Cheap In-Car Entertainment System Retrofit
8,116
99
About: Hi! If you like my tutorials, you can check out my youtube channel: https://www.youtube.com/user/mrfixpl
You will need:
  • Peugeot 3008 with RT6 navigation system (or any other car with any other multimedia system that lets you plug-in AV signal).
  • Media player with USB and card reader (about $30).
  • SD card or USB drive for media.
  • 12V-to-5V car charger.
Supplies:
Step 1: Modify the Media Player IR Receiver
Since I wanted to hide the media player somewhere inside armrest, it was necessary to extend the IR receiver.
I've opened the media player (warranty void), desoldered the IR receiver, and extended it with 1 meter of 3 pin wire.
Step 2: Modify Power Supply
Then I've disassembled phone charger, soldered two wires with a fuse (just to be sure).
Next I've modified the power cable for the media player so i could plug it in the USB port in car charger.
Step 3: Test and Mount
After testing everything on the table and inside the car it was time to hard-wire everything to the car.
First i found 12V ignition hot to power the device. Next I've connected three RCA connectors to AV-IN port. Then i placed the IR receiver next to the gearbox.
Media player was installed inside armrest so the USB and card ports were easy to reach.
Step 4: Done!
Turned everything on and confirmed that it works as it should.
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    3 Discussions
    minkyrocky
    3 years ago
    If youre a sparky, could you please post how to fit spotties to a nudge bar?
    Happy that you like it!
    When I have time I'll post another system that I put together from a old Nokia N95 phone, bluetooth GPS receiver, bluetooth OBD reader and 7'' LCD screen in 2002 Subaru Impreza.
    This had navigation, lap timer and in-car entertainment features.
    Follow my account and don't miss it!
