Coconut Bikini Top
44,136
168
17
Whether you are getting ready for your summer vacation on a tropical island or you are just looking for an all-natural material, eco-friendly bikini top wanting to say “Aloha” wearing the appropriate apparel . Well, here is how to make your own Coconut Bikini Top!
Step 1: Tools & Materials You Will Need.
First thing you should do is get yourself a coconut!
Check the coconuts for the right size and shape.
Tools & materials you will need:
Spoon
Knife
Saw
Permanent marker
Sand paper
Steel wool
Power multi-tool
Wood polish (optional)
Thin shoe laces
Step 2: Saw the Coconut in Two Pieces
Saw the coconut in two pieces. Try to make them as even in size as possible.
Slice & remove the (white) edible part of the coconut with a knife.
Use the spoon to help it loosen from its shell.
Use the coconut meat to whip up a coconut cream pie or for some crazy cocktail.
Step 3: Use the Sand Paper to Smooth the Edges
Use the sand paper to smooth the edges of the coconut husk, no pointy edges should exist where the coconut will come in contact with the skin.
It has to be comfortable.
Place the coconut husk in warm water, this will soften the rough part of the husk, rub it with steel wool until you are left with a smooth, clean coconut shell.
Trim any rough edges of the husk with sand paper. A power tool makes the job quicker in less time.
Step 4:
Choose the final positioning of the bikini top and mark the shells with an oval shape.
This will make the coconut look more like a bikini top. Rather than looking just a coconut cut in half .
Make the cut with the power multi-tool or with a saw. Again trim all the edges with sand paper so it looks and feels smooth.
Step 5: Finish Off According to Your Design
Mark the positions of the holes to be made according to your design. Placing two laces in the middle connecting the two cups, adds extra strength to the bikini top.
Drill the holes with a drill bit as big as the laces, and make the inner side of the hole a bit wider so the knot will fit snugly.
Make a knot at the end of the lace pass the lace through each hole and make another knot exactly on the outer side of the shell, this will keep the lace in place.
Polish the outer surface of the coconut top with some wood polish to make a nicer finish and this will also make it waterproof.
Step 6: Your Bikini Top Is Ready to Be Worn!
Your bikini top is ready to be worn!
Enjoy your handmade, all natural material, eco-friendly coconut bikini top! =)
Swimwear Contest
Runner Up in the
Swimwear Contest
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    17 Discussions
    itobor2525
    4 years ago on Step 6
    Need a model to fully appreciate the finished product.
    kun0515
    4 years ago on Introduction
    As a matter of fact,Coconut shell can be eat in some way
    I love your idea,but it looks just for A-cup
    kelinalkun0515
    Reply 4 years ago on Introduction
    I can confirm that it is larger than a B cup - probably closer to a C on a small frame. I had something similar once and it had lightweight quilted cloth on the inside and around the edges for comfort.
    Vyger
    So, is this a one size fits all or do your coconuts come in various sizes?
    tkjtkj
    Excellent!
    1) Interesting , imaginative concept
    2) clearly described construction
    3) sexy!!!
    What more is necessary!!
    jon
    danzo321
    4 years ago on Step 5
    Shoelaces give a slick look, but for an "islands" look, might use leather thong or a fiber rope.
    danzo321
    No point smoothing the edges until you come to the right final edge shape. Breasts stick out of a compound-curving oval cylinder (rib cage) so expect to curve most of the edge.
    fixfireleo
    hmmm....i doubt it would be comfortable and i think you would have to have pretty small breasts to wear it. far more appealing to straight men than anyone else.
    quadratpups
    4 years ago
    very cool, wanted to make one a while ago, but forgot over it. So now I get remembered by this instructable and know what I'll do on the weekend. Thank you.
    brmarcum
    Very nice. It doesn't even look real with how clean and shiny it is. Good job.
