Cinder Block (CMU) Offset Smoker
54,273
282
26
For a small fraction the price of a heavy steel smoker, you can setup a large capacity cinder block version. Not only will it be cheaper it will be better insulated. Follow the instructions attached for a very effective, efficient and not bad looking unit.
Supplies:
Step 1: Design & Dimension
Review design dimensions.
Step 2: Clear Area
  1. Clear appropriate sized area with offsets as needed.
  2. Soften and level dirt or ad layer of sand.
Step 3: Procure Cinder Blocks & Bricks
  • Cinder Block: 8x8x16 (Qty. 60)
  • Cinder Block (1/2): 8x8x8 (Qty. 15)
  • Cinder Block (Caps): 8x2x16 (Qty. 16)
  • Clay Brick: 4.5x9x1.75 (Qty. 24)
Step 4: Base Layers
  1. Place base layer of cinder blocks and use level to confirm flatness.
  2. Alternate seem on each level.
  3. Eliminate all air gaps.
Step 5: Complete Firebox
  1. Build firebox with rotated CMU bricks for air inlet and outlet as shown.
Step 6: Complete Chimney Structure
  1. With a chisel, break a 1/2 brick into half again so that the chimney has an opening as shown in picture.
  2. Stack chimney to 3 blocks high for appropriate air draw.
Step 7: Add Top Caps
  1. Place top caps on alternating seems from cinder blocks underneath. (Top caps will ad a flat surface for lids to seal better)
Step 8: Lid Construction
Lid Dimensions: 30.5" x 38" (Qty. 2)
  1. Cut plywood to dimensions.
  2. Procure Heat Shield Insulation (4 ft x 6 ft) and cut to same dimension as plywood.
  3. Using a staple gun, apply insulation to bottom side of wood.
  4. Fasten two lid pieces with hinges in middle and and handles.
Step 9: Add Clay Bricks
  1. Line the inner firebox with clay bricks for extra heat protection for the concrete blocks.
Step 10: Rebar Grate Support
  1. Measure off alignment for rebar supports. (3 places)
  2. Using a 1/2 inch concrete drill bit, drill holes through only one side of blocks.
  3. Insert 25" long, 3/8" rebar.
  4. Procure or cut, 3/4" X 13 ga. flattened expanded metal sheet to 22" x 53"
  5. Place expanded metal on top of rebar for a cook grate.
Step 11: Fire Box Lid
  1. Procure 29" x 31", 3/16" thick carbon steel plate.
  2. Drill and bolt in handles for easier removal (not shown)
3/16 steel plate is necessary for firebox as temperature here will be too extreme for thinner materials
Step 12: How to Use
Now you're ready to test it out!
  • Use a left over block as a damper for your incoming fire vent. Slide back and forth to adjust heat.
  • Leave stack vent open at all times.
  • Add another expanded metal grate over the fire-pit if you would like the option to grill over the fire. (Good for tri-tip and chicken)
(This specific pit has about a 20 degree difference from one side to the other....which is actually very impressive.)
First Time Author Contest
Second Prize in the
Home Improvement Contest 2017
Third Prize in the
3 People Made This Project!
  • Classroom Science Contest
  • Party Challenge
    Party Challenge
26 Discussions
licenseless
1 year ago
I might have missed it... But what is the overall cost of this? Considering how much of a surface area this gives and how much room it takes up... If the cost is low this could be something everyone should do.
elnino2783licenseless
Reply 1 year ago
Craigslist is an excellent resource for cheap cinder blocks. Some people give them away for free even.
licenselesselnino2783
Reply 1 year ago
hahahah I didnt even think of that. hahahah Great build
jason_5hundylicenseless
Reply 1 year ago
It can definitely be done for cheaper if you have better resources and do a little more shopping around. But it cost me right around $330 total. The blocks themselves cost about $125. Having the expanded metal and steel plate lid cut to size were a large part of the expenses as well.
davidapfeiffer
1 year ago
F.Y.I. ... you need to "season" any exposed cinderblocks; i.e. do several pre-burns to coat and seal their surfaces, BECAUSE the cinderblock material is toxic, and you don't want THAT on your meat. Just sayin' ...
DanielR421
1 year ago
Question: Are you burning the wood directly on the ground in the firebox?
Would there be any benefit to raising the fire up using a heavy grate or a rebar mesh in order to allow the ash to fall below?
Also, how do you dispose of the ash accumulation? Through the vent hole seems labor intensive in addition to digging out your sand with it?
jason_5hundyDanielR421
Reply 1 year ago
I'm burning wood directly on the ground. I start with a bed of hot charcoal and ad the splits on top. I've found no need for grates as the fire burns nice and even.
I just use a an ash shovel to scoop out from the top (with the lid firebox lid removed). Takes about 5 minutes if that. It's hard packed dirt underneath. No problems at all.
Robert DiffinS
1 year ago
A great tutorial! I'm going to drill a couple more heights for rebar holes so I can try that "whole pig" thing.
CaptainNemo
1 year ago
Now you just have to add a pizza oven on the end with a additional fire box and you have it all. :-)
terry954
1 year ago
Good day, very cool. My son and I are making plans to do this while my wife is on vacation with her sisters. No need to explain why this is the preferred time is there!
hobbs51
1 year ago
Like Chef John, I'm interested in how you eliminated all air gaps. Did I miss something in the tutorial? It doesn't look like you used mortar... did you use a sealer, or other material to secure, and minimize air gaps?
jason_5hundyhobbs51
Reply 1 year ago
I suppose I should have worded it a little better. "Mitigate all air gaps." Without mortar you won't be able to "eliminate" them. With this design I have had almost zero smoke leaking through.
stickin2jjason_5hundy
Reply 1 year ago
As with most natural fluids, smoke should take the path of least resistance. The bricks are much tighter than the path of flow you created with the open bricks. As long as they remain unobstructed, the air should "choose" to flow through that pathway. Get a few cookouts and grease popping and you'll probably generate some sort of "meat mortar" that even further seals the edges.
BobH160
1 year ago
Really good idea as I have been thinking about building a smoker as we do not get the variety of choices here as in N. America where I first used one. I'm not convinced about using wood for the lids though, perhaps a thin steel sheet would be better.
jason_5hundyBobH160
Reply 1 year ago
Same problem in California. A good steel offset trailer is twice the price here vs. the south. Steel sheet would work great for the lids. It's just more expensive and doesn't provide the same amount of insulation. Would definitely be more durable though. So far the wood lids have worked great. With the insulated lining, they don't take a lot of heat. I will be covering/protecting them during the rainy seasons of course.
ChefJohn1955
1 year ago
IN the procedure you said Step 4
  3. Eliminate all air gaps\
But you didn't say how .. was it just to lay the cinder block as snugly as you could on top of each other or ....
jason_5hundyChefJohn1955
Reply 1 year ago
Correct. Cinder blocks are a little irregular, so shuffling certain ones around and even filing off irregularities can help. Getting your base layer tight and flat is the most important. But this design has no mortar, so just pushing them snug is all that is required.
JamesG197
1 year ago
Wouldn't a piece of Concrete board be better than plywood? Like you would use in a bathroom floor.
elnino2783JamesG197
Reply 1 year ago
I've still got the same board on mine after two long pig roasts and several smaller uses between two summers, so you just have to keep the top out of the weather.
