Coffee Table Made Form a Single 2x4
90,010
418
56
About: If you like simple solutions then here you can find some of my crazy ideas.
To get an overview please watch the video.
First, sorry for my English!
This coffee table was made by a 2"x4" (5cm x 10cm) and 8 feet (240cm) long.
I know it is a wrong 2x4 because it is 2"x 4" and a real 2x4 is not 2"x 4"
The wood I used was Swiss pine, in German "Zirbe". It smells pretty good, so I decided not to use any wood finish.
Supplies:
Step 1: Plan and Tools
All measures on this plan are in cm!
Tools, I used:
  • table saw
  • router
  • band sander
  • drill press
  • clamps
  • chisel
wood glue
4 screws
Step 2: Cut the 2x4 in Pieces
I have only a small table saw, but with a clamp and a supporting table, it was no problem.
Step 3: Cut the Pieces in Width
Swiss pine is very soft. So it was not a problem to cut it with a fine saw blade.
Step 4: Milling
I cut a 4mm slot in the long table frame piece
all the small boards of the table top got a shoulder, so the fit in this slot
every foot got two slots
Step 5: Cut Tenons
the pieces of the frame got tenons
Step 6: Sanding
a lot of sanding!
Step 7: Assembling the Table Top
I glued every tenon in the slot of the frame with a small separator made out of 6 mm MdF
Then I glued the second board on the tenons and clamped all together.
After the glue was dry, I cut the boards in length and sand the table top.
Step 8: Preparing the Table Stand
the table top was screwed on the stand
I drilled holes with a big drill bit half into the frame boards
and with a small drill bit all the way through
Step 9: Assembling the Table Stand 1
First, I glued the two small pieces on the feet
Step 10: Assembling the Table Stand 2
then I glued the long parts on.
Because my clamps are not big enough, I made this little jig.
Step 11: Assembling
Just screw the table stand on the table top.
If you have any questions, please write them in the comments.
If you like this, please vote for it in the table contest.
Tables and Desks Contest 2016
Third Prize in the
    • IoT Challenge
      IoT Challenge
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    56 Discussions
    joseph.campo.35
    Reply 2 years ago
    I own a home. I don't have a table saw. I don't have a router. Did you see the machine he used to taper the edges of the legs? Plus he had a high power saw area, not to mention all the space required to house the table saw plus the layout board. Sorry, that's not all found in the typical home. Has nothing to do with gender, please.
    AdamT96joseph.campo.35
    Reply 2 years ago
    http://www.toolcrib.com/blog/2009/03/14-circular-s...
    not affiliated with this site but I can't believe everyone that is on this site that fosters creativity and are willing to let themselves be so limited. Everything you need to make a build like this can be done with a circular saw and a few DIY jigs. If this is something you might have a passion for (which I believe is the reason we are drawn to these sites) then learn to adapt!
    sharonnah59joseph.campo.35
    Reply 2 years ago
    Joseph, it's refreshing to see another gal with wood working tools. And I believe you are quite wrong in your assessment of the average US homeowner. There are ways to have a drill press, routing table, and a table saw in the space of one work table...if you are interested.
    milindnirgun
    2 years ago
    Your work and your equipment/workshop is awesome and I am jealous. I don't think I can get to the point where I can build this project but I got a few good ideas from your video that can be applied to other projects. So thank you.
    AdamT96milindnirgun
    Reply 2 years ago
    don't limit yourself! We do these things to fuel a creativity inside of us. Here is a site with a ton of jigs to make that allow you to do almost all of this with just a circular saw.
    The rest can be completed with a chisel and a hammer... same tools that the cavemen used lol.
    attawudh
    2 years ago
    nice mood when used.
    KikiS9
    2 years ago
    This is really great - thank you:) It makes me want to build it now! For the tools you use - mainly a table saw and router, and clamps? Anything else? I first need to come up with building a router table or stand, as I just have the router unmounted right now... guess that should be my next project.
    WackyPupKikiS9
    Reply 2 years ago
    You can build a nice router table, there's probably an instructable for it! Or check yard sales, that's where i got mine.
    bigpig
    2 years ago
    I could do this but I'd need a 2x4 that is 187 feet long!
    Cayotica
    2 years ago
    absolutely loved your use of the wedge claims that is a technique we don't see very often these days. BTW here in America an unfinished 2 x 4 is really 2 x 4.
    F. BrianHCayotica
    Reply 2 years ago
    Not sure where you are finding a 2x4 that is 2"x4" unless you are getting one from a local mill. Most finished or unfinished 'dimensional lumber' labeled as a 2x4 is actually closer to 1 1⁄2 by 3 1⁄2 inches (38 mm × 89 mm) here in the USA.
    CayoticaF. BrianH
    Reply 2 years ago
    Unfinished/rough sawed lumber is easy to find if you don't mind it being scrapped. Single use pallets, shippers even internal frame work of quality furniture and the mill, my brother the surgeon (tree that is) rough saws his own lumber but it's too green for me to use, l like kiln dried myself.
    Cayotica
    2 years ago
    don't need all that fancy stuff l made the table with only my 10" contractor table saw an a 1/2" chisel.....oh and twine lots of twine.
    UbyS
    2 years ago
    Will be good for the ones that doesn't have the tools to have the measures of the cut pieces used in this project. We can have the pieces cut by the measures and do the assembling process.
    karnowskij
    2 years ago
    I see a lot of people saying they couldn't do this because they don't have the same tools. Using standard dimension lumber, bought at a big box store, change the dimensions, and with a few simple hand tools you should be able to build this. It may not be as finely put together, but with a hand-held drill, hand-held circular saw, back saw and some proper planning (use clamps and a straight edge to cut the slots) you should be able to do most of the jointery.
    A nice clean design! Well done!
    RobertC443
    2 years ago
    I'd like to add some additional thoughts to my input below....1. If you don't have the tools Stephan has...this would be a great opportunity to meet/work with a neighbor who does. 2. If you decide to use the Pocket hole technique I mentioned..... you can substitute 1X2's and 2X2's and avoid the rip cutting which Stephan does. This way everything can be bought at the store and all you need is a handheld electric drill to assemble.
    RobertC443
    2 years ago
    Hi...very nice job and great photo's and explanation. I would like to comment on MadMax input below. While yes a big box store will make the cuts for you, the joint design will have to be modified. StephanP1 designed the table with mortise and tenon joints. An alternate would be to use Pocket Hole screw (such as the Kreg system). If you do, then all dimensions should be shortened the length of the tenons. Good luck to all...
