  • Party Challenge
    Party Challenge
  • Arduino Contest 2019
33 Discussions
Fedegarage
2 months ago on Step 13
Hi, i dont have Arduino uno but a Arduino mega with ramps 1.4 and 2 step Motor 24v.
Is Your program compatibile? Can you help me?
lingibFedegarage
Reply 2 months ago
I am not familiar with the Arduino Mega so in answer to your question ... probably.
From what I have read most Arduino shields are compatible. My software should compile and run providing the pin-outs are the same.
You will also need to rework the software if you choose to use 24 volt stepper motors as different motor controllers will be required.
The electronics will also have to be reworked to avoid applying more than 12 volts to the Arduino.
ErwinM5
9 months ago
Where can i find Teraterm, is this a android app please
Kind regards
lingibErwinM5
Reply 9 months ago
TeraTerm is a PC application available from https://osdn.net/projects/ttssh2/releases/
A list of all code, and installation instructions, may be found in Step 6 of this instructable.
An alternate terminal program that is specifically designed to work with my plotters may be found at https://www.instructables.com/id/CNC-Gcode-Sender/. I recommend using this application as it is able to transfer data at a higher rate which significantly reduces your plot times.
zencuke
1 year ago
Nice design. Some enhancement suggestions:
1) Add pins for continuous feed paper and let the drum push it back and forth. Then it would draw images as long as you wanted. I used to draw images 10 feet long by 11 inches wide on a continuous feed plotter. You would need to add some rollers to hold the paper against the drum both to keep it from lifting off the pins and keep the paper tight under the pen.
2) Replace the pen with an Exacto knife and you have a vinyl cutter.
shawnalfarozencuke
Reply 1 year ago
I actually have an old school plotter that i want to do just what you describe. Im trying to use the original rotary encoded DC motors for X Y, and a solenoid with an encoder as well for Z. Im hoping to use a Teensy3.6 for the brain and maybe a KFB2.0 (arduino Mega with RAMPS all in one board) with Marlin. Im completely a newb but i have been learning alot about it. just need help putting it all together, software wise
lingibzencuke
Reply 1 year ago
Thank you for your comments :)
The plotter was built as proof-of-concept. If I were to redesign this plotter I would use stronger motors and add a step-up belt drive to rotate the drum ... this would eliminate the need for a drum tensioner.
Other than that your ideas would work ... plus you could make the drum as long as you like.
lingib
2 years ago
See step 13 of this instructable for drum_plotter_v4.ino
lingib
2 years ago
Further improvements have been made to the code.
See step 12 of this instructable for drum_plotter_v3.ino
lingib
2 years ago
The code for this plotter has been updated.
See step 11 of this instructable for Drum_Plotter_V2.ino
CelioS
2 years ago
Really Nice! makes me recall old days when i worked with drum plotters! Very good instructable, please continue sharing your thoughts made real.
lingibCelioS
Reply 2 years ago
Glad you liked it :)
Tesla619
2 years ago
Is the lettering supposed to be not sharp or is that that way the text is
lingibTesla619
Reply 2 years ago
Several reasons for the lettering
(1) wobbles due to backlash in the motor gears.
(2) small motors don't like a lot of belt-tension. Changes of direction must take up any belt slack before anything moves. That can be fixed using larger motors (which have a higher torque) and matching controllers.
(3) "play" in the linear guide.
(4) ball-bearings not used for the drum
(5) my interpreter ignores the I,J biarc Inkscape information for determining circle centers. It simply plots a line from point to point, rather than an arc, which accounts for the slight truncated look.
Items (1) to (4) are purely mechanical and easily fixed $$$$
Item (5) requires a software patch which I am currently working on. Instead of plotting a line between two points when it encounters a curve, a series of additional points will be introduced such that a true arc is plotted. I will upload the new .ino code to this instructable once it has been tested.
As is, this plotter meets my requirement of transferring watercolor outlines onto paper.
Tesla619
2 years ago
Ok, can this be used to attach a laser engraver to it ?
I've seen laser engravers on CNC machines that would take a wine bottle and engrave.
lingibTesla619
Reply 2 years ago
The linear guide is pretty solid and would probably carry the weight of a laser assembly.
As mentioned the mechanical side needs to be improved and biarc curves need to be added to the interpreter if you are looking for a professional result.
