Cardboard Tool Bag
6,449
64
12
About: I wb in Belgorod Russia. In 2002 I graduated from Belgorod STU mechanical engineering and CAD. In 2004 I'v defended the dissertation "CAD for ball mill". I am a lecturer in BSTU. My hobby is 3D and...
Usually we need a lot of tools when create something hand made. If we are at home it is very easy to get everything you need (screwdrivers, hummers, nuts, drills) from appropriate places (shelves, toolboxes, workshops, under a sofa or in a refrigerator :-). Another way is to do something outdoor – in a country side, during a car trip, on a picnic at last. I advise to make a cheap TOOL BAG using CARDBOARD pack. You need only a few hours to make it but the result will be useful for a one or two seasons.
Step 1: Tools and Materials
  • cardboard sheets (4 mm thickness);
  • rulers (school size (0.3 m) and long (0.5...1 m));
  • pencil;
  • paper knife;
  • awl;
  • scissors;
  • cardboard bender;
  • PC, printer and 5 A4 sheets to print base drawings.
Step 2: Printing Base Drawings
So you need to have 3 drawings: Body, Butt_end, Rib. You can download appropriate drawings from the next locations: variant 1 (google drive), variant 2 (yandex drive). All dimensions are in millimeters.
Step 3: Transferring Drawings to a Cardboard
Some parts ('Body' and 'Ribs') we need to draw on cardboard sheets manually. For the 'Butt Ends' I recommend more convenient way – to print drawing on plain paper and then transfer it to cardboard using awl according to a following sequence: 1) put the cardboard on the old wooden board; 2) put the drawing on cardboard; 3) make holes in key vertexes through the paper using awl; 4) remove the paper drawing from the cardboard; 5) connect holes on the cardboard using ruler and pencil.
Step 4: Cut Parts Out of Cardboard
Step 5: 'Body' Bending
To execute all bend operations we will use special tool – Cardboard Bender according the following sequence: 1) Put the cardboard part on the wooden work base; 2) Draw path on the cardboard surface; 3) Move the Bender's Roller along the path with appropriate pressure to reduce the thickness of cardboard plate in a contact area; 4) Bend part along the 'compressed' path.
Also to execute bending it will be helpful to use long rule.
Step 6: 'Body' and 'Butt Ends' Connection
Step 7: 'Ribs' and 'Body' Connection
Step 8: Use It!
Organization Contest
This is an entry in the
    • Remix Contest
      Remix Contest
    • Epilog X Contest
      Epilog X Contest
    • Weaving Challenge
      Weaving Challenge
    12 Discussions
    tomwall1969
    13 days ago
    What advantage does a disposable toolbox have over a permanent one? I am genuinely curious.
    nml235ltomwall1969
    Reply 12 days ago
    Toolbox from the shop costs about 30$ and do the same job ;-)
    maxman
    18 days ago
    Have you ever made one out of that plastic stuff they use for yard signs? That would be water proof.
    doer_1
    13 days ago
    Before assembly, brush the surfaces with glue ( Elmers. Titebond, Gorilla, etc) (Be sure to allow for the extra material when cutting holes) cover it immediately with an already cut to size old shirt, allow to dry, assemble. It will last more than a short time...
    misterxp
    17 days ago
    Great idea. Good emergency box for various things. Thanks for sharing
    sageclouddancer
    17 days ago
    make one that can carry groceries from the store
    maxman
    18 days ago
    Wow. Somebody could make and sell these.
    pikwitonei
    19 days ago
    Great thinking outside the box!
    rayp1511
    20 days ago
    That's impressive, well done !
    So were not going to talk about the Bulldozer ? :)
