Remove Candle Wax With Hot Water
46,517
168
22
About: Making and sharing are my two biggest passions! In total I've published hundreds of tutorials about everything from microcontrollers to knitting. I'm a New York City motorcyclist and unrepentant dog mom. My ...
I’ll show you the easiest way I know for removing candle wax so you can reuse the jar. Besides your candle, you’ll need a chopstick and some hot water. I’ve seen folks suggest a method using a freezer and a knife, and I’m here to tell you there’s a safer, easier way!
Step 1: Poke Some Holes
Use your chopstick to poke holes in the wax so the water can more easily get to the bottom of the jar.
Step 2: Pour Hot Water
Pour in your hot water. It should be just off the boil— if it’s not hot enough, it won’t get the job done. The water starts to melt the wax, which floats to the surface. Enjoy the show while it lasts, then let it cool down for a few hours.
Step 3: Dump After Cooling
Eventually all the wax pools on top and solidifies again as it cools down. Then you can just scoop it out and dump the wax. Use a strainer or paper towel to prevent chunks of wax from going down your sink.
Step 4: Clean Up and Enjoy!
If your jar has labels you want to remove, soak it in soapy water for an hour or more. The labels and any excess wax should come off with a sponge, otherwise you can rinse it with another blast of hot water.
Now you’ve got a new juice glass, or some craft supply storage. Let me know how you’d use your candle jar in the comments.
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Jewelry Challenge
      Jewelry Challenge
    22 Discussions
    christine828
    1 year ago
    WARNING: Don't ever let the hot wax go down your drain. I did, and had to have the plumber come An expensive and embarrassing mistake!!
    HowardT12
    2 years ago
    Gotta remember this one! Thanks.
    Ungenious
    2 years ago
    Love the GIFs! Thanks for sharing.
    TracyW68
    2 years ago
    I just use wax cleaner. Works Ann's smells awesome!
    TracyW68
    2 years ago
    I use candle wax cleaner..works like a charm Ann's smells great too
    fixfireleo
    2 years ago
    why not just microwave it, pour out the wax then wash with hot, soapy water?
    bekathwiafixfireleo
    Reply 2 years ago
    I couldn't microwave my jar because the base of the wick is made from metal.
    JoseC176bekathwia
    Reply 2 years ago
    ...uh maybe grab a pair of pliers and pull the metal out? Then microwave it and wash it with warm soapy water?
    EmmitSfixfireleo
    Reply 2 years ago
    first, the wax might overheat and catch fire. second, it will still leave a layer of wax in the jar.
    Zaacharia
    2 years ago
    Don't throw the wax away - save your dryer lint in those tiny paper cups and drip the wax over it - perfect fire-starter.
    BeckyJoMZaacharia
    Reply 2 years ago
    a small piece of waxed paper (which used to be used a lot more when I was a kid-than what I'm aware of now ) or even the white paper that meat is wrapped in after butchering, etc. > makes a wonderful fire / trash fire starter-also ;-) .
    KronoNaut
    2 years ago
    Thank you for this. A much easier and safer method than I was doing.
    onemoroni1
    2 years ago
    I do the microwave method. I dig out the wick metal and just melt it and pour it out. You will burn anything in the microwave if you want. Use common sense.
    royhchiu
    2 years ago
    I using similar method, except instead of just pouring hot water onto the wax, I "double boil" to raise the water temp.
    Rebou
    2 years ago
    What a great idea, I shall certainly use this easy looking method in the future.
    thepoisonivy
    2 years ago
    This is smart and simple. Thank you! I would, however, advise that anybody reusing the jars for something food related be careful; lead is often present in glass used for decorative candles.
    andrej
    2 years ago
    some labels goes off with the oil - just spill some oil on peace of paper towel, attach it to label and let it soak.
    coryalex
    2 years ago
    So simple! I love it!
    I used to heat them in the oven and toss out the wax... but that still wasn't perfect, and I ran the risk of burning myself or making a mess.
    This is so safe and easy. Thanks for sharing! :)
    AlainaZ
    2 years ago
    What a clever solution. I usually melt it over the stove and pour it into the trash.
    The brand candle I use makes perfect little bowls for olives, crackers, etc for my dinner parties
