Cardboard Bluetooth Speaker
1,274
13
11
About: There is no greater harm than that of time wasted - Michelangelo Buonarroti
In this instructable I will try to show you how to make a simple but very cool cardboard bluetooth speaker.
My first instructable was the inspiration for this project.
https://youtu.be/F-B0r1T3isM
Very easy project, only few tools needed. I used a lot of recycled pieces to build it.
The sound is amazing for a cheap cardboard speaker!
Step 1: Materials
Thick Cardboard Sheets
2x 15w 8ohm speakers
12v 18650 li-ion battery pack
HX-3S-FL25A 3 SBMS with balancing function
2x10w PAM8610 Amplifier
On/Off switch
Bluetooth module
5v DC-DC Buck converter
Power Jack socket, 2.1mm Connection
Step 2: Speaker Box
Use a precision cutter to cut the carboard :
2 pieces 17cmx17cm (side panels)
2 pieces 17cmx26cm (top and bottom)
4 pieces 17cmx24,5cm (front and back -double)
6 pieces 2cmx22cm (speaker box handle)
Cut round holes for the speakers in both the front panels
Use a hot glue gun to join the cardboard sheets. Use it also for the speakers.
Make it airtight.
Step 3: Electronics
I made a 12v battery pack with li-ion 18650 cels - 3S2P
I added the hx-3s-fl25a-a BMS module because it has over discharge voltage protection and balancing function.
The PAM 8610 amp works with 12v. For the 5v bluetooth module I used a DC-DC 5v buck converter.
Step 4: Finishing
Use the hot glue gun to attach the 12v charging connector and all other electronics, amplifier, battery pack, bluetooth module.
Make two holes on top of the speaker box and attach the handle.
Use paint to make the front panel black.
Use glue to attach a piece of black cloth on the front panel.
I also used a piece of self adhesive bass insulation cotton on the double-back panel and a 10cm long 1inch bass reflex tube on the front. I don't know how this helped but the speaker sound is great :)
Done :).
I hope you will try to make one and write a comment about it
Sorry for my bad english!
Remix Contest
This is an entry in the
Remix Contest
    • Epilog X Contest
      Epilog X Contest
    • Paper Contest
      Paper Contest
    • Organization Contest
    11 Discussions
    markgrogan
    21 hours ago on Introduction
    This looks like a toy speaker or a recycling project children would bring to school. I am truly amazed that it actually works. I guess it isn't at all about the outlook but it is about making sure your main objective is eventually achieved. The physical aspect of projects shouldn't be made as the main focus in order to achieve great success.
    ImpactDIYmarkgrogan
    Reply 20 hours ago
    Hello! This speaker can produce great sound. It was a huge surprise for me. I made it for my son but now I used more than any other speaker, and I have a few :). The sound is close to the 80's speakers. And it plays 48hours on one charge at moderate volume :).
    UdyRegan
    7 days ago on Introduction
    If people only knew just how easy it is to create really useful things in your home, I think we would all save a lot of money…. That's what instructables are for isn't it? This is a really great build - thanks for sharing!
    ImpactDIYUdyRegan
    Reply 7 days ago
    Thank you ! I hope this instructable will help someone. :)
    ImpactDIY1234567guy
    Answer 8 days ago
    Hello, I will make a new schematic and post it here. I hope it will help you!
    ImpactDIYfitpamsy63
    Reply 8 days ago
    Hello, the speakers and 18650 cells were recovered.
    Cardboard Sheets - 0$
    2x 15w 8ohm speakers - recovered -0$ (15-20$ new)
    12v 18650 li-ion cells - recovered- 0$ (about 5$/piece new)
    HX-3S-FL25A 3 SBMS with balancing function - 7$
    2x10w PAM8610 Amplifier - 5$
    On/Off switch - 0,5$
    Bluetooth module -3$
    5v DC-DC Buck converter - 3$
    Power Jack socket, 2.1mm Connection - 0,5$
