Chocolate Nut Assortment
17,908
195
49
Chocolate hearts aren't for everybody...
Step 1: Form Mold
Make Wooden Frame
Cut two 3.5" wood strips
Cut two 5" wood strips
tape all pieces together.  Tape the last corner with a tab of duct tape to use as a clasp (you will need to attach and remove it for each batch)
Silicone Putty Set Up
Measure out equal parts of silicone putty components and mix according to instructions
Spread out evenly in the frame
Place hex nuts
Wait 10 minutes
Cut Mold
Remove nuts from mold.  This can be tricky since you will have to unscrew them off the silicone.
Cut each section in half.  Trying to unscrew less-than-solid pieces can result in accidental cracking.
To make filled chocolate, cut out middle piece of silicone and sand to even out both sides.
Variation
I also made a smaller mold with different size nuts...and a wing nut : )
Step 2: Chocolate Shells
Once the mold is all set, it is time to fill it!
Melt chocolate over stove or in the microwave and stir until smooth.  I used a small pitcher so that the chocolate could be poured directly from it.  I added a silicone sleeve to the side in lieu of an oven mitt.
Pour into molds.
For the molds that will have filling, pour in enough to cover the bottom and use a spoon to push chocolate against the sides of each section.
Sections for the solid sections should be filled in 3/4 of the way.
Tap mold against the table to push air bubbles up and ensure that chocolate spreads out evenly.
Place mold in the freezer for 5 minutes.
Step 3: Solid Chocolates
A few variations for solid chocolates.  Try stirring in...
  • Dark and white chocolate together
  • Chopped pistachios
  • Coconut flakes
  • Drizzle with contrasting chocolate
Step 4: Amaretto Truffle Filling
Remove molds from freezer and fill with...
6 ounces Chocolate
1 Tbs Butter (unsalted)
1/4 Heavy Cream
1/8 cup Amaretto
Directions
  • Melt chocolate in a double boiler
  • Add butter and cream and mix
  • Once smooth, add Amaretto
  • Pour mixture into a glass dish and set in the fridge for about an hour
  • Use small spoon to take some truffle out and place in a chocolate shell
  • Cover in chocolate and allow to set
Step 5: Additional Fillings
Try out different fillings! Nutella is great in anything, and peanut butter is a natural choice.
Now what other candy hardware to make...?
For an Instructable on the Tiny Toolbox:
https://www.instructables.com/id/Tiny-Toolbox/
Candy Contest
Second Prize in the
Candy Contest
Halloween Food Challenge
Finalist in the
    • Pie Contest
      Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    49 Discussions
    mrbrian1969
    8 years ago on Step 5
    ?nutella? the only place i've seen that is in the dominican republic. are you from the D.R.?
    Keira_Yagami
    7 years ago on Introduction
    I think it would have been cool if you had made a Sugar Toolbox...making an even better gift.
    RamDragon
    I didn't see the question, but was there a food-safe consideration with your mold choice? Brilliant intructable, by the way. Perfect for mending a broken heart.
    sunshiine
    This is soooo kewl! Nice ! Thanks for all your hard work.
    Dr. dB
    8 years ago on Introduction
    ...not entirely sure, but you probably have a screw loose to have though-up such a deliciously-nutty project...
