Children's Clothes Rail
2,331
51
7
About: I love creating and making things. From leather wallets, wooden rings to DIY projects. I also make videos of everything I make, have a look at my YouTube channel.
In this video I show how I made this Children's Clothes Rail.
I haven’t posted on Instructables quite a few months, that's in part down to my wife and I recently having a baby. But I’ve been desperate to get back out and make something, so I thought I would make this cute little clothes rail for all of her clothes.
For this build you will need:
Wood Lumber
Spray Paint (US)
Spray Paint (UK)
Painters Tape (USA)
Masking Tape (UK)
Step 1: Measure
I wanted to use some of the wood I already had in the workshop. So I used some CLS Timber from a leftover project and cut 2 pieces down to 120cm.
You can make this as tall as you like, but I wanted it to be able to be useable for us adults, and when my daughter gets a bit older she will still be able to reach it.
I took this to the mitre saw and cut it down to size.
Step 2: ReSaw
The wood was a little bit too chunky for this build, it really doesn't have to be that strong, so I took it over to the band saw and resawed it in half. I did this for most of the wood in this project. It would have been much easier if I bought wood that was already a bit thinner, but as I said I wanted to use what was on hand, and in the UK these are super cheap and readily available is the likes of Homebase and B&Q.
Then I cut another piece that was going to make the width of the clothes rail. I just guessed at roughly how wide I wanted this, and went with 80cm.
Then further cut more pieces at 30cm wide, these are for the bottom slats.
The bandsaw left a few rough marks, and generally, I wanted to smooth the whole thing a bit more, so I sanded all the wood up to 220 grit.
Step 3: Think Before You Cut
It was about now in the project that I realised I really should have put a little bit more thought into the order in which I was doing it. I now needed to drill the hole for the rail, so I clamped the twice pieces together. If I had done this first, no need to clamp and I would have got a slightly cleaner hole, but it worked out fine in the end.
I was using a 22mm wooden dowel for the rail, so I grabbed a 22mm hole saw bit and drilled a hole on both sets of legs.
Next, I cut down the dowel for the rail using the mitre saw again. I left this 10cm long at either end this would give us a bit of extra hanging space and I think it looks pretty cool.
Step 4: Paint
I used some masking tape and masked off an area around 60cm from the bottom. I then used some white spray paint and painted the bottom half white. I left the bottom slats off for this bit so they would be contrasted to the white colour. I ended up needing 2 coats of paint, but I still wanted to be able to see the wood grain underneath.
Step 5: Screw
I use a countersink bit and drilled and screwed all the slats together, and the side support pieces. I also added a couple of screws at the apex of legs to add a bit more support. Then I slid in the dowel rail. You can glue this in place if you want, but I left it loose so I can take it apart easily.
It is plenty strong enough for all the clothes, but maybe not a child swinging on it!
Step 6: Final Images
That's it complete. It was a nice and easy project, it took less than a day to make, and would have been quicker if I hadn't been filming, and I wasn't making the design up as I went.
If you would like some plans for this let me know, I am happy to try and make some.
    • Organization Contest
    • Epilog X Contest
      Epilog X Contest
    • Faux-Real Contest
      Faux-Real Contest
    7 Discussions
    DanieN1
    24 days ago
    My God! The main project photo, the color scheme - it's gorgeous! It makes me wanna buy 10 of them. Really beautiful, well done.
    aCuriousCreatorDanieN1
    Reply 15 days ago
    Thanks so much man. Yeh happy with how it come out :) thanks for reading
    cdemar
    19 days ago
    I am using your idea to build a smaller tool stand that goes inside a popup shelter outside.
    Chainsaws fit under the lower shelf, and upper shelf is a 36" x 12" wire rack. I will hang extra chains on the outer side of the dowel, and drape things over to dry. Power tools on lower shelf.
    aCuriousCreatorcdemar
    Reply 15 days ago
    That looks great! really great idea :) love to see a photo when you've finished it!
    seamster
    4 weeks ago
    This is a really slick idea, and something I might make. Great work, thank you!
    aCuriousCreatorseamster
    Reply 4 weeks ago
    Thanks so much :D If you do make sure to come share a photo. It was good fun to make and very simple!
