Chill Drink in 10 SECONDS!
5,240
55
About: Hi, My name is Luigi "Ludvic" for the friends, I really like the recycle, the technology and the Chemistry, another of my hobby is Videomaking and I love Youtube, You can check my project on LudvicTV' Chane...
Hi Maker!
In this Short tutorial I show an awesome experiment for Cool you drink in Few Second, You need only Compressed Air and...Your Drink obviously :)
If you want to see the Final result Watch the video Below:
Source: I see this awesome project the first time on this guide!
Supplies:
Step 1: Check the Temperature
For test the effective result of this experiment I use Thermometer and I analyzed the initial and final temperature of my drink.
This step isn't really necessary, I made only for a test and to show if the experiment work :D
Step 2: Super Cooled
Grab your Compressed air and turn upside down, this step is really important..
Spray on your Drink in all part, from top to the bottom, be careful because the air come out from the spray bottle it's really cold and can burn your skin, use the glove if you prefer..
Step 3: Less Over 10 Grade
Whats happened here?
This is a really simple, a pressurized gas will decrease in temperature as the pressure is released, and increase in temperature as the pressure is increased. This is how most cooling systems work.
When You put this air near your drink much of the "cool air" refrigerate your drink, be careful because you can burn your skin !
Try to make the same think with the compressed air in the water! the water became Ice immediatly!
Thank you so much for your attention!
here you can see other project I made for this summer:
https://www.instructables.com/id/Best-Cut-Watermelo...
https://www.instructables.com/id/Cool-Drinks-in-3-M...
https://www.instructables.com/id/Awesome-Watermelon...
https://www.instructables.com/id/How-To-Make-Ice-Cr...
If you want other awesome experiment and project follow me on Youtube on this link
Thank You so Much for Your support :D
Ludvic!
Step 4:
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    3 Discussions
    XxelectricmanxX
    3 years ago
    And we ended up spraying half a can worth in one room
    XxelectricmanxX
    3 years ago
    Also... You may not want to spray that inside too much... I learned the hard way that its not that good to breathe in... Long story short I was playing with my compressed air with my nephew
