Change a Mountain Bike Tube Without Tools
8,288
25
5
Sometimes, not using a tool is easier and faster than having to track it down. Besides, it's an added satisfaction to be able to perform a project with just your hands. In this instance, I will show the easy way to change a bicycle tire without using those pesky and break prone tire levers. This works very well for mountain bike tires or essentially wide tire. I've tried it with road bike tires, but they are tighter to the rim it's much more difficult to do.
I put this instructable together for my hackerspace, Bloominglabs, for the makerspace contest.
Supplies:
Step 1: Deflate Tire and Loosen Bead
Most likely you'll be able to skip this step as the tire is already flat. I mean, there aren't many other reasons to change a bike tire tube. But should you need to let some air out and you don't have a pressure gauge to properly deflate the tire, the top of the valve stem cover works well (or any other small and fairly pointed object).
When the tire is deflated, I find it helpful to squeeze the sides of the tire all around the tire to help break the tire loose from the rim. This is especially helpful if it's an older tire that has been on the rim for a long time.
Step 2: Pull Off One Side of the Tire
Here's the trick of the entire instructable. It takes some hand strength, but less than you'd think.
1. On one side of the tire, place your hands about 4 inches apart across the tire.
2. Push in and up with your thumbs.
3. Use your fingers to press the tire forward to bring the tire wall over the side of the rim.
4. Use one hand to keep the tire wall on the outside of the rim and use the other to perform the same in and up motion with the other hand where the tire wall is sitting on top of the rim. The tire will continue working itself off of the rim.
5. When you have a decent portion of the tire wall out, you can put your fingers inside the tire wall and slide it along the remaining portion of captive tire.
Step 3: Remove the Tube
Now that you have one side of the tire out, you can remove the tube.
1. Push the valve stem up threw the the rim and pull it out the side.
2. You can now start pulling out the remainder of the tube.
Step 4: Put in the New Tube
You have now either fixed the current tube or replaced it with a new one, so now you have to put it back into the tire.
1. Lay the tube over the side of the tire and get the valve stem lined up with the valve stem hole.
2. Squeeze the tire where the valve stem hole is located. Push the valve stem through the valve stem hole.
3. Pull on the valve stem to make sure that as much of the stem is through the hole as possible. You may have you work at it a little bit as it can stick.
4. If the tire doesn't come back over the tube by itself, lift it up and over.
5. Starting next to the valve stem, start pushing the rest of the tube into the tire. Take care not to twist the tube.
Step 5: Adjust Valve Stem
The last thing to check is whether your valve stem is straight. A small angle doesn't matter, but too much of an angle can damage the valve stem over time. The tire hasn't been inflated yet, so may as well fix it now. All you have to is hold several rim spokes with one hand and pull the tire so that the valve stem is straight with the other.
Step 6: Push the Tire Wall Back Inside the Rim
Now that you have the tube back inside the tire, it's time to push the tire wall back inside the rim.
1. Pretty much the reverse of removing the tube, squeeze the side of the tire and push it over the rim wall.
2. Use one hand to hold the starting point in place and use the other hand to continue working more of the tire inside the rim.
3. Once it holds itself, you can use both hands to work the remaining tire, which you'll need when you get to the end.
    • Fandom Contest
      Fandom Contest
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    5 Discussions
    JackR156
    1 year ago
    I want to know how to replace the outside tire on my Patrol Carbon, not the inner tube. I have searched everywhere on the internet and i cant find it. Hopefully someone can help?
    rabbit_manJackR156
    Reply 1 year ago
    From what I'm seeing, it looks like a standard bicycle tire. What issues are you having? You most likely have to do the exact same thing that I do in this tutorial, take the tire completely off and put the new one on.
    JackR156rabbit_man
    Reply 1 year ago
    Sorry, I thought that you were only replacing the inner tube. Cheers, JackR156.
    batvette
    2 years ago
    I thought everyone knew this already... it works on most tire/rim combinations, not all. (My shimano XTRs, the ones they made about 10 years ago with the spoke adjusters on the hub, would not mount conti gatorskins without levers.)
    However you don't focus on the one tip that makes this work: You've got to make sure the bead of the side opposite of the side you are prying off or on, falls into the deepest part of the valley of the rim. (Then of course you work that extra slack around if it doesnt do so by itself)
    Second that baby powder suggestion. Many tube mfrs put it on already, talc is a protectent of rubber and stops decay from petroleum products. Its a win-win application.
    zencuke
    2 years ago
    This is great. Just one thing to add. If you coat the inside of the tire with baby powder this method gets much easier, even for street bikes. The tire doesn't stick as aggressively to the rim. It also allows the tube to slip more freely reducing the chance of a fold which can cause leaks. I've been doing this on my street and touring bikes for years. I hate using tools because they always pinch the tube often causing a second (or third or...) flat.
