Cheapest Way to Clean Wheels Like a PRO (Under 1,5$)
2,401
6
7
About: Crazy stuff and instructables for normal live and survive
We use oven cleaner that cost 1,12€ to clean the rims with perfect shiny results, like a professional. It takes less than 10 minutes and it is very easy. Citroën Berlingo 2017 alloy wheels are cleaned.
You just need: Oven cleaner A buck of water Old t-shirt I bought the oven cleaner in Mercadona (Spanish version of Walmart, Tesco, Aldi).
Step 1: Clean the Wheel With Water and Old T-shirt
Clean the wheel with water and old t-shirt
Step 2: Let It Dry for 5 Minutes
Let the wheel dry for al least 5 minutes.
Step 3: Pour the Oven Cleaner Foam All Over the Wheel
Pour the oven cleaner foam all over the wheel. Until you completely cover all the rims.
Safety is number one priority: From this point wear glasses and globes.
Step 4: Wait 10 Minutes
Let work the oven cleaner between 10 or 15 minutes. No more, would be bad for your wheels.
Step 5: Remove the Foam
Remove the foam with water and the same old t-shirt. After you remove all the foam you can use a hose to remove well the oven cleaner.
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    7 Discussions
    Lorddrake
    Question 8 months ago
    does the oven cleaner have any adverse affects on the rubber of the tire? I know in the past there have been some cleaning agents that would cause the rubber of the tires to dry out and crack.
    1 answer
    CrazySurvivalStLorddrake
    Answer 8 months ago
    I do it once a year and I do not perceive any damage on the rubber, plus you change the rubber every 2 or 3 years. I wouldn't do it every month, also it is not necessary.
    codeslayer
    8 months ago on Step 5
    Oven cleaners affect aluminium even if you leave them for just 10 minutes. This means every time you do such cleaning procedure the surface will become more and more dull.
    I had a aluminium baking tray and tried to clean it with an oven cleaner. I ruined it by leaving the cleaner just for about 20-30 minutes applied. I admit it could have been too long for that tray but doing it repeatedly for only 10 minutes will probably end in the same disaster.
    EcoExpatMike
    Tip 8 months ago
    Wear eye protection. Oven cleaner is usually very caustic and can cause serious eye damage. A pair of glasses should do the trick.
    RobR2
    I tend to over do things, but when I clean my wheels I remove them from the car and start with doing the inside of the wheel,then do the lug holes with a toothbrush, this goes from a clean car look to a fresh restoration level clean!
    tercero
    8 months ago
    Thanks. Never thought of using such an unorthodox approach. It's just sodium hyroxide after all. I'd use gloves myself as it's kind hard on the skin, but outside of that. Brilliant idea.
    Thanks again.
    Barrie, Ontario.
