Carving Aladdin's Lamp Out of a Moldy Log (2019 Version)
About: Me and My Dad's YouTube channel is about creating secret/puzzle furniture in a fun and interactive way. We thoroughly enjoy working together and hope to create many more projects in the future that will hope...
Seeing as the new Aladdin movie is coming out this spring, dad and I decided that it was time for a mini break from all of our complex projects. While we thought that this little build would be quick and easy, we later came to find out that carving wood is just as hard as making something with a secret compartment!
READ FIRST: VIDEO DISCLAIMER
Bit of a disclaimer here, but most of our videos from now on are transforming into a mix of entertainment/informational/vlog format. These are the videos that dad and I enjoy making the most SO IF YOU LIKE WATCHING INFORMATIONAL VIDEOS ONLY, DON'T BOTHER WATCHING THE VIDEO BELOW.WHILE IT DOES CONTAIN PLENTY OF INFORMATION ON HOW TO CRAFT A WOODEN GENIE LAMP, IT IS MOSTLY FULL OF ENTERTAINMENT BASED CLIPS. YOU HAVE BEEN WARNED!!!!!
Supplies:
Step 1: Materials
Affiliate Links
Step 2: Log Flattening
Since we were dealing with a round log, we had to create four flat edges around it with our chainsaw so that it was easier for us to manage on our bandsaw. Just a quick tip though, cutting logs like this is much easier when the logs are pinched between something. I had my little brother just hold the logs with a rake so that they stayed more stationary.
Step 3: Bandsaw Rough Cutting
Once we had our flats cut on our log, the next thing that we had to do was begin to shape our lamp. The easiest way that we have found to carve out a digital image is to blow it up in Microsoft Paint to your desired size and then print it off on multiple pages of paper so that you can create an outline to carve around. This always works well whenever you're carving around one X-Axis of an object, but when you need to carve out the Y-Axis of your item this can get a bit trickier because you have most likely cut away your original pattern.
So what we do to compensate for this is save some of the chunks that we cut away and tape them back on to the project so that we can then draw the top-view of our item and then carve around this pattern with our bandsaw.
Step 4: Main Shaping
I don't want to be too vague on how we did this, but to be honest, a lot of woodcarvings is all about just taking your time and envisioning what you want your creation to look like. We used everything from a rotary sander, Dremel, and Sawzall (would not recommend this one {see video}) to get the shape we were looking for. We still have a ton of things to learn about wood carving so hopefully, we'll get better in time.
Step 5: Wood-Burned Designs
This step was pretty simple but very time-consuming. Based on the picture I was going off of, I couldn't really see any of the designs on the actual lamp. So I just eyeballed what I thought they looked like and left it at that.
Step 6: Finishing Up
To finish off our lamp, we merely used a dark cherry based stain to simulate the actual lamp's darker appearance.
Looking back on our lamp now, I know there were several areas that we could have done better on. But that's what making things is all about, it's about seeing what you're good at and what you're not so that you can always keep improving on yourself and your projects.
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Party Challenge
      Party Challenge
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    2 Discussions
    Corinbw
    5 weeks ago
    Ok, Just let me be the first to say. This is amazing. I absolutely love it. You couldn't have picked a better piece of wood. It has such amazing wood grain and spalting. I hope you do well in the woodworking contest. Amazing shape and desings on the side as well. Keep it up. This is the kind of stuff that keeps me coming to instructables.
    secretstashbrosCorinbw
    Reply 5 weeks ago
    Corinbw... You have no idea how much that means to us right now! We honestly thought most people hated it because very few of our subscribers watched the video. So we just want to say thank you for such a positive comment! We really appreciate it!
