Compact Clay Pot Tandoor Oven
13,403
197
11
About: There's always a better way, just need to keep recycling those brainwaves!
This is my attempt at making my own Tandoor Oven. I browsed a few designs and came up with this setup. Its low cost, fairly compact, lightweight and portable.
Its charcoal fuelled, with an air intake and sweep out hole at the bottom.
Supplies:
Step 1: What You Need...
Parts:
* Oil container drum 20l+ (free)
* 2 clay pots which fit above (£10)
* vermiculite (10 litres £4)
* 2 bricks (free)
Optional:
* broken tiles/rubble (free)
* 3 metal knobs
* sand/cement
Tool/Skills:
* Angle grinder with stone cutting disc
* Hammer
* Flat blade screwdriver or chisel
* Drill and masonry and hss bits
Step 2: Cut Open Lid of Can
I used an old blunt screwdriver which i hammered continuous holes around the top edge.
Remove cut lid. Use a hammer to flatten round the sharp edges.
Its a good idea to tape over this rough edge to prevent cuts to your hands as you will be working inside it.
Remove any remaining oil using a dry cloth.
Step 3: Cut Air Holes
Similar technique as lid to cut can air hole.
I beat a and tapered edge outwards using a ball pein hammer and a wooden stump as a beating base.
Pot already had a drain hole. I drilled 4 extra air holes around it.
Step 4: Base Pot & Handles
I fitted 2 side metal knobs i had lying around.
The bottom pot was placed on broken tiles. I also dded some sand to the tile base. Lower pot was inserted and side filled with vermiculite for insulation. I made a paper funnel to get vermiculite in through the narrow border edge. Fill it up to the rim of the pot.
Step 5: Top Pot & Lid
Pencil mark depth of lid cut. I cut using an angle grinder with a stone cutting disc and eye protection
Other people have used a hand tenon saw for the job.
Smooth off the base and lid for a level finish. I added a metal knob with washers for convenience.
Step 6: Stack It Up!
Position the top pot, with wide mouth of top pot touching the rim of lower pot.
I was running low on vermiculite so wedged in some extra broken concrete pieces to fill up the void. Its not the best of insulators but it does help hold the top half in situ.
Fill remaining edge voids with vermiculite.
Step 7: Cap It Off!
This step is optional.
I decided to cap off the vermiculite using sand cement and broken tiles.
This will prevent vermiculite from blowing away, getting wet and keep it weatherproof should it get left outside.
I added broken tiles to minimize cracking and the mosaic finish looks hip. Lets see how well it lasts.
Sponge wipe the cemented tiles for a clean crisp finish, ensuring no sharp tile edges are protruding.
Leave to dry.
Step 8: Finished Product
Loads of cooking space in there. Should be able to do 3 naans at a time or several skewered kebabs.
Its a shame the tin wasnt a bit taller for the extra insulation.
Stack it up on 3 or 4 half bricks to keep the air hole clear and leave some space for an ash collection tray.
Step 9: Lets Get Cooking!
Place coals with firelighter at bottom and light it. I placed 5 lumps of charcoals (hindsight 3-4 would have been enough)
Leave the lid slightly open for air circulation and give it 30-40 mins to get up to temperature. I dont leave the lid fully open as the charcoal could burn too fast.
Wait for coals to go white hot.
I skewered some marinated chicken breast pieces on a hanging skewer and placed in oven. I left lid slightly ajar and left to cook for half hour.
For cleanup, pick out any large lumps and sweep cold ashes down the air hole into an ash collection tray. Beats cleaning a barbecue grill!
Step 10: Conclusion
Tandoori Chicken had the authentic tandoori taste. A little crispy on bottom of skewer end. Need to adjust height of my skewers.
Lamb seekh kebabs came out a treat.
Worked well even with exposed chimney.
Final verdict is waiting for thr naan bread test.
Any improvements?
Yes, add a charcoal tray to prevent charcoal lumps from blocking air intake holes. I made this from external plaster beading hammered into shape. To remove galvanizing i left it to sit on hot coal lumps (or you can use acid)
Also recommend making larger or make more surrounding satelite air intake holes.
The metal lid knob gets hot, so use a wooden one.
If you intend to leave it outside, I would seal the exterior of the clay pot with several coats of varnish. This should prevent it soaking moisture or water. Heating up wet Claypots are prone to crack, so ensure they are dry before use.
Outdoor Cooking Contest
Second Prize in the
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    11 Discussions
    Mugsy Knuckles
    2 years ago
    That angle grinder would be faster than the screwdriver and hammer for cutting off the top. Just do plunge cuts first to avoid breaking the cut off disks, then grind the remaining arcs off with the wheel.
    wynkin
    3 years ago on Introduction
    Interesting idea - now you have to learn to slap the dough on the wall without burning yourself!
    Reema121
    3 years ago
    I'm so impressed by your tandoori I love it just wanted to know how big is your flower pots thanks
    solara70Reema121
    Reply 3 years ago
    My pots were 26cm. I would measure your container and pots to ensure they will fit. Mines was 26 versus 32. Pretty snug, but maximised on cooking volume.
    Edbed
    3 years ago
    Great idea!
